Question about Tomtom One Europe v2 GPS Receiver
TomTom One Europe
Bought 2 days ago, TomTom home loaded Ok backed up to computer. Today went to download map update, said not enough memory. Now the screen has frozen on the tomtom picture with a flashing white cross. Tried to back up says error trying to download from the file on theĀ computer. When I ask for details of what is on the TomTom it shows nothing but says Capacity 957.9mb with 1.2mb free. Anyone help please
  • 43 Answers
Re: TomTom One Europe
What is happening is your map updates are being copied onto your memory card without overwriting the old maps hence you are running out of memory.
In the tomtom home browser you should be able to delete your old map before installing the new one. Make sure you have a back up of the map card before you try this though so you can reinstall if something goes wrong.
Also have you replaced the voice prompts on your tomtom? The voice files take up a lot of memory so if you have put new ones one without removing the old ones you will be wasting memory.
There is one window in TThome that lists eveything installed on yuor card so have a good look at this and see what you can get rid of.
Posted on Nov 29, 2007
2 Suggested Answers
  • 515 Answers
SOURCE: tomtom map activation
Im pretty sure that Tomtom provided what you needed, if you did buy the map...
Posted on Apr 10, 2008
  • 515 Answers
SOURCE: I bought US maps and my tomtom one stuck on the first screen.
Tried a reset?
Posted on Jul 27, 2008
0 characters
3 Points
Tomtomcom getstarted
The VIA models act as servers and the map doesnt actually download to your computer. It uploads itself to tomtom servers, gets rewritten and then downloaded back on to the tomtom unit. They have done this to prevent map illegal copying, sharing
Sep 06, 2014 | Tomtom VIA 135 Automobile Portable GPS...
When I turn on my TomTom it says no maps avaible. When I go to load the canada usa maps I just bought it says not enough memory. How can I reset my Tom Tom back to the maps it had.
Since you have just bought it, you are eligible for a new map (within 30 days of purchase). Please update the map as early as possible. Please follow the steps mentioned below:
Tom do not seem to overwrite the existing map file. So before trying to install the map, you need to delete the folder that contains the map. (It is important to read the next part before you delete the map folder). Once you have connected your TomTom to thecomputer, close the TomTom home window. Double click on my computer. You will see the TomTom hard drive as a drive (like you see the CD drive). Double click on that . Once the folders of the TomTom hard drive opens, look for a folder named USA_Canada_and_Mexico_P. (Please note: this name is for American continent. For others, this name will be different). Right click on it. click properties. Check whether the size of this folder is approximately around 1.3 GB to 1.5 GB. This is just to make sure we have the correct folder. After confirming this is the map folder, copy this folder to your computer for back up purpose. Once you have it safely in your computer, delete this folder from the TomTom hardrive. Go back to TomTom home software. Use the map guarantee to update/Upgrade the new map. You will see this time around the installation completes without a problem.
Apr 27, 2010 | Tomtom ONE 140 -S Car GPS Receiver
I tried to update my tomtom go live 750 inthe mid of installation it says no enough space then i canceled after that my device shows on screen no maps found i bought the device end of december 2009, any...
In the Memory slot at the bottom of your TomTom (Go 750) insert a 4GB MicroSD memory card and download Europe 2GB from your TomTom update. It worked for me Good luck !!
Jan 21, 2010 | Tomtom GO 750 LIVE GPS Receiver
Down loading Europe on my TomTom 1/3
Yes you can I have europe and canada on mine.
just plug your tomtom into your computer and start tomtom home
On the computer screen for tomtom select ADD MAPS
Here you can select and buy the maps you need.
Once you have confirmed the purchase you will be given instructions on how to download etc
Some maps may take a little time to install to the tomtom itself.
you should also ensure there is enough space on your tomtom
If not you will have to get an SD memory card.
I use a 4gb one that still has lots of room to spare
Jun 07, 2009 | Tomtom ONE 3rd Edition GPS
Tom tom Western european map
This problem is due to the memory card not containing the TomTom application or map. To update the application onto the memory card
  • Connect the device to your computer.
  • Open the TomTom Home application.
  • Click on 'Update My Device'.
This should then install the application onto the SD card. Alternativly, you could perform all the steps above without the SD card in the device, this will install the application onto the internal memory. Note: you may also need to install your maps, voices, etc after you updat.
