Question about Dell Computers & Internet
Whenever i start my PC red lines and boxes appear
I am using windows xp and i have checked my PC with another monitor and stll it has red lines so there is a problem with the pc.
  • 52 Answers
Are you sure its not your LCD?
Posted on Mar 25, 2014
Testimonial: "Yes I am quite sure"
  • Filip Kunsten Jun 03, 2014
    Do you have a spare video card to test with?
Laptop Screen Shows vertical Red lines on Grey Color on random Spots
Check the cables. It might be overly simplistic, but if your monitor is connected via a serial cable, one of the pins might be bent or missing. This can cause slight display problems, including a vertical line. If you are using a USB, try another cable and see if the problem persists. Update your video card driver. Some discrete cards have an update feature in the properties window for the device. Right-click on your video card in the programs list, and select "Properties." The update will be a button under the "Drivers" tab if your device is so equipped. If not, visit the manufacturer's website and search for the most current driver for your model number.
Updated video drivers could solve the problem. Place a box fan directly behind your computers intake vent for extra cooling. Sometimes if there are system problems, your components can run too hot. If cooling the computer takes away the line, you know have you an overheating problem, not a monitor problem. You might try cleaning the internals with canned air. Remove the housing, and thoroughly blow any dust, hair or carpet fiber away from the fan and off the mother board. While you're there, you can check to see if there are any obvious loose connections. Connect the monitor to another computer if you have one available. This is probably the most definitive test of your monitor's health. If you have a line when the monitor is connected to a different machine, it's likely time for a new monitor. As frustrating as it sounds, taking apart one of today's monitors in an attempt to repair it is more expensive than buying a replacement. If you don't have another computer available, try shutting down the computer but leave the power on to the monitor. Using the buttons on the monitor bezel (if you have them), call up the settings. If the line appears in the menu just as it did in the video from your computer, then you definitely have a monitor problem. Replacement is probably in order
Dec 10, 2012 | Computers & Internet
Not in line error
thamk you for the reply. I went into msconfig then BOOT.INI and ticked the basevideo box.
cheers
Mar 25, 2009 | Computers & Internet
Windows script host settings
first try windows update
if that don't work right down exactly what script it is then
click start then run type in msconfig
then a box will appear click on startup
then find the program click to remove restart computer then click don't show message again
Jan 16, 2009 | Computers & Internet
My D & E drive is not opening on double click.
parental control pin codes for the box so the new codes can be installed
Dec 28, 2008 | Computers & Internet
Display problem in windows xp
Make sure the drivers for both monitors are installed. Update the driver for your graphics card. Hopefully this will fix your problem. Good luck.
Dec 22, 2008 | Microsoft Windows XP Home Edition
Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
Yellow lining problem
Turn on your PC, press CTRL-ALT-DEL and check on the tab processess if ehtray.exe is running. Ifso, kill it and see if the line disappears. do not remove the file, it is part of windows media player but known to cause problems, click here for more information and how to remove it from start up.
Aug 01, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
How to change the resolution of Acer AL1702Wb 17
On windows XP and earlier :
1. Right Click the desktop
2. Click properties
3. go to settings
4. the resolution slider is there. Try different resolutions untill it looks good.
Feb 21, 2008 | Computers & Internet
Black lettering has red or green highlights
Try turning on cleartype if you are using Windows XP. 1. Right click on the desktop and select 'Properties' 2. Select the 'Appearance' tab and press the 'Effects?' button 3. Check the box for 'Use the following method to smooth edges of screen fonts', then select 'ClearType' in the dropdown list 4. Close the Effects dialog by clicking 'OK' and click 'Apply' to complete the process
Jun 19, 2007 | Samsung 906BW LCD Monitor
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
