Question about Mtd Garden
Fails to start
New active 160 fails to start. everything seems to be in the correct position and I am getting a spark,
    Problem Solver:
  • 9 Answers
If you are getting a spark it is probably a fuel problem. If you left fuel in it when you stored it for the winter try "mechanic in a bottle" which is available from lowes, home depot, or tractor supply etc. Just use in accordance with directions on the bottle. If that doesn't work the carburetor will probably have to be cleaned or replaced.
Posted on Apr 05, 2014
Sears tractor cuts out while cutting grass like somebody turns the key off
Could be a failing ignition coil,i have seen a tractor start right up and runs,until the coil heats up from the motor. When this happens the motor dies,do to the coil not producing spark to the spark plug. You didn't mention if the tractor's motor was restarted right after it quit running or was it left until later when you attempted to restart the motor allowing the motor to cool. However,how old is the spark plug? If the spark plug is old,the plug will start failing,do to heat also. I would try a new right type spark plug,make sure the gap is set correctly according to your Owner's Manual. I have found that the gap on some new plugs,not set correctly,when it comes right out of the box. You can check the plug,by turning the motor by hand to see if there is a spark,turn on the ignition switch first(DO NOT USE THE START POSITION) when doing this,the tractor just might crank over,will not start if the plug is out.(But your hand could be injured). Check for a bright spark,if there is one,install the plug then try starting the tractor,in the start position. If you,have checked,what i suggested and everything is good-to-go. The tractor should start and run,like a new tractor. One more suggestion,check the fuel filter,while your down,this maybe or maybe not be the problem,doesn't hurt to check it. Sincerely,Brad Locke. DTD. 12/03/15
Sep 06, 2013 | Sears Garden
My 93 nissan altima stalled while driving and will not start back. put on a new coil, new fuel pump. still will not start. is it the crank sensor or distributor?
First, verify all connections at distributor (both ends of each cable) are securely connected and inspect all lengths of each plug wire to make sure there are no major breaks, cuts, burns, abrasions that would be causing a short. Then, try another plug just to make sure it's not a bad spark/coil wire. If still no spark, then I would say rotor/distributor cap/distributor/ICM module (Ignition Control Module) is the problem. You can generally buy those parts seperate, or you can buy a whole distributor that typically has all combined. The ICM can usually be removed without too much difficulty and taken to an autoparts store for a test, but not always. If you go with the "piecemeal" solution, start with ICM test (if removable), then rotor cap, then move to distrubutor cap. If nothing has worked to this point, you can replace the distributor, but you have already bought everything BUT the actual distributor. It would make sense to price everything seperately versus cost of new distributor...up to you.
If you do replace the distributor, be absolutely sure to mark the position/direction the rotor cap is pointed on old one, so you can re-install the new one in exact same position. Otherwise finding TDC (top dead center) on #1 cylinder is another whole process.
Oct 08, 2012 | 1993 Nissan Altima
Whenever i put my blazer in gear it dies
I'm assuming it's the 2.8, I'm not sure when they started putting the 4.3 V6 in them.
Anyway, a few things come to mind when something won't idle.1. EGR valves. If they are open at idle, it won't idle. It's open at cruising speeds when the engine is warm, but not at idle or full throttle.
2. Idle air controller (IAC): This is a little electrical valve located on the side of the throttle body. It regulates the amount of air that the engine needs to idle at the correct speed. It makes up for stuff like cold temps, being in gear, or having the A/C on at idle. They also get full of junk and jam up, or simply fail electrically. Replacement is extremely simple.
3. Ignition timing. If the timing is late (********), engine vacuum is lowered and it struggles to idle, even without the load of a transmission in gear.
4. Vacuum leaks. Crunchy old vacuum hoses make everything worse.
Apr 07, 2012 | Chevrolet Blazer Cars & Trucks
93 nissan pick uptruck just quit running no sparkk put new cap rotor and power transister on still no spark,tried portable diagnostic and self
Go to Autozone.com and register your vehicle and get a free wiring diagram and powerbox layout. Although it sounds like you have some info.
Sounds like something dependent on the injector circuit is smoked. A bad relay, a bad fuelpump, find out which connects through the injector loop that is not connected when the injectors are out. You should be able to trace it back.
