Question about QSC PLD4.3 Processing Amplifier
Amp switch on but stays on mute
Staying on mute
Why is my amp only coming on when my f.m radio on its not staying on when I switch to Aux or cd. Everything has power
Your amp is still on - issue is that the connections to your aux and cd inputs are not properly going thru the preamp circuits and reaching your amp inputs.
Jun 20, 2017 | AMP Car Audio & Video
Wiper motor staying on all the time changed wiper motor & switch not relay
I don't know the year model you have a lot of the older ones had a circuit board that went bad.auto zone sells them on the help isle
Mar 04, 2014 | Chevrolet 2500 Cars & Trucks
How do I check if it's the tcc switch without
Drag the brake while staying on the gas & the
solenoid should turn off & rpm go up, when you
come out of lock-up
Whatever the issue the brake sw has to work
Jul 10, 2013 | Cars & Trucks
The headlights of my peugeot 206 is always on, whenever I turn the car on the lights went on and remain the same. I have to turn the battery off to turn the headlights off. What could that be?
Hi, I'm not sure about your car, or if your lights are staying on when the car's turned off, but it sounds like your headlights are hard-wired, it's a safety thing on some cars from some places so you're easier to see. If they're staying on after you turn the car off I'd look for a headlight relay & swap it for a similar one to test it, or replace your headlight switch/dimmer switch.Hope this sheds some light :)
Apr 20, 2010 | 2005 Peugeot 405
F 150 starts and starter stays engaged unplug alternator starts ok but no charge
2 problems, first you have bad starter or starter relay for starter staying engaged, keep alt plugged in has nothing to do with starter staying engauged, to test starter relay, jump at relay bat + post with red/bk wire on solonoid, if cranks over without staying engaged, then not relay or starter but rather in your ign switch, ford had bad problems with ign switch some years ago doing that
Feb 05, 2010 | 2006 Chrysler PT Cruiser
Brake lights staying on.
switch behind break pedal is bad, replace switch
Sep 08, 2009 | 2000 Hyundai Elantra
Anti-lock & brake lights are staying on
NO CK FOR WIRES BROKEN TO ABS SENSOR ON TOP OF THE REAR TWO WIRE TERN. & CK SENSOR IN REAR WITH OM METER
May 18, 2009 | 1990 Ford F150
Mute button is broken and the section where the 9 volt battery goes
you have two choises:1-buy anew one;
2-buy an used one from the used msrket and replce defective component.
Dec 06, 2007 | Shure Beta 58 Microphone
QSC PLD4.3 Processing Amplifier Logo
104 people viewed this question
Top QSC Photography Experts
Tony
Are you a QSC Photography Expert? Answer questions, earn points and help others
