Question about Coby KCD150 UndertheCabinet CD Player with AMFM Radio
Coby kcd150 wont operate
Nothing works on it. have a power light that is it
Cd drawer does not open
This could be very simple to repair. They are usually driven by a small belt which has either snapped or fell off.
Dec 15, 2013 | Coby KCD150 UndertheCabinet CD Player with...
Eject button not working
That indicated you have a jammed gear in the tray mechanism. You might be able to unjam it by taking the cover off and manually running the tray out (with the unit unplugged!), putting the cover back on, plugging it back in... but more than likely you will need to buy a new cd player.
Dec 15, 2013 | Coby Under-the-Cabinet CD Player with...
The CD don't working properly
your optic laser is probably dirty.you need to open this device up and clean the eye as they call it its a lens looking circle clear eye.You have to be very very carefull as you could make your problems far more worst that they are at the moment.You can use a q tip to do this dnt use any chemicals u can use peroxide though with a q tip or soft tissue
Dec 19, 2012 | Coby KCD150 UndertheCabinet CD Player with...
My Coby LEDTV-2426 24 No Power
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 19, 2012 | Coby LEDTV2426 TV
My coby tftv3229 wont turn on and I've only had it
If its two weeks old why are you here? Take it back to point of purchase and either have it fixed or replaced or get a refund.....
From the brand you likely are in UK but here all sets come with some kind of warranty==the problem sounds like a power supply issue but if you have a warranty and open the set it will void that warranty.
Apr 11, 2012 | Coby Televison & Video
My coby kyros won't turn on, won't charge, no lights are coming on
Mine does that to but all I ever do it just hit the reset button on the back and it turns back on.
May 18, 2011 | Coby Kyros 716829701508 Tablet PC
Were is the reset botton?
From the manual there is no reset button but here is a link for the manual- http://www.cobyusa.com/files/manuals/KCD150_MN.pdf
May 07, 2011 | Coby Kcd150 Shelf System
It on a red screen it on but wont go any were
All mine does is flash the word coby on and off and wont do nothing else.
Jan 20, 2008 | Coby MPC-848 MP3 Player
Coby KCD150 UndertheCabinet CD Player with AMFM Radio Logo
475 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
