Question about E-Machines emachines (emachinees) CD-ROM Drive
Cd drive not reading disk
Updated drive but problem remains
  • E-Machines Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard.
If this does not fix the problem it might be a registry problem
"you only need to do the following"
if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and typeregedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computerOpen My Computer and check to see if your CD or DVD drives have returned.
You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if this fails to fix the problem It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it
http://www.nextag.com/dvd-lens-cleaner/shop-html
http://www.infopackets.com/news/hardware/2005/20050315_clean_cd_or_dvd_rom_lens_with_a_brush_part_2.htm
Posted on Mar 27, 2014
My cd rom drive does not read disk
This problem could be solved by updating the firmware. I have tried to find a reputable firmware update from the manufacturers site but have only come across them for that drive supplied by laptop manufacturers.
Who manufacturers your computer , is it a laptop and what model is it?
Dec 21, 2010 | LG CRN 8245B (CRN-8245B) Internal 24x...
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
Device- SONY CD-RW CRX320EE It is detected by the OS(Xp-64bit). Device Status- working properly. Disks(any type) when inserted not detected . More over i can access the drive when i double click it even...
make sure it is not a DVD disk you are trying to insert into your Drive because your Drive is a CD-RW will not read DVD nor burn onto it.
Your disk may be damaged or corrupt and the drive cannot read it.
your drive may need a firmware update from Sony.
use this link below to access Sony's website to download drivers.
here is the link:
http://sony.storagesupport.com/
Jul 17, 2009 | Sony Computers & Internet
Dell Inspiron E1505 CD/DVD Drive reads only dell disks.
If the driver didnt fix your problem, your disk drive might be faulty , maybe the problem is on the disk drives lens this is very common problem 2 any other cd/dvd rom drives.
Jun 26, 2009 | Dell Inspiron E1505 Notebook
LightScribe DVD SuperMulti Drive/CD-Writer won't read disks. It has been cleaned and passes all tests. Has read these disks before, but file will not load from disk.
check and see if there are updated drivers and install them. have you changed your Operating System via upgrade or anything.
May 26, 2009 | HP PAVILION A6230N DESKTOP PC
MY CD/DVD Disk drive will not read anything
Physically take out the drive and reseat it back into place. Then turn the laptop on and go into your bios by pressing F2. If the cd drive shows up in the BIOS then that means the system is seeing it properly. If it doesn't show up in the BIOS then that means the drive is bad and needs to be replaced.
If the drive shows up in the BIOS then reboot the laptop and then once you get into windows try different dvds and cds in the drive. If it reads them then problem solved. If it doesn't read anything then go ahead and clean the laser of the cd drive with a damp q-tip. Clean it and then try different discs again. If it still doesn't read anything then the drive at that point is definitely bad and the drive would need to be replaced.
Jan 26, 2009 | Toshiba Satellite A200-0ET00X Notebook
Hi, I'm still unable to update the xbox 360
your probably not doing anything Wrong.
did you boot the console then eject the draw, and put the update disk In ?
it should read the disk, then tell you it,s an update, and ask you if you want to update the console.
Make sure your hard-drives connected.
The only other thing i can suggest, is to make sure your 360 reads the disks or media your using.
if you try burning a music cd, and see if the 360 recognises it, you,ll know the media or Blank CD/DVD is good for the 360 to read. another method is to add a dummy file of about 80-100mb.
this ensures the 360 sees the disk.
try different media/disks and different methods.
if it still does,nt work for you. mail me your e-mail address and i,ll forward you 1 already made.
regards Mike @ compurepair.
Oct 06, 2008 | Microsoft Xbox 360 Console
DVD-RW not recognising blank disk
Did you try a DVD firmware update? Some dvds need new firmware to reconize some DVDs
May 30, 2008 | Computers & Internet
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
56 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
