Hi Ginko. I have Phillips TV 60PP935217,I replaced the board power supply including flyback(LSB board #313503710171), and the 2 STK392-120. After replacing 2 ICs convergence chip ,it had the problem with Red convergence, I could remove the Red convergence in vertical but no horizontal line at all, I checked the voltage at the STK 1 (-22V,37V) and STK 2 (-37V,37V). Do you think the LCHDR Auto Convergence board is bad(PN:31350133233.3 01)? Please give me advise. Thanks, Tom
  • micro09 Jun 26, 2009
    Hi Rylee Smith,
    Thank you for your advice. I 've replaced the resistor near the STK IC'c and it fixed the problem; However, there are some problem with the bottom left and right corners has double image and I could not align. Also when High definition (HD) was use for bout 10 minutes and the TV turn OFF.
    Please give me advice. Thank you very much.
    Tom
  • 3,267 Answers
After going through the details of items you have already replaced but still have a problem with red convergence, my advice is not to try any more experimentation should be attempted after changing the 2 ic's, because from now on it will be a trial & error method to rectify it and in this process you might damage a important item, it would be best to change the auto convergence board. period........sodeep
Posted on Jun 26, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Have you replaced the resistors connected near the stk IC's as they are also required to be replaced. This voltage diffrence is due to the resistors which are needed to be replaced with same valued resistors. Please tell me the color bands on the resistor and i'll tell you with what resistance value you'll need to replace them.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 14, 2009
  • Rylee Smith
    Rylee Smith Jun 26, 2009
    TOM
    If you have already checked the STK ICs then it is definetely the convergence board that has gone bad and needs replacement.
    Thanks
    Rylee
  • Rylee Smith
    Hi Tom
    There is a common power supply problem with these that requires the replacement of four capacitors on the power board. This could be causing your problem.
    Thanks
    Rylee
Phillips lcd tv model 42pfl7662d/05 set turns on have sound but no picture
Hi.
The problem is the inverter, the psu, or the main board. Repair is done checking power to the inverter.
Please let me know if you need more info on the problem.
Regards.
Ginko.
Mar 08, 2011 | Philips Televison & Video
I neea flyback for plat tv phillips
Hi Ritchel,
You may look online, try ebay.com and shopjimmy.com for the replacement. just type the model no. of your unit to the search engine and the available parts of your model no. will be displayed. You can also look at your local electronics supply.Bring your original flyback as much as possible.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 02, 2011 | Philips TV Tuner Video Capture PCI Card -...
My 60 inch Phillips Magnavox Rear Projection Tv will not turn on and there is a wheezing sound coming from inside it.
Hi
Thanks for using FixYa. Wheezing sound can be caused due to many reasons however, to start with open the back of the unit and check the power supply board for any blown capacitors. Also check the flyback as it can be some loose wires in the coil. Usually this happens when there is a vibration in the horizontal circuit, the flyback and/or coil can make this noise. The flyback can also go bad and cause this issue, opening the unit is only recommended if you have some electrical expertise. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 28, 2010 | Televison & Video
My cat threw up on the back of my tv
sounds like the LSB board will need to be replaced as thats the board that produces the operational voltages. The main filter board is good if the led lights.
Mar 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips Proyection-60P8341 from the PTV915 series
those models are famous for the LSB boards going bad and they are hard to track down the cause if the LED isnt blinking. You can get a repalcement LSB for your model at the following link. Leave them a email and they may make you a good deal on one. Heres the link.
http://servicemanuals.vstore.ca/
Sep 30, 2008 | Philips 60P8341 60" Rear Projection...
Phillips magnovax 50p8341
sounds like the LSB ( large signal board) as that has all the various power supplies on it. You can get a replacement board at the following link.
Aug 04, 2008 | Philips 50P8341 50" Rear Projection...
Tv fix
that is usually related to the LSB large signal board will eventually need replacement. Most repair shops will not troubleshoot the LSB at component level, they will opt for replacing the entire circuit board. If you need more info or help to locate a LSB board. please let me know.
Jul 14, 2008 | Philips 60P8341 60" Rear Projection...
PHILIPS REAR PROJECT
Your large signal board is getting ready to to go out, most likely due from a defective flyback. Yiu can get a replacement LSB circuit board at the following link.
Jul 13, 2008 | Philips 55PP9401 55" Rear Projection...
Phillips 60pp935217
I have a phillips HDTV monitor model 60pp935217, i don't get an hd picture but i do have sound. Please help.
Apr 08, 2008 | Philips 60PP9352 60" Rear Projection...
Phillips 43pp920217
On these sets, if your not experienced with this problem I would not try, but you could get the the part yourself and replace it. Call PTS 1800-844-7871 and ask to speak to a tech and he or she could tell you what you need and how to put it in. I just repaired a 51pp9202h/17 and would not want to do another. It has many boards in it and depending on the problem you could only buy another board and replace. Mine went black, I could hear audio but no picture. Thought it was the convergence board but it was the SSB the one with the Flyback on it. So after replacing almost everything I just bought another and its fixed now. So hope this helps
Sep 13, 2007 | Philips 43PP9202 43" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
