Question about Maytag Centennial MEDC400VW 7.0 Cu. Ft. Electric Dryer - White
Will not start
Light does not come on, timer does not start dryer--- power to unit is good
  • 171 Answers
Please check door switch and wiring
Posted on May 22, 2014
Whirpool Fronload Dryer has power, timer cycles through, but it is not running. The dryer worked two days ago when I ran a load. I went to dry a load this morning and it turns on, everything lights up...
The reasons can be a fault on the program controller unit but as the door does not close the program also will not move further. This must be the clue to the fault. Remove and check the lock and the settings. manually close the door with force and see if the program cycle starts, if not check the door switch and the control panel. Also check for output when the timer counts down. If not the controller unit must be checked for possible problems.
Nov 14, 2011 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool Model WED5540SQO Type DWJR-ELE-2406026-FM54 It has been running fine, today wife dried a load of clothes and folded after buzzer went off. Filled dryer, closed door and the unit would...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 06, 2011 | Whirlpool Dryers
I have a Maytag Dryer that has a twist knob selector that you push to start the dryer. The dryer stopped producing heat and then the knob would no longer start the dryer. The light inside went out at the...
Has the Timer gone bad? check the connections to the dryer because the timers sometimes die, make sure to turn of the power and unplug the unit form the wall.
Mar 25, 2011 | Maytag Dryers
Hello my 70 series kenemore is not getting warm and the timer is not completing the cycle to turn the dryer off it just keeps running for hours
I would need a model number to better narrow the problem down for you.
If this is a gas dryer
Remove the lower panel. With the lower toe panel removed, start the dryer & watch the igniter. If the igniter glows & cuts off without lighting the gas this would usually indicate the gas valve coils are weak & will need to be replaced. For this type of repair be sure to disconnect the electrical power & turn off the gas to the dryer. If the timer is set in the auto dry cycle, it will not advance if the dryer is not heating. Once you repair the dryer, the timer should start advancing. It is possible that your old timer is good. If you need further assistance please resubmit your question.
If this is a electric dryer
The timer not advancing from 50 minutes in time dryer & the unit not heating are not related unless 1 leg of the 240 volt supply is lost. Diagnosing a problem like this will require using a volt/ohm meter. With the timer set to time dry you should be getting 240volts to the timer motor & 240volts to the heating element. In the wiring diagram provided L1 comes from the timer on R & goes through the thermal cutoff, oper thermostat & the hi-limit to provide 120volts to 1 leg of the heating element. The L2 leg goes through the motor switch to the other side of the heating element. This is how the element gets 240volts. The timer motor gets its voltage on BK from L1 & OR from L2; this is what advances the timer.
Jan 12, 2011 | Kenmore 700 7973 Dryer
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
The dryer does not start
Unplug unit, ohm out door switch, check that belt is good. Make sure you have 220 to plug.
Oct 01, 2009 | Dryers
GE dryer Model DWXR473ET2WW . Dryer does not start. Timer is not moving either, but it is receiving power (light still goes on when door is open)
To prevent a fire this unit has a fuse mounted on the rear of the dryer located on the dryer heater pan. GUIDE
Jun 25, 2009 | Dryers
Dryer won't start
does it have drum light ?if so is it working ?if not and bulb is good raise top by pressing clips at each corner on back is heating element.. on element case is thermal fuse with 2 white wires it could be open part# la-1053 ( i think)..if light is on but still no operation possible timer or door switch
Sep 18, 2008 | Dryers
Mdg7400aw natural gas
THEY HAD TIMER PROBLEMS WITH THE PULL TYPE.MAKE SURE DOOR SWITCH IS GOOD ALSO
Jan 14, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Centennial MEDC400VW 7.0 Cu. Ft. Electric Dryer - White Logo
73 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
