Question about Dell OptiPlex GX620 PC Desktop
Buzzing noise whenever boot up/login/search/open/downlosd
  • 259 Answers
Motherboards use signals a radio signals to communicate across them. Some on board soundcards pick these signals up. Try purchasing a better sound card. This might eliminate some of those on board noises you are hearing. Hope this helps.
Posted on May 05, 2014
Altea tailgate
try an internet search, VW and SKODA use the same parts so search for these makes as well triple yours chances of finding one
May 18, 2014 | 2010 Seat Altea 1.6
Boot will not open on ford c max
the release solenoid is stuck and trying to work. Lubricate and/ or adjust the latch mechanism
Mar 14, 2014 | 2008 Ford Focus C-Max
Acer computer won't boot has long buzzing noise
The long buzzing sound indicate the nature of the problem. Depending on the manufacture of your bios will determine the problem. With only one long beep you may have memory problem. The computer cannot initiate the boot sequence. Did you add any devices to the computer prior to your problem. if you did undo what you did. Make sure the computer is on, if nothing happens ( no lights, no sound, no fans etc.) the computer has a power failure. Make sure you listen to the beep if it is a numerous beep sequence note it down and check the web for computer beep during boot up.
Mar 25, 2012 | Computers & Internet
Whenever I use one of the cleaner amp models i get an aggravating buzz. The buzz only occurs when I play and is not constant. (The buzz is not there when I'm not playing). At first I thought my strings...
Try moving your guitar around and oriented differently as it MAY be picking up magnetic fields from equipment in the area. Some pickups really are sentive to interference.
The effects for modeling MAY have a noise gate that requires a certain signal level before unmuting which would explain why you have to be playing to open the gate and hear noise that is really there all teh time but muted.
Dec 27, 2010 | Line 6 POD HD500 Amp Modeler and Multi...
I recently bought a Vizio television Model Number Vizio e370vl and I have been experiencing a buzzing background noise whenever I have sound coming through the tv speakers. Be it my satellite reciever...
Exact same problem, buzz was not overwhelming but non theless there. Tried antenna, dish, dvd, another persons house and buzz remained.Complained to Vizio, tech cam out and replaced mainboard I think it was. Bahm,its fixed. Would have tried returning to Walmart but figured another new onemight buzz as well. Tell support line you always have the buzz no matter whatthe input (dish, antenna, dvd player). Windings in power supply coils have air gapsthat create the buzz I read somewhere. Good Luck
Nov 04, 2010 | Televison & Video
(1995 vw passat) central locking doesnt work just buzzes
Your central locking pump in the right rear of boot area behind light cluster may be faulty but if not check the rubber pipe between each door, open doors wide and in the big black rubber boot is the small rubber pipe.They perrish and cost peanuts to replace from any car parts shop.Do all doors regardless as one worn means all will go soon also.
Oct 13, 2009 | 1995 Volkswagen Passat
Mbox2 mini digidesign buzzing
Are you running passive speakers if so try using a ground loop isolator this should stop any noise interferance.
Jan 22, 2009 | Digidesign Mbox External Sound System
Noise coming from power supply
When we turn our TV the humming and buzzing begins! We cn mute it and it goes away and then it when we turn the sound back on the sound is back! How can we fix this?
Sep 18, 2008 | Polaroid FLM-323B Television
Front door buzzing Frigidaire front loading washer
replace entire door lock assembly ..remove spring holding the door boot in place and roll boot back ..unless you have the one where the seal is glued then carefully slide knife under edge to cut through glue take the screws from lock and pull through opening remove wires and install new lock ..if noise is only issue use till it blows then replace
Jul 30, 2008 | Frigidaire FWT449
Phone makes a low buzzing noise whenever try to talk on it
to change the buzzer,the microphones,clean-it and hot it
you can ask -me by address:
adamaf 1947@yahoo.fr /+225 0645 4954 IN COTE DIVOIRE.
Jan 14, 2008 | Motorola Mobility L6 Cellular Phone
Dell OptiPlex GX620 PC Desktop Logo
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
