Question about Atari Test Drive Unlimited 2
When I click play on the UpLauncher, nothing happens.
As I said in the title, When i click play on the UpLauncher, nothing happens. I have Open: FullCone Nat Type and the servers are available. My computer can handle it. Also, in the task manager, TestDrive2.exe is under processes. Help! I want to play with my friends.
Analog audio signal applied to "line input" jack on audio card produces no audio out (Dell 8300)
Ok, i'm not sure what version of windows you are running but on my windows xp machine I right click on my volume icon (little speaker) on the right side of the start bar on bottom of screen. Then click 'open volume control' , This will open up 'play control' window. In this window you now want to click 'options' in the upper left corner and select properties from the drop down menu. This will open up a second window titled 'Properties', near the top of this windows there is a section titled 'Adjust volume for', under this select the 'Recording' option. This will change the list of volume controls to your computers audio inputs. Make sure the input you are trying to use has a check mark next to it then click 'OK' on the bottom right of the 'Properties' window. The 'Properties' windows will close and the Play control window will now have the title 'Record control'. Make sure any inputs you want to use are turned up and there is a check mark next to the 'Selected' check box under the volume bar for each input. This should fix it for you. If you are using a different version of windows let me know what Windows you're using and i'll post a followup for you with the correct instructions. Good luck!
Dec 30, 2013 | Dell XPS 8300 Desktop
Memorex mvdp 1085 dvd player, says door open.
our memorex 1085 doesnt play it just buzzes and has a blue screen
Jan 09, 2010 | Memorex Televison & Video
My pc wont open football manager 2009 disk
click on the diskdrive that fm is in once to get the pop up menu and click on open auto play and then click onto open folder and in that folder there should be the application to install football manager 09
Jul 04, 2009 | Video Game Consoles & Games
Can't Install Agatha Christie Triple Murder
I had this problem as well, but I discovered the solution in good time. First, put in the disc, but don't run it. Next, go to My Computer and right click on the disc, and click explore/view files. There should be four folders, three of which are titled "motoe", "euts", and "attwn". In all three of these folders, there is a file titled "setup.exe". Open that file on all of them to install the games.
Jun 08, 2009 | The Adventure Company Agatha Christie: And...
Iriver E10.....wont play songs
well it seems you deleted your songs but not the titles. weird huh but that happened to me too. so hook it up to your computer, go to " my computer", and then right the icon that is your device, and then click format and that should take care of that.
May 28, 2009 | iRiver E10 Digital Media Player
The CD Rom that came in this Dell Dimension 310 has problems.
CDROM,??? PEOPLE STILL USE THOSE ,
U CAN BUY A BURNER ON LINE FOR LESS THAN 25 BUCKS
Apr 19, 2009 | Dell Dimension E310 PC Desktop
Mp3 will not play
When you installed the songs all you installed was the title. I had this problem with my rca pearl,
you must downlad the song and not just the title of the song o.k.
Try again with the whole song.
when you put your cd's together put them as a playlist
Feb 25, 2009 | Sears TGE MP3 Player
IPod stopped and won't recharge.
By pressing Menu and the centre button together the iPod was reset. I got this solution on Google.
Jan 06, 2009 | Apple iPod nano
Finalizing DVD
If the size of the vhs recording was in 2hr mode, and the size of the recording itself is about 2 hrs, you may not have enough space to finalize. I would use your PC to finalize the disc - I use Dr. Divx, but you can find many finalizing programs out there.
Sep 04, 2008 | Zenith XBR413 DVD Recorder
Atari Test Drive Unlimited 2 Logo
Top Atari Video Game Consoles & Games Experts
Hanzu
Reggie brown
Nikki  Mclean
Nikki Mclean
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
