Question about Vehicle Parts & Accessories
Interior electrical outlet plugin
What is maximum hz or amp can use in interior outlet?
    Genius:
  • 1,114 Answers
Typically ' cigarette lighter ' plugs are fused with a 15 amp fuse, so in that case 15 amps is the capacity for that plug. If you have an owners manual check it for the fuse rating for the lighter plug, or check the fuse box . There may be a list of fuses and what they are for. Some folks install auxiliary plugs with higher amperage ratings, say a 20 amp circuit. This would entail using a 20 amp fuse, the correct size wire, and a plug that is rated for 20 amps.
Posted on Mar 30, 2014
Why did interior lights go off when glove compartment lamp switch failed?
Automotive Technology: A Systems Approach
https://books.google.com/books?isbn=1305176421
Jack Erjavec, ‎Rob Thompson - 2014 - ‎Technology & Engineering
... network failure Burned out lamp elements Faulty controller Faulty headlight switchinput ... Glove Box Light Opening the glove box door closes the glove box light switch ... LEDs are often used for interior lighting and custom colors can be often selected ... Editorial review has deemed that any suppressed content does not ...
Reports of Daytime Running Light Problems : Toyota ...
repairpal.com > Problems > Toyota > Corolla
Tested all relays and fuses, Running Light Assy Relay behind glove box burnt. Installed a ... When I turn lights on manually, all dash lights go out-- unable to read speedometer or any other dash indicators .... Engine indicter yellow light does not go off after starting of engine ... Rear oxygen sensor can cause emissions failure.
Interior lights, electric windows & door lock failure? Time to ...
? 2:53
https://www.youtube.com/watch?v=PFwCsnxsS6A
Mar 28, 2015 - Uploaded by Redline Revs
Seat Leon, VW Golf mk4, Audi, Skoda - if your interior lights, electric windows, remote ... If you still can't fix ...
Lights -- interior, incl. instrument and dash lights [Archive ...
Dec 13, 2015 | Cars & Trucks
Just stopped working. Checked circuit breaker in house.
Troubleshooting Dead Outlets ' The Family Handyman
www.familyhandyman.com > Skills > Electrical
Shortly after moving into our house, we had an electrical problem. ... I knew enough tocheck for tripped circuit breakers and GFCI outlets. ... I was just about to start pulling apart the wiring when I double-checked the main panel and noticed the ...Missing: car
Nov 22, 2015 | Cars & Trucks
No interior lights both power outlets in front don't work
you blew the fuse. replace it.
open glove box, see guide. (free at all dealers) see fuse section?
or test all fuses.
only 2 ways, one is harder.
or go to alldata.com and look there, all is there, full electrics for sure.
Nov 11, 2013 | 2006 Honda Odyssey
Keep Blowing Fuses on my ford galaxy for interior lights, soon as I put it in it blows Can anyone help ?
Check how many volts/amps in your interior lights, and check also how many volts/amps on your fuses it suposed the fuses has a twice higher amps than the lights. Or it might you have electrical shorted on your electrical, check on the diagram ang follow the lines for the open wirings connections
Aug 21, 2013 | Cars & Trucks
Interior lights come on when I try to make the dashboard lights brighter on my 1999 grand Cherokee Laredo
Tom is right. They're already at the brightest setting, turning it up anymore is turning the interior lights on. It's normal, there isn't a problem.
Mar 16, 2013 | Vehicle Parts & Accessories
Blown radio and interior lights
You dont post what the make model and year are but most likely there is a part called the BCM that controls those items. IT may be burned out.
Feb 11, 2013 | Cars & Trucks
Which number on the interior fuse panel is the one for the radio?
On Passenger Compartment Fuse Panel Description check position 28, 5AMP...
Hope helps.
Apr 30, 2011 | 2002 Ford Explorer
Mk4 Golf. Remote locking, windows and interior lights not working
Maybe fuse number 6 is blown (check lefthand side of steerning wheel where all teh fuses are located - you must open the door)
Jan 10, 2010 | 2003 Volkswagen Golf
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Hyunday Sonata interior 12V outlets
I pulled the trunk 12V socket outta the wall and ran a wire straight to the battery terminal, so now its powered all the time (thru a 15AMP fuse)
Nov 23, 2008 | 2006 Hyundai Sonata
Vehicle Parts & Accessories Logo
77 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
