Question about Bosch Benvenuto TKN68E75UC Coffee Maker
I have a clog that i cant seem to get rid of
I have cleaned with tabs, i have have removed front drip head and cleaned very well and still have a clog and all water is going into bottom tray
2 Suggested Answers
  • 1214 Answers
SOURCE: clogged dishwasher arms
Our Bosch has a round knob in the center of the arm, under the basket. ROtate it 90 degrees, and the arm drops away and can be cleaned.
Posted on Jan 16, 2009
GE tbx25pa has horrible smell. We have cleaned EVERYTHING!! Took back off of inside freezer, removed front grill, cleaned all coils underneath and was nothing in what I'm guessing is the drip pan.
The drain pan under the refrigerator next to the coils you cleaned but you have to access from the back pour some bleach into to get rid of the smell
Feb 25, 2014 | Refrigerators
Keurig drips too slow
The exit needle is located on the inside bottom of the K-Cup Holder. If coffee grounds or cocoa mix gets clogged in the exit needle, it can be cleaned using a paper clip or similar tool. Remove the funnel from the K-Cup Holder, insert the paper clip into the tube and move it around to loosen the clog and remove any debris. Please note, you cannot poke all the way through the needle as the opening of the needle is located on the side and not the top.After cleaning, align the K-Cup Holder tabs with the opening placing the two front tabs on the bottom and the single tab on top and snap it into place by pushing down on the top rim.
Aug 28, 2013 | Keurig K-Cup Keurig OfficePRO Single-Cup...
WATER COMING OUT OF HEAD UNIT when air con. on
May be normal. Mostly likely this is condensation that spits out of the head units of most AC units.
Mar 08, 2011 | Heating & Cooling
New ink no print
Hi Good day!! Try to do a printer maintenance
Cleaning a Clogged Print Head
1. Press the cleaning button located on the front of the printer. Hold it down for 3 seconds to begin the cleaning cycle.
2. Run a cleaning cycle using your Epson printer utilities program. In Windows, go to "Start," "Printers and Faxes," right-click on your printer and choose "Printing Preferences." Select the "Utility" or "Maintenance" tab, depending on your printer model, and click "Head Cleaning." When the head cleaning cycle is complete, run "Nozzle Check." Repeat the head cleaning and nozzle check one to three times.
3. To access the Epson printer utility in OS X, select the Epson Printer Utility icon in the Applications folder in Macintosh HD. If prompted, select your printer from the Printer List, then click "OK."
Clean the print head manually. Remove the ink cartridges from your printer according to the instructions in your owner's manual. Turn off your printer. Dip a cotton swab in isopropyl alcohol, ammonia or hot water and rub the swab against the print head. Let the printer sit overnight.
Remove the print head according to the instructions in your owner's manual. Soak the print head for at least an hour in a small dish of hot water or isopropyl alcohol.
Preventing Clogged Print Heads
1. Use your printer at least once a week. Regular use will keep dried ink from clogging your print heads. If you have a color inkjet printer, print full color pages in addition to black-and-white documents.
2. Turn your printer off when not in use. This will prevent warm ink from bleeding onto the print head. If you have to store your printer, remove the ink cartridges.
3. Use a cleaning kit regularly. A cleaning kit usually includes a tube of ammonia that you spray on the printer head to clean dry ink.
Thank you for using FixYa
Please accept if my solution helps you
Nov 18, 2010 | Epson Stylus C84 InkJet Printer
The fabric softner chamber seems to be clogged because after a wash it is full of water.
The fabric softener chamber is likely full of crud and or mildew.
  1. Pull out the detergent / softener tray (press down on the tab in the back to get it all the way out). Take it and wash it as well as you can.
