Question about Euro-Pro Shark S3901 Shark Lift-Away Professional Steam Pocket Mop - S3901
Remove bottom plate on Shark Professional Vacuum
Remove bottom plate to get access to beater bar
2 Suggested Answers
VacuumRepair
  • 438 Answers
SOURCE: I need a new roller bar or beater brush for
Hi There,
Here's a link to that part on our website if you haven't found it already:
Euro-Pro Shark Infinity NV30, NV31 Bagless Upright Roller Brush Assembly
Also if you need belts for this machine, here's another link to the belts on our website:
Euro-Pro Shark Replacement Belt Set For Shark Infinity Upright Models, Part 1085F
I hope that this information helped you. If it did, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand corner of the repair.
Thanks again,
Chris J.
GoVacuum.com
Posted on Apr 14, 2010
SHARK NV90 VACUUM BEATER BAR DOES NOT ROTATE - WHAT IS MY PROBLEM?
Most beaters are driven by a rubber belt driven off a shaft from the motor. Check this is in place, and wrapped around both the shaft and the beater bar (they can break). If this is OK, try to move the bar by hand- it may be jammed by fibres, hair, or other material that has wrapped around the bar. If this is the case, cut along the fibres and remove.
Oct 15, 2016 | Shark Vacuums
Shark navigator making strange noise. Still have suction, doesn't make noise when beater bar not moving. What could be the problem?
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator vacuum is only making a strange noise when the brush roll is turning then the two things to consider and examine would be the brush roll itself as well as the belt.
First off lets look at the brush roll itself. Right off the bat is there any noticeable debris caught in it? You're mainly looking for long carpet fibers, or even strands of hair? If so try using a scissor to cut the blockage away. Then, manually rotate the brush roll to uncover further clogs. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll entirely. There should be two screws holding the plate onto your Shark Navigator. Use a screw driver to remove these screws to gain access to the brush roll and belt.
The second part to check would be your Shark Navigator's belt. With use the belt will stretch out, lessening the tension on the brush roll. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that. A general rule would be that you're going to want to replace your belt about every 6 months. And if your belt is really loose this could be causing a noise when your brush roll is active.
You can purchase your replacement parts for your Shark Navigator direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=Shark+Navigator&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Nov 26, 2014 | Shark Vacuums
Why isn't my brush turning
Hello, Put the vacuum on side and take the screws out on the plate, holding the beater bar. This will expose the belt and motor and the beater bar, so you can see if the belt is loose or broken or the motor isn't turning.
Jun 01, 2014 | Shark SV60 Hand Vacuum, Cordless
Beater bar is not working
Shark Rotator Troubleshooting - YouTube
? 10:35
www.youtube.com/watch?v=H_dovG2javs
Oct 23, 2012 - Uploaded by VacBin
I show you how to fix common problems with the Shark Rotator..... I have Shark Rotator Prof Liftaway and ...
Feb 01, 2014 | Shark Rotator Professional Bagless Upright...
Beater bar stopped turning after bottom plate removed
The beater bar is powered by a lever and pivots on a point - you either broke the pivot point or disconnected the lever.
Take out the bottom plate again and, using a flashlight, try to locate the problem.
Jun 22, 2013 | Miele S7000 S7210 Twist Upright Vacuum...
Why won't brushes move on Commercial Carpet Pro Vacuum Cleaner
Luvumuch48tj:
Unplug the vacuum and lay it upside down on some newspaper. Remove the sole plate (bottom plate) with a screwdriver. Pull straight up on the brushes (called a beater bar) and remove the beater bar and belt. Remove the end caps and bearings from the ends of the beater bar (it may take a 2-grunt pull, or CAREFULLY pry the end caps and bearings from the beater bar with a screwdriver) Don't stab your hand with the screwdriver... That HURTS! Once you have the bearings and end caps off, remove the hair, carpet fibers and other gunk from the ends of the beater bar, end caps and bearings. Dribble a little rubbing alcohol on the bearings in the end caps and spin the bearings to clean them... keep dribbling alcohol in the bearings until the alcohol draining from the bearings is clear. Dry the bearings until there is no alcohol in them. Now would be a good time to check the opening in the vacuum head and the hose going into the body of the vacuum for clogs. Reinstall the bearings and end caps on the beater bar and reinstall the beater bar with a new belt in the machine. Reinstall the sole plate. Your machine should run like new.
Feb 15, 2013 | Carpet Pro CPU-2T Commercial Upright...
How do yu change the belt
Hello. W/D here.
On the baseplate that surrounds the beater bar, you'll see three large plastic screw heads. Turn these and youll feel the plate loosen. Raise the plate from back to front; it hinges toward the front. This gives you access to the beater bar. Remove the beater bar, making mental note as to how it comes out. You want to pay attention to the ends so you can get it back in easily. Remove whatever remains of the old belt. While you have it opened this far, inspect the suction cavity behind the beater bar; this is where they are most likely to stop up over time. Also take a moment to inspect the beater bar and remove the things that tend to wind up on the bar and at the ends. Slip your new belt over the motor shaft, and then slip the beater back under the belt. It will be tighter going back with the new belt. While the belt is on the motor shaft and the beater bar, slide the beater bar back into the sockets of the vacuum, and replace the base plate.
That's all there is to it!
Best regards, --W/D--
Aug 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum won't pick up any dirt - there's no roller marks when vacuuming carpet. Roller does turn and filters are clean.
When you turn the roller, you should feel some resistance from the belt. Remove the base blate that surrounds the beater bar. Check the belt. Take care in removing the beater bar, so you can get it back in the same way it comes out. Clean the beater bar while you have the bottom open. If you remove the beater bar to replace the belt, take the time to inspect the cavity behind the beater bar where the vacuum picks up. That is where vacuums usually stop up. Reassemble the vacuum. If necessary, slip the belt over the motor shaft and then slide the roller undre the belt. Install the beater bar back in the sockets and replace the base plate.
Best regards,
--W/D--
Aug 12, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Hoover U6476-910 - Very little suction from the bottom
If you haven't already, remove the beater bar. This is accomplished by unplugging the vacuum and turning it beater bar up. Remove the clips or screws that hold the plate on the beater bar and set aside. The beater bar sits in sockets, so carefully remove the bar, noting the correct position of the sockets. This will make reassembly much easier. Slip the beater bar out of the drive belt. Now, inspect the suction cavity that the beater bar would discharge into. Usually, things clog up here as there is a flex hose that catches things, creating a pluggage.
Hope this helps, --W/D--
Jul 18, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
Belt
Hi. This isn't a hard repair at all.... Unplug your vacuum. Turn the vacuum beater bar side up. Locate the catches or screws that hold the plate on that covers the beater bar. Remove the plate. The beater bar sits in sockets where it attaches to the vacuum, so remove carefully, making note how it comes out. This will make reassembly much easier. Place your new belt on the motor shaft, then onto the beater bar while you replace the beater bar back into the sockets. Test your work by revolving the beater bar a bit by hand. Reinstall the cover plate. That's it!
Regards! --W/D--
Jul 17, 2009 | Bissell 6594 PowerForce Bagless Upright...
Euro-Pro Shark S3901 Shark Lift-Away Professional Steam Pocket Mop - S3901 Logo
42 people viewed this question
Top Euro-Pro Televison & Video Experts
Electro Med Services...
Are you an Euro-Pro Televison and Video Expert? Answer questions, earn points and help others
