Question about Amana NFW7300WW Washer
The washing machine will start turn a few times add some water but then stops and the light flashes
I had washed a rug in my washer the rug fell apart i tried to clean everything out it will start turn a few times then stop i bought a electronic control panel because when i ran diagnostics that is the code i recieved but that wasnt it eithier
Sounds like unbalanced now - try to rebalance the adjustable knobs under the washer - we have to rebalance every few months because our floor isn't the straightest. We always know when its time because the washer won't work right.
Posted on Mar 23, 2014
  • 111 Answers
SOURCE: Washing Machine has burnt rubber smell
your problem is probably the coupling that ataches the motor to the transmission , take the skirt of the washer off , take the motor off and you going to see the rubber coupling if is bad just change it , cheap part
Posted on Jun 18, 2009
  • 10 Answers
SOURCE: washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Posted on Feb 10, 2007
  • 7 Answers
SOURCE: washing machine very loud and machine moves during spin cycle
Normal these mean unbalance load of clothes. Try to balance it with heavy clothes opposite each other. The fabric that hold more water tend to be heavier during the spin cycle. Also try not to overload the machine by washing clothes just half to 3 quarters full
Posted on Jan 06, 2009
SOURCE: won't drain or spin
Sounds like the lid switch which is only about 30.00 to fix if you do it yourself. It's a little difficult but it's much better than replacing or having someone come in and do it
Posted on Mar 11, 2009
jumptrout51
  • 3361 Answers
SOURCE: amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Posted on Mar 12, 2009
How can you get a washer smelling good?
First of all this mainly happens when you use cold water washing, the plastic bowl(s) become slightly porous over time & the dirt from clothes adhere to the area between the inner & outer bowls.
To clean & remove smell.
1. Put washer on hot wash, high level & let it fill with HOT water.
2. Stop washer, put in an old towel.
3. Add a bucket of hot water (This allows the water level to be above the scum mark inside machine.
4. Add washing soda to the bowl (double the amount it says on the packet).
5. Start washer & allow to run to the end of the first wash cycle.
6. Stop washer & allow to sit for a few hours.
7. After the few hours, start washer & allow it to run the rest of the full cycle.
you can do the same procedure with Vinegar.
you may have to repeat procedure a few times.
TO PREVENT THIS FROM HAPPENING AGAIN YOU NEED TO DO THIS PROCEDURE ONCE EVERY 3 MONTHS.
The worst case scenario, you will have get a technician to remove the inner bowl & manually clean these areas.
Apr 27, 2014 | Haier HLP21E Top Load Washer
I washed a rug and the back fell apart clogging the washer somehow so the water wont drain what do i do?
You may need to do more than just a filter cleaning. Your sump and hoses are all probably clogged too. Looks like you will have to take the washer apart and give it a good flush out.
WM2277 service manual
Feb 13, 2011 | LG WM2277H Front Load Washer
Had ld reading on screen which is nicked or clogged hose repairman came and replaced pump. i washed 1 rug and it was fine, went to wash another load and got the same ld reading as before, called and was...
You should not wash rugs in this machine. The Long Drain is caused by rubber backing from the rugs flaking off and jamming the pressure tubing. The control cannot detect if water is leaving the machine ok. Take that tubing off the control and blow it out. This washer uses a small amount of water which is continually dumped over the clothes. The pump is strong on these washers. The problem is gonna be sediment in the base of the tub clogging that tubing.
Repair photos and manual are HERE
Feb 03, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
MY FISHER & PAYKEL WASHER STOPPED AFTER RINSE WHEN I WASHED BATH RUGS THAT FELL APART. IT WON'T DRAIN AND MAKES A WHINING NOISE WEN ADVANCED TO SPIN CYCLE. WHAT SHOULD I DO?
Your pump is blocked with the bits from your wash. A handyman may be able to service the pump, but it would be a quick job for a tech. The pump us accessed from under the machine and can be inclipped like a light bulb. Inspect carefully first. look for small latch clip before twisting. Make sure the machine has been bailed out first. lean the machine back againt the wall to give access and to keep what little water remains, away from the drain/pump hole. Good luck....Nomess
Jul 13, 2010 | Fisher and Paykel Washing Machines
My washer will not drain . I washed bathroom rugs that fell apart leaving excess fibers that I beleive plugged up the holes that allows drainage. A few gallons of water is still sitting in my washer and...
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Mar 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washed a bathroom rug, which fell apart in the
The little pieces off of the bottom of the rug are clogging up the pump. Clean out pump.
Jan 15, 2010 | Dryers
I clogged my washer drain...
follow the discharge hose into the washer body --- the trap will be at the housing the hose connects to --- not a big job. be sure to unplug the machine and hand bail the standing water out of the basket. keep a sponge and rags with a pail for the water in the trap and hose. no special tools, but it will be metric
Jun 20, 2009 | Maytag MAH8700A Front Load Washer
Help!
When the backs of the rugs fall apart, they tend to bunch up in the pump and form a pasty substance that keeps the motor from turning. Since the unit knows there is more water in there than what should be, it tries do keep draining even when the unit is turned off (the buzzing noise you're hearing) The first thing you need to do is remove the lower front panel (the screws are on the botom side of it. Once you take those out the panel (with a little wiggeling) will come down then out. On the bottom of your washer, you will see a white piece of plastic. This is your pump where the remanants of your rugs have ended up. I would recommend a large bowl, towels and a wet/ dry vaccume at the ready before the next step. On the front of the pump, there is a knob whcih you turn counter clock wise to open. I recommend putting the edge of the bowl under the pump while you SLOWLY turn the knob. DO NOT OPEN IT ALL OF THE WAY INITALLY! Drain water out a little at a time. Once your bowl is full, screw the knob back in, dump the water and repeat until all of the water is out. Once the water in not flowing anymore, then open the knob fully and pull it out. You will see a white clump of the rub backing.Once you dispose of it, fill then drain your washer again. More remanants of the rug will wash into your pump. Continue this fill, drain pump clean procedure unit the trap comes out fairly clean (it will take many loads to get the last bits out from everywhere inside your washer)
Jun 17, 2008 | GE WBVH6240F Front Load Washer
Washer will not complete cycle
suspect something may have gone in between the inner & outer tubs& got wrapped around the drive shaft, this could account for the 'tight spot' & the water if the item has displaced the water seal. This may mean a biggish job to get the inner tub apart
Oct 16, 2007 | GE Profile WPRE6100G Top Load Washer
Amana NFW7300WW Washer Logo
220 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
