Washing machine is malfunctioning LG 1068QDP2
  • 957 Answers
How is it not working you have not said anything that is wrong.
Posted on May 31, 2014
How do i repair start/pause button
you dont try to repair it if you do it your board may be comletely or partially gets damaged which may cause malfunctioning so u better contact to your near lg store
Jun 02, 2014 | LG WD-1280FHD Front Load Washer
Lg wm2801hla starts fill with water but that it it gives a humming noise
What age is it?
My guess is that the solenoid valve is malfunctioning. They are usually pilot operated, so they usually shut off on failure.
Oct 03, 2012 | LG Wm2801hFront Load Washer wm2801hla
LG WM2277HB start button won't start cycle
Either the button is damaged or the switch it operates is malfunctioning.
Suggest you get a Technician to pop in and check it out while there is still plenty of life left in the machine!
Poppa
http://www.cdbaby.com/cd/poppamadison
Sep 23, 2012 | LG WM2277H Front Load Washer
When i start program de keeps coming up
'de' on LG machines normally stands for Door Error - it thinks the door is not closed properly. This means that either the interlock requires adjustment, if that is physically possible on your machine, or the sensor is malfunctioning.
Whichever it is requires a service engineer, sorry ;-0(
Good luck,
John C
Feb 28, 2011 | LG Washing Machines
My Lg washer is showing a code UE and then PF what can I do to fix this problem.
UE means that the load is unbalanced in my LG. The code PE means that the water sensor is malfunctioning and needs replacing.
Feb 13, 2010 | LG WM-2277HW Front Load Washer
FE code on LG Tromm washing machine, what is this code?
Hi. this code represents a faulty water valve. I would shut off the tap and inspect the water valve assembly inside the machine. If dissembling this machine is a problem and you are uncomfortable with the disassembling process, i recommend a quick service call. the water valve may have a malfunctioning solenoid.
please rate and god bless.
Mar 24, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
MY fridgadaire lg washer says loc and wont let the door lock and machine start
That is a door lock malfunction, check the lock and wire harness connections.
Oct 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Seal malfunction
First obtain a replacement seal from your local domestic appliance parts dealer. Remove the top from the washing machine. Undo the straps or screws holding the old seal on. Replace the seal reverse of removal. Hope this helps!
Oct 07, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
