Question about Sunbeam Microplush Electric Heated Throw Blanket Lagoon Blue
I washed my electric throw now the remote just blinks , and it doesn't get hot
The remote just blinks on high
Kenmore Elite Mod. 66513922K010: Complete light keeps blinking. It had a leak, but is fixed. Now how do I clear the blinking light?
Press (one after the other):High Temp, Heated Dry, High Temp, Heated dry. You can also try throwing the breaker (at the house breaker box) for 5 minutes to see if that clears the problem.
Jul 20, 2016 | Kenmore Washing Machines
I bought the INGOLF dining room chair from Ikea a few months ago. There is a padded cushion on the seat that can be removed and washed. Is there a specific way to wash the cushion or can I just throw it...
The Ikea website offers washing and care instructions for this specific product. The instructions are as follows: machine wash in hot water (140F), do not bleach, do not tumble dry, iron at high temperature.
Aug 09, 2012 | Furniture
Front Loader W'pool # GHW9400SUO throwing codes F/H. I know it means water inlet, but can't seem to figure it out. I have changed both hoses. They are free and clear, but only runs for a minute...
hi ,,inside the water vavle theres screens unplug unit stick a little screw drive in each vavle,,,hold up to light to see if clogged,,,if clogged wash out and replace...good luck
Sep 03, 2011 | Whirlpool Washing Machines
Just replaced the battery remote will NOT work.... I have a very high ceiling.... this is getting annoying.... when I press the remote I get a red light wether I ask for fan or light.... light just blinks...
Some remotes have a learn button in them, when it lose its power you need to relearn it. Hold the small button for about 5 seconds, to reprogram it with the receiver. If it doesn't work ,then your receiver may need to be replaced.
Sep 03, 2011 | Hunter Ceiling Fan Remote Transmitter...
My KUDS011JBSO undercounter dishwasher is blinking the normal wash light. What do I need to look for to fix this?
Hi
If light is blinking then it may be an issue with heater circuit, door switch or the thermal fuse, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the thermal fuse located on the control or the door switch that is bad and should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | KitchenAid Dishwashers
How do i disassemble the fabric softener dispenser? already popped off of agitator
This softener cup doesn,t come apart.The easiest way to clean it is to throw it in the wash cycle with rags and hot water. Then from here on use less softner . Mix it 50/50 with water.
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Sunbeam Microplush Electric Heated Throw Blanket Lagoon Blue Logo
452 people viewed this question
Top Sunbeam Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Sunbeam Garden Expert? Answer questions, earn points and help others