  2. Now, pull the washer out enough that you can get to the back of the machine.
  3. Unplug the washer!
  4. Remove the four screws holding the plastic tabs (at the top) on the rear of the machine.
  5. You should now be able to remove the top cover of the machine - slide it back and then up.
  6. There are four small hoses connected to the back of the detergent tray, and one large hose.
  7. Take a marker / tape / etc. and label these hoses 1,2,3,4 - write the corresponding number on the top of the detergent tray so you will know where to hook them back up!
  8. Using pliers, squeeze the tabs on the small clamps to loosen them enough to pull them back about an inch on the small hoses.
  9. Pull the hoses off, gently.
  10. Use a phillips head screwdriver to loosen the clamp on the large black hose. Pull it off.
  11. You may want to loosen the other end of this large black hose and remove the hose for cleaning. Mine was nasty.
  12. There is a black bundle of wires snapped into the sides of the detergent tray. Take this bundle out of the clips so it hangs loose.
  13. Remove the two screws from the front of the detergent tray. These are on either side of the opening and are usually hidden by the detergent drawer.
  14. Now, you should be able to slide the entire fabric softener tray back and out of the machine.
  15. The tray comes apart into two pieces - gently pry the tabs on the sides to separate them.
  16. Clean everything! If anything is too nasty / clogged to clean, buy a replacement part.
  17. Reverse steps to reassemble and good luck!
Apr 29, 2010 | LG WM-2277HW Front Load Washer
Epson 4800 pro
Make sure that the "Encoder Strip" is clean and in the channel for the sensor located on the back side of the printhead carriage.
Jan 06, 2009 | Epson Stylus Pro 4800 InkJet Printer
I have a sony handycam - dcr-pc109e. When viewing a tape, there are grey horizontal bars across th screen that have just appeared. I cannot seem to get rid of them. Any ideas please?
Gray horizontal lines appears when video heads in camera got dirty / clogged.
Use good quality video cleaner cassette to clean video heads, problem will resolve.
Dec 16, 2008 | Cameras
Issue with front loader going through spin cycle
you can try removing the lower acess panel(2 screws along the bottom of front) behind the panel youll see the pump assy mounted to the right, disconnect the hoses and check for debris in the hose assy. the machine will not spin if it cant get rid of water, and it cant get rid of water with a clogged hose. very commom.UNPLUG UNIT FIRST PUMP WIRES ALWAYS LIVE!!!!!!!
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Black text d not print
If the printer has been left for some weeks with an empty black cartridge then I suspect the print head is clogged.
To clean the print head, firstly remove it.
Remove each cartridge quickly and turn it upside down so ink does not drip out.
Flush warm water with a drop of detergent through the metal meshes at the bottom front inside of the print head unit. Continue untill the water coming out of the bottom of the print head is clear.
Then flush through with clean warm water for about 30secs.
Shake as much water as possible out of the unit.
Replace the cartridges quickly to avoid ink dripping out.
Undertake a nossle (head) clean on the printer until printing correctly.
Hope this helps.
Jul 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Ghd30y7 goldstar dehumidifier
We came home to this problem the other day, water all over the basement, leaking out the bottom left side, nothing in the collection basin but plenty would spill out if I tipped the unit forward. After searching the web and these forums I theorized that the coils were frozen. I let the unit thaw. No luck. I removed the faceplate and discovered thick, wet silt had filled the internal collection plate and was clogging the drain. I stuck a pipe-cleaner through the drain and the problem was fixed. Took some paper towels and cleaned the whole thing. Works like new. I assume the unit will need to be cleaned regularly to keep it going. To remove the faceplate, unscrew the two phillips' head screws under the faceplate along the sides, then take a flat head screwdriver and pop the tabs holding the face on, one tabe along each side. There are also two tabs on top, but you don't need to mess with those, as they simply act against gravity. Whole thing just clips back together after cleaning. I have no idea if this voids the warranty.
May 21, 2008 | Goldstar DH304 Dehumidifier
Bosch Benvenuto TKN68E75UC Coffee Maker Logo
103 people viewed this question
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
Oloyede Monsuru
ray gallant
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
