Question about Pyle PCAU44 - PCAU44 Amplifier - 120 W Rms - Usb
Balance is about 18 DB higher on the left channel. I have only used the USB port for playing MP3s
I could not find a schematic to see if I could fix the problem myself. (There is no balance control accessible on the outside)
Skip channel function not working coreectly
db:: 4.90::Fios tv VMS1100 skip not working correctly k3
www.hivmr.com/db/k37cmjfzkk71s913ksf3j7xfxsz3zc37
DB:4.90:Fios Tv Vms1100 Skip Not Working Correctly k3 ... Pressing Play on the remote has no effect, but changing the channel fixes everything. ..... The functions Skip Forward, Skip Backwards, Next Chapter and Previous Chapter all skip ...
The Secret Method to Skip Commercials with One Button on ...
Dec 28, 2015 | Televison & Video
After I downloaded songs onto my mp3, when i turn it on it says "GPX" and wont let me do anything else. It wont even turn off. what do i do?
db:: 4.22::why wont my songs play on my mp3 player ax
www.hivmr.com/db/axxs1akj89ss7zs8zmf11d9kmzzj33fa
I download my music, extract the .rar files then take the new folder that has the.mp3s and ... Is there anything i can do to convert the songs to play with the MP3 player? .... LIST ONTO A CD AS AN MP3, BUT I TUNES WONT LET ME AND SAYS ALLSONGS ..... DB:3.37:Nomad Muvu Cannot Format And Mp3 Wont Turn On 37.
db:: 4.31::mp3 player wont play f7 - Hivmr
www.hivmr.com/db/spxap11fkpmm9jss18kz9skc8c8mj977
I have an mp3 player which is usually good but for some reason wont let me ... Howdo I download Itune songs in a format that will play on my mp3 player? ... on Windows 8 after it has been copied to your new computer, or the MP3 can't play the music. .... my stereo will play the songs from Itunes if i burn them onto a CD-R..
MP3 write protect removal - Forums - CNET
Dec 28, 2015 | GPX Audio Players & Recorders
I bought a used car and it already had a kenwood kdc-x890 installed. my question is when i plug my zune or even just a mp3 player into the usb port it responds with [n/a data].
The KDC-X890 will play MP3s that are stored on a USB mass storage device, such as a USB thumb drive. It won't play music from another MP3 player such as a Zune through the USB port, but you could plug your MP3 player into the auxiliary jack.
Mar 04, 2011 | Kenwood KDC-X890 CD Player
My problem is when I connect my iPod to my head
That usb port is not meant for an ipod it was intended for a usb flash drive with mp3s on it. if you want to use your ipod you will need to get a interface mod, i believe the model number is jvc KS-PD100.. it should have it listed in your manual or you can call up jvc to confirm.
May 01, 2010 | Car Audio & Video
My 360 does not play my mp3's
if you are trying to play your mp3s through the usb port via a ipod ect the newest update from microsoft stopped all this because of people playing games ect via large usb hard drives that were plugged in via usb ports, it wont help you any but at least you know why!
Nov 17, 2009 | Microsoft Xbox 360 Arcade
Owners Manual for Kenwood Car radio Model KDC-M4527
KDC-M4527
CD Receiver with WMA/MP3 decoder Built-in
Audio Features
- 4 x 50 watt maximum output power by MOSFET Power IC
- 1 RCA preout, 2 Volt
- Separated tone control: Bass/Mid/Treble
- Source tone memory
- Balance/Fader/Loudness control
- System Q: Sound control with pre-programmed tone curves
- Auxiliary input with optional unit (CA-C1AX or KCA-S210A)
- Attenuator (-20dB) with smooth volume return
Tuner Features
- 24 presets: 18 FM, 6 MW/LW
- K3I clean reception Tuner
- Radio Data System (RDS) with Radio text
- Auto memory entry (AME)
- Up/Down seek tuning
- Local Seek
- FM Stereo/Mono selector
- Tuning mode : Auto1/Auto2/Manual
- DAB reception with optional unit KTC-9090DAB
CD Features
- CD-R/RW compatible
- 8 times over-sampling
- 1 bit D/A converter
- S/N ratio: 105 dB
- Dynamic range: 93 dB
- Channel separation: 85 dB
- MP3 decoder with ID-3 Tag display
- MP3 decoder MPEG-1/2 Audio layer-3
- WMA decoder: windows media audio
- CD-text
- Random/Repeat/Scan Play
Changer Features
- Dual changer control capability (CH1/CH2 & AUX)
- CD-Text with compatible units
- Disc Name Preset System with compatible units
- Disc & Track repeat
- Disc & Track scan
- Disc & Magazine random play
General Features
- Removable faceplate
- Protection case for faceplate
- Disabled System Indicator (DSI)
- Mono Colour LCD display
- 14 segments x 8 characters
- White LED display backlight
- Selectable key illumination (red or green)
- 24 hours clock
- Auto Dimmer
- 2 way telephone mute
- All off select (20/40/60 min.)
- Built-in fuse/coil
- ISO A/B connector
- Remote sensor for optional remote control unit
- OEM steeringwheel remote hardwired connection
thats the most i could get go here http://kenwoodusa.com/Contact/ and have them send u one hopw that helps.
Oct 01, 2009 | Kenwood Car Audio & Video
I have a jvc kd-g720 stereo in my car and when I plug my iPod into the usb port it says "do not disconnect" and even though i have about 2,000 songs on my iPod the stereo will only play the same 49 ones in...
if you are plugging your ipod into the usb port of the kd-g720 it won't play all your songs because this particular radio only plays mp3s through the usb port. ipods play both mp3s and mp4s. so those 49 songs you're hearing are the mp3s on your ipod. in order to play all the songs on your ipod you must buy the cord that plugs in the back of the radio that will connect to your ipod. sorry for the bad news man. i had the same thing happen to me.
Sep 01, 2009 | JVC KD-G720 CD Player
Proton 520 Integrated Amplifier with quiet left channel
Hi...
Flush all the switches and controls with De-Oxit D5 or better.
Then get back to me.
Thanks
Feb 02, 2009 | Audio Players & Recorders
Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Mar 18, 2008 | Samson C01U - USB Studio Condenser...
Hi, my sansa e250 has sound come out of only one head phone no matter how many headphones i try the same happens
The jack in the e250s is not made of adamantium, so it can actually go bad; however, if you try different headphones and thus determine that either:
  - All the headphones simultaneously went bad in one side
  - Your left ear has issues
  - The Sansa is only cranking out one channel; and
     -the jack feels a little off, or
     -perfectly good mp3s are being played off-balance; AND the balance has not been misconfigured in Settings.
...well then, the plot's moving forward and you can get your ear fixed, or stop the cat from killing your headphones, or re-load Sansa or Rockbox.org firmware, or fix the Settings, or see to the appropriate repair to the jack (depending on your warrantee status and skill with soldering irons and ordering off Jameco.com etc.)
Feb 21, 2008 | SanDisk Sansa e250 MP3 Player
Pyle PCAU44 - PCAU44 Amplifier - 120 W Rms - Usb Logo
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
