Question about OKI B4600 Printer
On-printer Auto is not print
Panasonic KX-P7110 printer won't print from the auto feed tray, shows error when printing is attempted.
Please check the entire length of the paper feed path from input to output for a small piece of paper that is stuck causing a "Paper Jam".
You are lucky that you can still print manually as this usually shuts a printer down until the jam is found and removed!
Good Luck!
Rich Lilja
Jan 06, 2014 | Panasonic KX Office Equipment & Supplies
Phone call automatically prompts fax response
if U have manuals remove auto answer in settings or set auto answer after 5 tones
Dec 29, 2013 | Oki Printing Solutions MC362W LED...
LQ 300 +2 auto pause during printing
This is a feature provided by the manufacture to protect the print head overheat for small dot matrix printers. Here giving printer head connection diagram, the last two row have temperature sensing (thermister) connection pin 1 to 1. If the thermister is faulty in the print head the printer will auto pause abnormally. Check the printer with compatible / EPSON recommended print head. These kind of small printer only for POS printing not for continues printing. 2_17_2012_8_31_04_am.jpg
Feb 16, 2012 | Epson Dot Matrix LQ-300+II Printer
How I can solve auto printing when I start HP laserjet 1020
how could I manage the auto printing in laser jet 1020??How could I delete the past setting printing from it's propertise??
Oct 13, 2011 | HP LaserJet 1020 Printer
Hummer sound and one page print an then stop printing
There could be a wide range of caused for the problem being seen, a few things worth trying are;
Try printing the HELP page on the printer, this is a menu page and will demonstrate if the printer can print ok, if the printer prints the HELP page correctly the problem is likely to be 'data related'
The help page gan be printed in the following way;
  1. Place the printer OFFLINE
  2. Press the MENU button
  3. Press the DOWN ARROW repeatedly until HELP is shown of the display
  4. Press ENTER
  5. The printer should then print out a menu page containing a number columns of settings.
If the printer prints the Help Page Correctly this strongly suggests the problem is data or settings related.
It may be worth trying printing from another system / application to see if the problem may be related to one document or system.
Some settings you may wish to check on the printer are;
Emulation -Ensure this is set to match the host system setup
Auto LF- You may need to turn Auto LF (auto line feed) on if the system is only outputting Carriage Return Commands and no Form Feed Commands
Bi-Dir - If the printer is connected via the Parallel Interface you may need to disable Bi-Directional communication for the parallel interface.
Further investigation may need to be carried out to identify the cause of the problem
If the printer is not able to print the help page, this indicates a hardware problem with the printer.
If the printer prints the help page but not the document, this indicates a Driver / Settings / Communication type problem which requires investigation.
Mar 29, 2011 | TallyGenicom 6306 Matrix Printer
What's a 016-799 error code mean?
016-799 Wrong combination of print parameters, like selecting to print on custom size paper and setting [Auto] for [Paper Source] on the printer driver and [Auto] for [Paper Size] in trays 1 to 4 on the control panel.
Check the print parameters.What we did is match the documents page size and paper type to the printers (A4) then we could print.
Oct 04, 2010 | Xerox WorkCentre 7328 Multifunction laser...
Drum light stays on after replacing
C- Auto- C -Auto . 24 Print, 07 Print , then press CCC three times.
Pls? try so that)
Dood luck!
Sep 15, 2009 | Sharp AL-1642CS Copier
Printer does not come out of the Manual color setting
When printing tell printer to use color space sRGB.
let printer determine color.
see if that works.
Mar 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Double side printing issue with HP 2420
Try to default on your page setup.
May 23, 2008 | HP LaserJet 2420 Printer
Printing a tiled document from InDesign
you have check the tile option in print dialog box and select auto justified. now the printer will print tiled documents.
Apr 12, 2008 | HP Photosmart C3180 All-In-One InkJet...
OKI B4600 Printer Logo
19 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
