Question about Worldwide 1997 Dodge Stratus 2.4L Alternator - 90 Amps
Name of the hose
I am trying to find the name of the hose that goes from the air breather to the right side of the valve cover
So what is the name of the hose and the part that connect to the valve cover?
Posted on May 15, 2014
Tube from air filter to engine???
Blow by hose,valve cover to air filter.
Jun 15, 2013 | Cars & Trucks
Missing an air hose that goes from the air breather to ? what is it called?
if its about as big as your little finger in diameter it may be but if its an inch or larger its a manifold heat tube that comes up from the exhaust shroud on the header pipe which is used to preheat air on really cool days.. its usually around a foot long and flexible(bendable) and made from flexhose..parts store sells by the foot if needbe..its like an exhaust patch..they will know when you tell what car it is..(normally)
Jan 22, 2013 | 2000 Mercury Sable
What is the part name for the hose on top of my Protege DX valve cover?
Just the hose or the PCV (not pvc) valve? The hose is probably a dealer-only item - go to the Mazda parts department w/the broken piece and they'll get you a new one. The PCV is avl. @ most auto parts stores - and is cheap - <$20.
GL,
Td
Oct 08, 2012 | 1993 Mazda Protege
I have a 2003 Toyota Camry with the 4 cyl eng., I was changing the air filter and a hose that was attached to the rear right of the filter housing snapped off. I have been trying to get the part...
Is it a large hose going into the valve cover? If so, it could be a breather vent hose or part of the p.c.v. or e.g.r. system. These systems are sometimes tied into the air cleaner assembly.
Mar 15, 2011 | 2003 Toyota Camry
Replacing valve cover 3.0 1998 dodge carivan
For the 1998 Dodge Caravan 3.0L:
This is the same for all 1996 thru 2002 - 3.0L Engines
The Breather hose on the front cover goes from the Valve Cover to the Air Filter Casing.
The PCV hose on the rear cover goes from the Valve Cover to the Intake Manifold.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Apr 29, 2010 | 1998 Dodge Caravan
There is a puddle of oil behind the throttle plate in my 97 land rover discovery.why? there is a breather hose that goes from the valve cover to the mantafold plenum is there supposed to be a pcv valve or...
My 96 Discovery has a plastic baffles inside the valve cover port that connects to the hose. If it got brittle and cracked, then oil could leak by. Its cheap and easy to replace, along with the hose. There is a second hose on the other side to replace as well. Land Rover was proud to pass emissions standards without using exhaust gas recirculation (EGR). The whole system is sealed, so all the air entering the engine is being metered by the Mass Air Flow (MAF) sensor, unless your breather hoses crack and leak. Unfortunately, oil in your location might also indicate other engine trouble, such as worn piston rings (causing pressure in the crankcase). I would try replacing the plastic baffle piece first.
Aug 30, 2009 | 1997 Land Rover Discovery
What is the name of the part that is attached by a hose to air filter
If it's the small hose connected between the breather element inside the air cleaner pan and the PCV valve, it's called the breather hose.
Jul 01, 2009 | 1986 Dodge Ram 50
Carburetor
It is located between the Intake Manifold on the engine and the Air Breather, which is under the seat. To remove, turn the fuel shutoff valve to OFF. Remove the fuel supply hose from the carb; it may help to leave it in place on the shutoff valve. Loosen the hose clamps that connect the carb to the Air Breather and the Intake Manifold. On the right side of the bike, you will have to remove the cover and cables for the throttle control. The cover should be held on by two small screws. The cables will come out of their grooves, but you may have to work at that a bit.
Nov 10, 2008 | 2000 Honda CA 125 Rebel
Can't find the name of a hose.
this is the breather or the pcv hose....... im leaning to the breather hose.......
Oct 10, 2008 | 1994 Dodge Intrepid
Worldwide 1997 Dodge Stratus 2.4L Alternator - 90 Amps Logo
29 people viewed this question
Top Worldwide Electrical Supplies Experts
jhnolson
wadingriver
wadingriver
ka4iup
ka4iup
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