Feb 24, 2009 | Tomtom One XL GPS Receiver
Tomtom One T Europe version 3
You can back up all your current maps and install North American maps for Florida using TomTom Home. You can switch back to European maps when you get back to the UK as well- I used my TomTom Home to manage my GPS and I find it can be very useful in situations like that
Nov 08, 2008 | Tomtom One Europe v2 GPS Receiver
One xl europe software
Software updates are free, maps are not.
To download software updates, you need to download Tomtom Home, and connect tomtom to a computer.
Download Tomtom home here: TomTom, portable GPS car navigation systems
To get maps click here.
Oct 02, 2008 | Tomtom ONE GPS Receiver
Upload latest western europe map v7.20 to TOMTOM 700 not possible
I have managed to solve the problem of loading a new map on my Go700 using a Mac. I discovered that Tomtom is incompatible with the Leopad operaying system, despite the protestations of the idiots at Tomtom ,so I reverted to an older Mac using Tiger.
Taking the instructions given to crinold, I tried to erase the disc on the 700 using home 1.5 - and it didn't work. So I went to disc utilities, highlighted and erased the Tomtom disc, and opened home 2,5. After being refused entry several times, like being told to load an already loaded device, I persevered, and managed, slowly, to add the map I had bought for 78 euros. T]One point oif interes is that when I bought the map, they site stated it would cost 63 pounds sterling, but switched it to euros when the invoice arrived. at a rate very favourable to Tomtom - funny, that.
This is sharp practice,probably illegal in many countries,, but, to be honest, dealing with the mysterious Tomtom company is so frustrating, that I don't have the time or inclination to fight them for the money they cheated from me.
How they survive with such an awful product and extremely bad after sales service is hard to understand - perhaps they won't ... we live in hope.
Jul 11, 2008 | Tomtom GO 700 GPS Receiver
Tom tom one xl wont accept SD card with map on
If you have TomTom that have the slot for SD card, then it should accepted the SD card. The instruction for how to use the SD card is simple, but it is hidden in the TomTom Home, that's why it's difficult to find it. Below are the instruction how to use the SD card.
1. Format the SD card (FAT32) and do not stick the SD in the slot yet
2. Run Backup (connect TomTom device to computer)
3. Disconnect TomTom from computer and turn off
4. Slide the SD into the slot and connect TomTom back to computer (choose "yes")
5. In the TomTom Home menu, Choosen Backup & Restore >>> and choosen Restore
TomTom Home will add all applications to the SD card. So the internal memory still have the applications and the SD card also had the same applications. Everytime you slide the card in, TomTom will automatic detect and use it as its primary storage, if it not detect, you can go to the device menu and pick the device to connect to.
Whenver you take the SD card out, then TomTom will use its internal memory.
Hope this helpful
Apr 24, 2008 | Tomtom One Europe v2 GPS Receiver
No maps found on tom tom one new edition
this problem just happened to me. i'd just bought my new tomtom one and tested it on the journey home. all was well and i was really impressed. that was until I got it home and went to update it to get the latest maps for my area. I installed all the software as instructed by the on screen prompts and downloaded the latest updates. i then went to turn the device on, and was greeted by a message stating ''no maps found!''
after almost two hours of complete frustration, i then tried probably the easiest solution anyone could think of:
First of all, connect the device to your computer and close down tom tom home. (making sure it isn't even open in the system tray).
Now, open my computer and find the device. it will be labelled as a storage device (mine was drive G). Open it up and find where the maps are saved to. Something like, UK and Ireland, or something similar relating the place you live. Once located, delete them manually.
Now, reopen tomtom home and go to tools. Click ''use latest map guarantee''. It will then download the maps again and install them onto the device.
Next disconnect using the option 'disconnect device'' from the device menu.
Finally turn on your tom tom if it doesn't automatically, and you should be back in business. This worked for me, after trying numerous way more complicated solutions I found in various forums.
Hope it works for you too!
Nov 24, 2007 | Tomtom ONE GPS Receiver
Tomtom One Europe v2 GPS Receiver Logo
204 people viewed this question
Top Tomtom GPS Devices Experts
Martin Murray
Are you a Tomtom GPS Device Expert? Answer questions, earn points and help others
