Question about Amana Washing Machines
Will start to run but turns a few times then stops
The washing machine will start like it is fine turn two or three times then stop like it is end of cycle
  • Amana Master
  • 5,323 Answers
Possible bad motor windings
Posted on Apr 11, 2015
  • 13 Answers
SOURCE: Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Posted on Apr 13, 2009
ghost4548
  • 776 Answers
SOURCE: nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Posted on Jun 30, 2009
SOURCE: maytag bravos washer stops cycle "f" code flashes
This isnt really a solution because Im having the same problem. The repair man that came said that is buildup of soap in the water line. I use my own powder soap, not h/e, and its not desolving and getting built up in the lines. Im not sure what to do to get it to stop doing this. He suggested cutting back on the amount of soap and running hot water through the lines which I have done for the last couple of days but I still have this problem.
Posted on Jul 03, 2009
SOURCE: Zanussi ZWF16581W Washing Machine
Not helpful as the instructions given in the manual do not work. It may be that they do work at a certain point but they don't tell you WHEN to press them. When the machine has irritated you beyond belief in beeping like a maniac? Before you start the cycle? during the cycle? When? Have tried all of these but to no avail. What am I missing?!
Posted on Aug 04, 2009
  • 21 Answers
SOURCE: unit runs good through wash cycle then while in
Sounds as if the drain pump is not ejecting the water fast enough. Did you notice of the washer is draining more slowly than usual or at all?
Posted on Feb 14, 2010
Why does my 5 year old machine keep stopping mid-cycle?
Check the door sensor and clean it. Or one or more(i believe there are three) of your tub sensors may be bad.
Sep 11, 2015 | Washing Machines
The washing machine will start turn a few times add some water but then stops and the light flashes
Sounds like unbalanced now - try to rebalance the adjustable knobs under the washer - we have to rebalance every few months because our floor isn't the straightest. We always know when its time because the washer won't work right.
Mar 23, 2014 | Amana NFW7300WW Washer
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Hi, good evening. I have a zanussi iz12 washing machine that stops during rinse node and gives e20 fault (wont drain). I checked the pump - working fine. I've found that if i blow into the waste pipe the...
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Jan 11, 2010 | Zanussi IZ12 Front Load Washer
Won't stop filling, water just keeps running into washer even after agitation starts have to turn water connection off to stop filling
check to make sure the control knobs are turned to exactly small -med -or large - if it's in the middle of say med and large loads the water will over flow - this happened to us three times (cause of daughter!)
Aug 26, 2009 | Washing Machines
Cold water will only trickle into washing machine
Check your water pressure if thats good check the screens on your hoses, if thst good go to the water inlet valves that allow water into your tub
Jun 09, 2009 | Washing Machines
Hi, my machine starts for a few seconds then stops and pause button wont stop flashing, have tried turning off and on but same thig keeps happenig, please help x
if it is a HE kind of machine it is supposed to stop and start a bunch of times at the beginning of the cleaning cycle. Did you wait for a while to see if it ends up running the cleaning cycle?
the new machines are kind of freaky the way they work.
later
Apr 09, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Won't stop pumping
H android1968 and danimaldds
The reason it keeps running is because there is water in the pan under the dishwasher. firs this to do is shut the power off, then take the kick plate off, remove all the water that you can. this should fix it , if it happens again there might be a leak from a seal or from suds. hope this helps
brent
Jul 29, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Door will not open
On my machine which is identical to this one I have to press and hold the stop button to end the programme and then turn off and unplug the machine to reset it. Following this run a spin only cyle(M) to get rid of the water.
Once the machine has drained and ended the M cycle try the door again. If this fails unplug the machine wait for a few seconds and then plug it in again and turn the program knob to any programme but do not start it running, just try the door it should open.
If all this fails it may be a problem with the contacts for the electrical stage of the door release or a faulty door lock.
Good luck, Al
Nov 08, 2007 | Hotpoint First Edition WMA22 Front Load...
Washing Machines Logo
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
