Question about Acer Computers & Internet
Bios Password help
I have an Acer Aspire 3100 configured by Sultex PC in Kentucky now out of business, I cannot boot from any external device and cannot enter the bios setup to enable that function. It has a Phoenix Trusted Core NB Bios version 1.90. I've tried the backdoor passwords to no avail. Does this laptop have a cmos clear jumper on it or a removable battery or is there a way to identify the Motherboard?
  • 3 more comments
  • Rick StClair
    Rick StClair Mar 24, 2014
    I found the battery and it is soldered.
  • Rick StClair
    I will try to shorting the terminals as I am getting desperate to do a clean install of XP. I was leary of trying that fopr fear of ruinning the battery. Thank you for your help. I will post if sucessful when I attempt it.
  • Rick StClair
    Rick StClair Mar 26, 2014
    No joy on shorting battery terminals, tried serveral different times with no results.
  • rosen84 Mar 28, 2014
    can you unsolder the battery
    you also can brake it but then each time will have to enter the date and time
    Problem Solver:
  • 8 Answers
The cmos battery is soldered on mainboard if you know what are you doing and can disassemble the laptop just short the battery terminals for 1-2 seconds and that should clear all settings here is a photo http://mainboard.en.alibaba.com/product/624925883-213834902/laptop_motherboard_for_ACER_ASPIRE_3100_series_LA_3121P_AMD_NON_INTEGRATED_ATI_Radeon_Xpress_1100_DDR2.html
Posted on Mar 23, 2014
Geekman
  • 32281 Answers
SOURCE: Gateway MX6030 bios/boot password reset
How long did you leave the battery out?
To discharge the BIOS you need to short out the battery contacts, or disconnect the battery for 1/2+ hours.
If this does not work the it is near impossible to remove because the password would be stored on an EEPROM chip.
Check with Gateway, they might suggest a motherboard replacement just like IBM.
Posted on Jan 19, 2009
  • 52 Answers
SOURCE: I have aproblem with my Acer Aspire 3100 Laptop
locate the cmos/bios jumper below your memory ddr2 modules (J2) you need to be sure to make contact trought this jumper pe.-with a screwdriver, put back your memory modules and turn on your laptop, this process will clear your cmos/bios memory, you will need to setup your dates.
If this will not work you will need to replace your Mobo because of a faulty, we can replace your Mobo if you are interested:
10001 buckwood ave 79925 El paso tx
contact me if you are interested
support@vcrtech.com
vcrtech@hotmail.com
www.vcrtech.com
Posted on Apr 28, 2009
SOURCE: need password for phoenix bios version 4.0 release 6.0 notebook(laptop)
when i On my laptop IBM t22 it show me phonix bios 4.0 release 6.0 ...what can i do that it shuold be Not show me Agan this message plzz Help me..
Posted on Aug 26, 2009
  • 74 Answers
SOURCE: Can anyone help me on how to reset the Bios
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Oct 30, 2009
  • 102 Answers
SOURCE: How to reset bios password
I fix laptops and when I get an Acer laptop locked with an unknown bios password I use www.unlockbiosrecovery.com to get the bios master password for only $20 which clears any set bios password and they guarantee it to work. I have unlocked a dozen or so Acver laptops with unlockbiosrecovery.com bios password recovery service.
Posted on Sep 01, 2011
0280:Previous boot incomplete - Default configuration used
Error Code: 0280 Previous boot incomplete - Default configuration used
Message Meanings : Previous POST did not complete successfully. POST loads default values and offers to run Setup. If the failure was caused by incorrect values and they are not corrected, the next boot will likely fail. On system with control of wait states, improper Setup settings can also terminate POST and cause this error on the next boot. Run Setup and verify that wait-state configuration is correct. This error is cleared the next time the system is booted.
What does the above mean ??? If the BIOS does not see a particular device loading ( like Hard Drive ) Try bringing up the Bios setting F-2 and reset to default. Hope this helps
BBBB
If one of the BIOS settings is incorrect or if the system is looking for a particular ggggg
Mar 17, 2014 | Acer Aspire 3100-1405 Notebook
How to reset bios password acer aspire 4315 without removing d cmos battery? I ever try to use default password for bios phoenix, but useless. so please help me coz I want to reinstal windows, change it...
Aug 28, 2011 | Acer Aspire 4315 Notebook
No bootable device insert boot disk and press any key acer aspire 5741g. Then I turn on my acer aspire 5741g . This is my problem. Can you help me ?
The notebook cannot detect the hard disk when you turn on the notebook.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty. Next - to check if the harddrive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Aug 12, 2011 | Acer Aspire One PC Notebook
Acer Aspire 5102WLMI \ After booting stps for Password. System does not accept any input . Input rom touchpad, key board, Usb keyboad. No usb port is working. I guess, the power may not be coming to these...
On the Motherboard, set the BIOS Configuration Jumper for pins 2 & 3 to clear the password. Turn on the PC for a few seconds and then power it back down and restore the BIOS Configuration Jumper back to normal. The password is now cleared.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 02, 2011 | Intel D865GBF Motherboard
Acer Aspire One has Hard drive Password frozen
There should not be a password set in the BIOS unless you set it up with one. You can clear the BIOS to BRAND NEW state. Acer can guide you through this if it is under warranty. If it is not, write back and I will help you do this.
Jul 28, 2009 | Acer Aspire One AOA150-1570 Notebook PC
Acer aspire one - its died!!!
If it was just the hard drive, I would expect the video to come on and say something like "no boot device."
However, since you went through the steps here and see absolutely no video (even none on an external monitor), I would suspect a motherboard failure.
Be sure that when you hooked up an external monitor that you pushed the Fn key and the appropriate special function key (maybe F7) that switches between the laptop and external monitor. If you have done that (pushed the combination several times to switch displays), then you can be pretty certain your video card (if a separate card) may be bad.
I'm not really sure if this machine has a separate video card. The specs say it's a ATI Radeon Xpress 1100. This leads me to believe it may be a separate card.
If it's just the card that went bad, you can replace it. Otherwise, the motherboard will have to be replaced.
Good luck. You can do that, but if you're not confident, you best take the machine to a repair shop.
Apr 26, 2009 | Acer Aspire 3100-1405 Notebook
Acer aspire 5315-2698 want to restore to like ner . restall from
If it has a hard drive password, you must remove it before you will be able to restore your OS.
Mar 15, 2009 | Acer Aspire 5315 Notebook
Acer aspire 3100 series
If you where the CMOS battery is, there's beside it a jumper inserted in two of the 3 pins(left pin and middle pin). Remove the jumper from its original position and with it short the middle pin and right pin. This resets the CMOS ROM to its default settings minus the password. Return the jumper to its original position as before. Reboot the computer.
Apr 25, 2008 | Acer Aspire 3100-1405 Notebook
Acer aspire 3003lci forgotten bios password
you will need to disconnect the cmos battery for a few seconds to allow the bios settings to revert to default, reconnecting the cmos battery will allow you to boot up without a password, howver any changes which were made to bios settings will be lost....have you tried pressing f8 while booting, then selecting the option "last known good configuration" ?
Jan 05, 2008 | Acer Aspire 3003LCi Notebook
START UP DISC FOR ACER ASPIRE 1640Z -
What operating System has been installed to your laptop?can you clarify it?you can download support software at ACER,com but startup disk is in windows xp CD or any windows os.you just configure your laptop in the CMOS setup or BIOS by accessing it on the boot up.just configure your laptop on CD/DVD boot media.
Jan 05, 2008 | Acer Aspire 3100-1405 Notebook
Computers & Internet Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
