Question about Canon PowerShot A570 IS Digital Camera
Canon powershot "A570 IS" is dead I'm looking for location of fuses on pcb
I jacked a non standard 9v DC adaptor into my camera by accident and now my camera is dead. i want to replace fuses corresponding to the problem,but i don't know where are those fuses.I like to know are there multiple fuses or not and where are they?
    New Friend:
    Problem Solver:
  • 8 Answers
Cameras do not typically have fuses for protection as they have specific batteries that will not damage the pcboard in the camera. If any components were damaged you would probably need to have it replace.
Posted on Dec 01, 2014
SOURCE: Uploading pictures form canon powershot sd500
i need heip
Posted on Oct 12, 2008
  • 383 Answers
SOURCE: How do I use the self timer on my PowerShot A570 IS camera? Please help...
Press the Center Button
By pressing the center button on the four-way controller, you'll open up the Function menu. This menu has the following options:
  • ISO speed (Auto, High ISO Auto, 80, 100, 200, 400, 800, 1600) - see below
  • White balance (Auto, daylight, cloudy, tungsten, fluorescent, fluorescent H, underwater, custom) - see below
  • Drive (Single-shot, continuous, 2 or 10 sec self-timer, custom self-timer)
  • My Colors (Off, vivid, neutral, sepia, black & white, custom color) - see below
  • Flash compensation (-2EV to +2EV in 1/3EV increments) + flash output (1/3, 2/3, full) - this last item is only available in manual mode
  • Metering mode (Evaluative, center-weighted, spot)
  • Compression (see chart later in review)
  • Resolution (see chart later in review)
The Third Option is Having Self Timer ..... Check
Posted on Oct 14, 2008
BillB-SA
  • 2761 Answers
SOURCE: My Canon PowerShot A570 IS wont turn on and it was
Your problem is likely due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be due for replacement, or the camera may have a problem that requires professional repair.
Posted on Dec 05, 2009
t00nz
  • 4738 Answers
SOURCE: Digital Camera CANON PowerShot A410-No VOICE Record
I'm sorry to tell you, but the PowerShot A410 model does not have a microphone to record voice. Of all the A400 models, only the A410 and A420 were made this way. For some unknown reason, Canon decided to not include micorphones wiith these two cameras, thus they can only record video, but no voice.
Posted on Dec 25, 2009
rommelalilin
  • 2178 Answers
SOURCE: hi- my husband was playing with
There is a switch on the side of the memory card and is very tiny to find. Set it in the opposite direction - unlock.
Posted on Jan 21, 2011
My canon powershot "A570 IS" is dead I'm looking forlocation of fuses on pcb
I'm afraid you are looking for a thing that is not in the camera. There are no fuses in a camera. Sometimes electronic equipment has a diode, to prevent damage by connecting the wrong way around (reversed battery or so) but a fuse in a camera? no!!
Mar 23, 2014 | Canon PowerShot A570 IS Digital Camera
Where are locations of fuses on a570IS board
See my answer for the same question earlier.
Mar 23, 2014 | Cameras
Hello experts, witch main pcb is built into Canon Powershot D10? Canon-repair told me main pcb and jack pcb assy have to be changed after corrosion. i found jack pcb assy for change but i couldn`t find...
Your camera is run by a program that is loaded onto the main board when it is replaced. This program is not available (Canon considers it propriety information) so the only way you could replace the main board would be with a used one (that already has the program installed) pulled from a salvage camera. However, this program also has color correction information and dead pixel information etc for the image sensor in the camera. You would have to replace the sensor from the salvage at the same time so that it matches. It would be cheaper to buy a used camera - check Ebay.
Sep 02, 2013 | Canon Cameras
PowerShot A570 IS- accidently erased pictures and video by resetting settings to default. Want them back, haven't taken pictures or video since I made the mistake. Thanks!
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones.
Oct 24, 2010 | Canon PowerShot A570 IS Digital Camera
My Canon PowerShot A570 IS won't turn on. I put new batteries in and checked the memory card. What else can I do?
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
May 19, 2010 | Canon PowerShot A570 IS Digital Camera
My Canon powershot A570 is will not turn on, have tried new batteries and still will not work
get a new camera...this camera sucks...wasted tonnes of money on new rechargables...just didn't last long for more than 50 shots each battery change...after that, it couldn't turn on after connecting to DC input....just get a new camera and chunk this away....
Jul 03, 2009 | Canon PowerShot A570 IS Digital Camera
Battery problem
Remove stain from batt. location , spray it WD40 inside batt. compartment then use NiMH batt. enelop white color
Jun 17, 2009 | Canon PowerShot A570 IS Digital Camera
Canon powershot a570
Well, no matter you photos in Canon camera got deleted, formatted by accident or became inaccessible due to camera memory card errors. Chances of recovery is possible as long as you take the right action.
Take a try of this software to recover Canon photos, Not only general photo formats, but Canon RAW photo formats (.cr2 or .crw) can be retrieved easily.
Note: before the photos are recovered, Never should you attempt to take more photos or save more data to the memory card in case chances of photo recovery might be reduced. Hope it helps. Regards.
May 17, 2008 | Canon PowerShot A570 IS Digital Camera
Canon PowerShot A570 IS Digital Camera Logo
89 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
