Question about Gateway Computers & Internet
Align screen how do i align screen. i need to shift images to the right
  • 406 Answers
Sounds like a monitor issue. Would have to go into monitor menu settings and configure.
Posted on Mar 24, 2014
Print Screen on Gateway 820gm
You need a printer attached to your computer.
Print Screen
Use this method to print screen.
Press and hold down the Alt key and the press the PrtSc key, this places thescreen image into the Clipboard. .
Open a blank Word document and then Click on Edit - Paste.
The image is then places onto this page, you can up the image by holdingdown the Shift key and then place the cursor on the bottom corner of the image,then press the left mouse button and drag it down to the right, release themouse button when you have d the image to your requirements.
NOTE - Holding down the Shift button will maintain the image in the correctproportion.
You can now print this image document and or add text before printing.
Apr 04, 2012 | Gateway 820GM (827103045345) PC Desktop
My model : Samsung SyncMaster 940bw After change of setting, I am getting images which are not clear and crisp and having less colour content
Good Morning!
One thing that I have noticed when I change settings on my monitor is that sometimes it needs to be re-aligned. Thankfully this is very easy to do. There is a button on the bottom right of the screen that says "Auto". dantheman286.png
Press this button and you should see the screen shift and become sharper.
If this does not work, you may want to change the monitor back to the default settings. You can do this by navigating through the menu: Press the Menu Button -> Select "Setup" from the on-screen menu -> And then separately select "Image Reset" and "Color Reset".
Please feel free to comment back if this does not solve your problem.
Thanks!
Mar 01, 2011 | Samsung Syncmaster 940BW LCD Monitor
Connect laptop to LG Plasma 42PQ30R, image alignment issue
I have the same problem, not sure what to do.
Feb 21, 2010 | Televison & Video
Tv image shifted right
Horizontal hold IC and circuit is failing The remote signal will cause it to spasm because of this faulty set of parts. It needs professional intervention to fix this properly
Sep 25, 2009 | Sony FD Trinitron WEGA KV-27FV310 27" TV
Duplicate image in pink displays on the screen.
From your description, it sounds like an alignment problem. There are 3 LCD panels in the projector. Each one displays an exact duplicate image of the others except it's either red, green, or blue. Under normal conditions, the images precisely overlay one another so you get a sharp image. Due to age, heat, or vibration/shock(impact) it would appear that the red LCD panel has shifted a little, giving the "ghosting" effect. You'll have to have the unit repaired by a qualified tech. He'll have the special electronic equipment needed to align the panels properly. Before sending the unit in, try a reset in the menu. Sometimes, the projectors can shift the image electronically, using math algorithms which will try to auto-sharpen the display. Hope I was able to help!---Rick
Aug 11, 2009 | Sanyo PLC XU35 Multimedia Projector
Tv out of alignment
the picture shifted 2 inches to the right
Jun 28, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Desktop view alignment
right click on your desktop and change the default resolution try 800x600, 1024x768 see if that helps. if it does not download a new videocard driver specific to your computer.
Aug 04, 2008 | Toshiba Satellite 15" Flat Panel LCD...
Image Shifted to the Right...
did you go into the service mode, only a good technician should go into there
Jun 22, 2008 | Toshiba TZ50V51 50" Rear Projection...
Half the screen has ghost image (not focused)
Replace the convergence ICs. They are located on a large aluminum heat sink with STK numbers stamped on them. They cost about 10.00 each. They have to be soldered in. Let me know if you need anything further.
Aug 23, 2007 | Sony KP-53S65 53" Rear Projection...
Sone TV Picture not aligned.
This looks like Pincushion problem. nothing you can do. Only a Trained technecian can do this adjustment to reproduce a perfectly aligned image. It requires a pattern Generator and other tools. call the company tech.
May 10, 2007 | Sony KV-36FS100 36" TV
Computers & Internet Logo
11 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
