Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Bizhub c253 Transfer belt fuse fix - is it a slow or quick fuse, 800mAh that I am supposed to use?
  • Konica Minolta Master
  • 1,297 Answers
Quik fuse but not 800mA if 80mA!!!You can use every rapid(quick fuse 50-80mA.
Posted on Mar 25, 2014
nchalabe
  • 4 Answers
SOURCE: Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Posted on Jul 09, 2009
SOURCE: howto fix internal error c - 1183 on bizhub c253
C-1183 - Finishing option elevator drive malfunction
Posted on Aug 23, 2009
  • 158 Answers
SOURCE: I have a BizHub C253 and the data light just
most common cause for this is the hard drive in the copier is malfunctioning and needs to be replaced or data clear needs to be done in service mode
Posted on Oct 03, 2009
  • 51 Answers
SOURCE: Bizhub C253: Error Code C-4551 will not clear.
open front door and switch-off machine
press utility buton hold press-on then swietch-on machine, on the screen right top corner u see dot (remove finger from utility buton)
after fue second u will see trouble reset touch under u will see ok switch-off machine wait 10 sec and switch on
If the error code still is on the machine u have to change cyan laser
Posted on Oct 09, 2009
  • 158 Answers
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Posted on Nov 16, 2009
How do I replace the fusing unit in Konica Minolta bizhub C253
POWER OFF MACHINE! Open the front door remove one screw from the small access UPPER RIGHT cover disconnect the three connectors two carry 120 VAC other sensor signals the open the right side of the machine two screws below the fuser and remove the unit. reinstall opposite direction. Be careful not to brake the sensor connector
Apr 11, 2015 | Konica Minolta Office Equipment & Supplies
My printer fuser and transfer belt did not open with error code c2152 i tried to reset the printer but not still working pls what can i do
PROBABLE CAUSES:
1. Detecting Plate not positioned properly.
Shape of the detecting plate has been modified. Install the modified Detecting Plate (p/n A02E 5033 01). Please refer to the attached procedure for
instructions on how to install the modified bracket.
Note :The following are the serial number cut-inswith themodified Detecting Plate installed:
bizhub C353 - A02E010005899 and onward
bizhub C203 - A02E012005777 and onward
bizhub C253 - A02E011005566 and onward
bizhub C353P - A02E013000060 and onward
magicolor 8650 - no cut-in available
2. Transfer Belt Retraction Sensor (PS31) mounting bracket (p/n A02E 1121 00) is fixed with a screw and it can be tilted while assembling. If the bracket is
tilted, the sensor cannot detect the Transfer Belt position properly. In order to avoid tilting the bracket, the shape of the bracket has been changed.The shape of the sensor actuator has also been changed because the actuator could touch the other parts.
PARTS
A02E 1121 00 -current Bracket
A02E 1121 11 - modified Bracket
A02E 1122 01 - current Actuator
A02E 1122 12 - modified Actuator
Notes :
a.When at the machine, please check the condition of Sensor Bracket and change the Sensor Bracket and Actuator if necessary.
b. Please refer to details in attachedBulletin Number 6252 (applies tobizhub C203/C253/C353).
3. Somepacking material was not removed froma new Transfer belt before installation. Ensure that allpacking material has been removed before the Transfer belt is installed.
4. Failure of the Transfer Belt Retraction clutch (CL7).
Check for wiring being pinched from bypass door and replace the failed parts.
PARTS
CL7 (p/n A02E M200 00)
bizhub C353 Drive Wiring/1(p/n A02E N10F 02)
bizhub C253 Drive Wiring/2 (p/n A02E N117 02)
bizhub C203 Drive Wiring/3 (p/n A02E N10Y 02)
bizhub C353P Drive Wiring/4 (p/n A02E N11A 00)
magicolor 8650 Drive Wiring/6 (p/n A02E N11C 00)
Mar 16, 2015 | Konica Minolta Minolta Bizhub C353 Copier
Door stack on konica minolta c 253
Did some one install a new unit such as a transfer belt or transfer roller? Or a fusing unit? Recommend a technician look at it unless you want to yank it open and do some more damage?
Sep 01, 2014 | Konica Minolta Bizhub C253 Copier
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Is generic RAM suitable for Bizhub?
Yes, the RAM modules are in fact laptop modules. It will work from one type of machine to another, as long as you are using the same specs (as frequency, etc).
If you need anything else, just drop us an email at office@bizhubreset.com
Also, please visit our websites, we're sure you'll find useful things there
Aug 13, 2014 | Konica Minolta bizhub Office Equipment &...
Desbloquearla para seguir trabajado gracias
Replace the transfer belt. open close front door to reset
May 17, 2014 | Konica Minolta Bizhub C253 Copier
What is the solution of error c-2152?
Check the transfer belt. Ensure it was inproperly installed no one for got to remove the tape ??
Apr 21, 2014 | Konica Minolta Bizhub C253 Copier
What is error c-2152?
The transfer belt check for proper installation
Picking wrong color at printing
check that the two sensor that monitor the color registration on the transfer belt are clean, located under the transfer belt. need to remove the belt to get to them
Apr 03, 2014 | Konica Minolta Bizhub C253 Copier
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
66 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
