How to dissasemble ink jetprinter for first time with steps
How to dissasemble for first time all the tool with it's name
    Champion:
  • 220 Answers
Its easy you dont need a step by step thingie. you have to map it. as you take off the screws make a map of where it goes use scatch tape and take the screw to the paper map you have made. that way you will remember where it goes.
Posted on Mar 23, 2014
Hello,I haven't been able to use my printer for some time and the ink heads are blocked,can you help please?
To clean the cartridge via the operator panel, follow the steps below:
  1. Press the Menu button once. The Photo Menu will appear.
  2. Press the down arrow until Clean Cartridge (Press SELECT) appears.
  3. Press Select to begin the cleaning process.
  4. When the page has finished printing, press Stop/Clear to exit the Photo Menu.
However, if you have made several tries already yet cartridges are still not printing properly, it may be time for you to replace those old cartridges with new ones.
Source: How to Clean the Cartridge on a Lexmark P315 Photo Jetprinter
May 30, 2011 | Lexmark P315 InkJet Photo Printer
Lexmark x1185 - the ink skips and some is very light and blurry. i tried the steps it told me to try. Still the same
you tried cleaning to fix the horzontal lines and and aligned it to fix the blurry edges if you dont no how to do that go to the lexmark solution center
Dec 30, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Empty the overflo ink tank on a canon ip5000 printer
The waste ink absorbers on a Canon are pads that are under the print engine and cover the whole bottom. It is a major dissasembly where the covers come off, cables and plugs un plugged, power supply removed, and then you need a shop to reset the counters.
Aug 28, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
I have my lost my Lexmark color ink jetprinter cd
use ur installation disc and run it or go to drivermax and download ur needed drivers....u will find drivermax on
www.driverrmax.com free download
Mar 07, 2009 | Epson LQ 300+ Matrix Printer
How do I clean out my waste ink on my Canon IP 2200 printer
Hi. I researched on this and found that these steps have fixed the problems most of time. Also, it does the required procedure automatically.
Canon Pixma iP1200, iP1600, iP2200 Resetter
  1. Download software for Canon iP1200, iP1600, 2200 Printers.DOWNLOAD Service Tool Software for Canon Pixma Printer iP1200, iP1600, iP2200
  2. Unzip downloaded file by WinZip, 7Zip, Izarc, etc
  3. Run GeneralTool.exe
  4. Select the connected USB port number from USB PORT
  5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
  6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selectedwaste ink counter will be reset. MAIN resets the main waste inkcounter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Feb 07, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Printer not working
Hi
You must download resetter software to your printer name iP tool for canon pixma.
Step 1: Reset hardware
  1. Press Resume button hold for 1 - 2 minutes
  2. Open the cover
  3. Release the catridge and then put catridge again
  4. Close The Cover
  5. Turn Off
  6. then Turn On again
Step 2: Reset Software using general tools
  • Download software resetter or general tools for canon pixma iP4500 : Download service tool for Canon iP4500
  • Driver should have been install correcly.
  • Connect USB cable.
  • Before connect power, press and hold power button then connect the power.
  • At the same time Hold power button, and press reject button for 2 times then release power button.
  • Run software resetter for canon iP4500.
  • Don’t forget to open lock release in the software. ( note : to view lock release menu, min resolution 1024 x 728)
  • Then select Set Destination to iP4500
  • Check CLEANING and EEPROM CLEAR
  • Click MAIN and PLATEN
  • Finally test print by click TEST PATTERN1.
Gud luck..
Jan 29, 2009 | Canon Pixma iP4500 InkJet Printer
Changing the cover
Dear jonah50
Please download this walkthrough step by step guide for the dissasembly of the V3x phone you own.
http://www.formymobile.co.uk/Dismantle/v3xdisassembly.pdf
You need to do Steps 13 to 20 and 41 to 46.
Regards.
Mar 25, 2008 | Motorola Mobility RAZR V3x Cellular Phone
INK BUTTON
  1. Power off the printer and remove it from the mains supply.
  2. Open the printer lid so that you have access to the cartridges.
  3. Pull gently on the ribbon cable connected to the carrier until the carrier is accessible.
  4. Remove the cartridges.
  5. Using a dry, clean cloth, wipe the contacts of the carrier gently from top to bottom.
  6. Repeat Step 5 on the second carrier slot (where applicable).
  7. Reinsert the cartridges and close the lid.
  8. Reconnect the printer to the mains supply and turn on the printer again.
Feb 13, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark x1180 blank ink not coming through
You can refill cartridges only a certain number of times.
Check the copper contacts and see if they look like new. any amount of wear and they wont work anymore. That being said, All printer manufacturers say to buy new and not refill.Maybe that is a moneymaker for them, however, I have never had good luck with refilled cartridges.
Oct 25, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Canon ip 1000 waste ink reset
want the software tool to reset the waste ink level for canon inkjet printers
Apr 20, 2006 | HP LaserJet 1020 Printer
35 people viewed this question
k24674
jasbo
jasbo