I mentioned the fuelpump because it coasts until the injectors dump fuel into the engine and runs only shortly until the pressure regulator signals a need to kick in again. Perhaps a fuel pressure regulator?
Would be interested in what you find.
Mar 29, 2012 | Nissan Z Cars & Trucks
How to start the snowblower yard machine when you've tried everything to start it up correctly and it doesn't start?
How did you store it? The gas should be drained out of the carburator and tank prior to storing. If you don't do that it starts varnishing the jets closed in the carburator. So to start it, try draining all the old gas out. Take the spark plug out and put the wire back on and lay it on top of the block. Crank the engine over turn switch on if it has one, does it have spark? If it does good. If not try a new plug, if it still does not have spark you will have to pull the flywheel to see what is wrong with the points or pickup. Once you have spark established, put new fuel in tank. Spray a little WD40 into spark plug hole. Put spark plug back in and go through normal starting procedures. Good luck.
Jan 06, 2012 | Sewing Machines
Getting spark getting gas but will not start
If you have spark, the valves may not be working due to a break in the timing belt, chain, or gear. Some of these engines get a timing pulse from a Crankshaft sensor and it does not mean the Cam is turning.
If your sparkplugs are easy to reach, you can try removing one to see if you have compression when the engine is turned over. If no compression, then the Cam most likely is not turning. If you have a Distributor and have spark, then check to see if the engine has fire to the coil in the RUN position.
Your Ignition key has 2 positions which deliver spark, the Starting position and the RUN position. You can have spark when you crank, but can lose spark when you release the Key to the run position.
You may also have insufficient fuel pressure although you have fuel. What you are seeing may be residual gas from before when the fuel pump circuit failed.
Thats' all I have for now.
Dec 31, 2011 | 1991 GMC Sonoma
I have a 1993 chev pick-up v6 4.3, i just installed new spark plugs,new plug wires, distributor cap and rotor button.All plug wires are back in the right position,and i used the firing order 1-6-5-4-3-2...
This diagram is for 1998-1995 Chevy 6 cylinder 4.3L engines.
Your got the firing order exactly correct, at 1-6-5-4-3-2, but here's the thing to double-check:
The distributor rotation is clockwise (note badly rendered arrow in picture).
Since you probably got everything right, then you're left with really unusual/rare causes of
failure of the ignition system:
(a) rotor button misaligned/failing to make contact?
(b) rotor button not pressed onto distributor shaft far enough therefore failing to provide correct
proximity to distributor cap contacts when coil fires
(c) coil wire or contact loose/disconnected - press coil wire firmly down into distributor cap.
(d) distributor shaft of other damage caused during installation of rotor.
(e) spark plug wires defective from factory
(f) spark plugs defective from factory
(g) battery low - may need a charge to start
(h) ICM (ignition control module) failure - hook up your HEI (high energy ignition) tester, and
watch the quality of the spark on each cylinder.
(i) fuel problem? If spark is being properly delivered, its gotta be a fuel problem...
(j) distributor cap not screwed down flush to top of distributor? maybe just on one side?
Inspect the inside of the distributor cap - if there are lots of little metal bits all over the inside
of the distributor cap, then you know you have a misalignment of some type in there, and the
rotor and cap are destroying each other. normal operation will throw a quota of spark-ed off
metal bits inside the distributor cap, but since your cap is brand new, your attempts to start
the engine should have rotated the distributor so few times, you should see no metal debris.
Inspect the distributor cap contacts to see if any spark marks are more of less in the middle
of the cap's proper "contact zone". If not, you've diagnosed an internal misalignment, which
you know how to correct.
Sep 14, 2011 | Chevrolet 1500 Cars & Trucks
2005 gmc safari wont start checked coil spark
how much fuel pressure you have when turn key on
Feb 04, 2010 | 2005 GMC Safari
Car fails to start one day and starts the next.
I would check all the relays and the computer .
They could be over heating when coming on for a while then shorting out.
Apr 01, 2009 | 1998 Chevrolet Camaro
2003 hyundai tiburon 4cyl wont start
I know there is no imoblizer on canadian modles not shure about american if there is that would be my first thing to look for
other then that you have changed alot of parts but have u checked any of the fuses or relays and dubble check that every thing is plugged in correctly if all that is good u have a wirring problem
Oct 19, 2008 | 2003 Hyundai Tiburon
Garden Logo
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
