Question about Xerox DocuColor 3535 Copier
Xerox j75 wont print on textured stocks?
Cannot print on linen
2 Suggested Answers
  • 241 Answers
SOURCE: prints aren't plain, it have some texture like crayon
its problem of toner
its of good quality
and also check proper supply of toner into develper assembly
trying to add some extra ink directly in developer assembly
if problem solve
check
cartridge motor running
and supplying toner proeprly
Posted on Oct 05, 2010
Past tense
this is a site for fixes not complaints
Aug 22, 2014 | Refrigerators
How do I print labels using the bypass tray on Xerox phaser 3635?
All I can add to your question is from my experience.
Make sure you have the recommended labels installed.
The fuser can cause jams when not using the correct recommended stock.
Very old labels tend to ooze a small amount of glue along the edges and can get stuck to the inside.
Print as you would do on paper, perhaps try printing on some white 80 GSM stock and hold them up to the light to check alignment.
Good luck.
Jul 02, 2014 | Xerox Phaser 3635MFP/X Multifunction...
I have a fault code 093-329 on a Xerox J75? What is that?
Actually had that code today myself. Tech told me it was because of a toner clog. Take the all toner cartridges out and shake well. Power off/on machine. Problem solved.
Oct 09, 2013 | Office Equipment & Supplies
Can I run envelopes on a Xerox J75 Colour Press
Yes you can. I always rund them from patch 5. make sure the document is in the right size and add the paperformat manualy (size and thickness)
Jul 30, 2013 | Xerox Office Equipment & Supplies
We have a Laser Jet Pro CM1415. It wrinkles linen envelopes when printing. Is there a quick fix (adjustment etc.)? It prints slick envelopes OK.
that printer is really not designed to print on those envelopes but the wrinkling is usually caused by to much moisture in the envelope or paper stock. When the printer heats the print stock to bond the toner to the paper in the fuser unit the moisture evaporates and causes the paper to wrinkle. Don't know of a fix for it other than use different print stock.
BuddyMc
16 Years HP tech
Aug 10, 2011 | HP Office Equipment & Supplies
Xerox Phaser 7750 - Tray 1 streaks on prints
If you put Tray 2 in Tray 1's spot with the heavy stock in Tray 1 (now in tray 2's spot) and print from it, does the problem persist?
This may help...
http://www.support.xerox.com/support/phaser-7500/support/enus.html?objGUID=4538
May 16, 2017 | Xerox Phaser 7750DN Laser Printer
Prints aren't plain, it have some texture like crayon
its of good quality
if problem solve
check
May 24, 2009 | Xerox DocuColor 12 Color Copier
2 sided copying
You just select 2-sided printing in the print dialog box. I think it's on the finishing tab. I'm assuming you aren't trying to print on 2nd side of pre-printed stock. That would be a different issue.
Apr 09, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8200 Smears on Linen Paper
Your maintenance kit is running low on oil and needs to be replaced. Since the image drum is not getting enough lubrication, some of the ink from the previous page is sticking to the drum and carried over onto the next page. Also, try to match the printer paper type to the paper you are using. It will adjust speed, temperature, etc. to optimize print.
Mar 24, 2009 | Xerox Phaser 8200 Laser Printer
Card Stock will not print
1-try both sides of the card stock
2-try the manual by-pass and see it that works
if it works then there could be a problem witht the main board
when you change the setting it changes :the temperature, the pressure on the rollers, and a few other thins, because of the wieght of the paper.
Aug 08, 2008 | Xerox WorkCentre Pro 123/128 Printer
59 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
