Question about Furniture
Kenmore wine cooler 461-99130 not getting cold compressor is running and making noise
Not getting cold at all the compressor does kicks on but makes a noise
fridgetech
  • 473 Answers
SOURCE: wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Posted on Oct 07, 2007
  • 833 Answers
SOURCE: Haier BC112G Wine Cooler Beeping and overcooling
That thing that's beeping...it is the circuit board. It is telling you that it wants a new cousin to live in your house. Replace it.
Posted on Dec 21, 2007
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
  • 306 Answers
SOURCE: Making clicking sound motor gets hot but not cooling
Your PTC relay on the compressor is bad needs to be replaced.
First be sure to unplug cooler. Remove the cardboard cover that covers most backs of the units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Posted on May 03, 2009
  • 340 Answers
SOURCE: wine cooler makes noise and runs hot
The price looks fine for my area its about a 3 hour job done properly. you should consider a new wine cooler and cut your losses because if their only replacing the compressor they should be replacing the cap tube and liquid drier if the cap tube is not replaced could be a waste of money
Tom
Posted on Jun 17, 2009
Whirlpool 22" wine refrigerator wwc287bls. Makes a high pitched sound pretty much constantly (compressor seems to run constantly too)
Howard, We're sorry to hear about your Wine Cooler making a high pitched noise. Our Wine Coolers are handled by a different department. Please call 800-263-2629 for assistance.
Jun 13, 2017 | Whirlpool Refrigerators
Danby wine cooler DWC440 stopped cooling - makes clicking noise
sounds like you need a new start kit or your compressor is lockedup. get a supco 3in1 for fractional hp compressors.wire it in correctly! you only get one chance at the last step.
Nov 27, 2012 | Danby Refrigerators
Compressor seems bad
HI sally.well wine coolers r not rocket science.your local engineer should be able to at least diagnose the problem...lets c if u can do it ok?(still getting power )u mean light comes on or u mean it runs but dont get cold?well haier is not the best but if it's done 7 years is not bad:).ok...1-check if it makes any noise or is completely quiet.if no sound feel the motor (compressor).hot or cold.if cold it could be the thermostat or motor.if hot running or not it could be refrigerant or motor.needs visual.hope this helps.ALI
Jul 09, 2012 | Haier HVFM20ABB Wine Cooler
My wine cooler works well but it make noise while running, I suspect could be compressor, What should I do?
There is not compressor it a cooler not a fridge... The noise is most likely fans 2 of them one inside and one under the rear cover. remove the bad one take to R Shack ... computer fans are about the same size.
Dec 17, 2011 | Danby DWC283BLS Wine Cooler
Making noise
not to many moving parts on that wine cooler more then likley it is the compressor making the noise. check your warranty to see if the compressor is covered
May 12, 2011 | Haier BC112G Wine Cooler
I have a HVFM20ABB wine cooler and the unit is not getting cold. Is there step or items on the cooler that could be checked to see why it isn't geting cold? There is a noise that it makes when it is on,...
rer
Sorry to read about your problem. you can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Haier HVFM20ABB Wine Cooler
The light comes on but nothing else comes on. I do not hear any noise that it is coming on.
Check your cold control ( thermostat). Is it turned on? If so, is it good? Is it turned up to a colder temperature? If nothing is happening, unplug it. Disassemble the cold control. chances are, there are two wires to it. Twist the two wires together. Plug it back in, making sure that the wires are touching anything. Check the compressor and see if it is running? Is there a fan inside? If so, is it working? If the wires made the compressor and fan, if present, to come on, chances are, the cold control is bad.
Jul 13, 2009 | U-Line 75WC Wine Cooler
Wine cooler doesn't cool properly
Oct 07, 2007 | Marvel 61WC Wine Cooler
Fridge not running well
Not sure of what type of fridge you are refering to.. However you can try a few obvious things. Try turning the thermostat to a lower number (warmer setting) to see if that makes a difference. If you have an ice build up starting to form on the fridge plate or only a partially cold plate then you could have either a loss of refrigerant or compressor fault. Is the compressor noisey in comparisson to its normal noise. Is there heat being produced all over the condenser (black finned section on back of cabinet or underneath cabinet)..If not possible gas leak. Hope this is of some help.
Sep 07, 2007 | Haier BC112G Wine Cooler
U-Line no longer cooling
This sounds like the thermostat is the problem. I wouldsuggest touching the compressor at the back of the unit to see if it is hot or cold. If it is hot then you have probably have power down to the compressor, if it is cold you could (if capable) bypass the thermostat to see if it kicks in. Hope this helps.
Aug 23, 2007 | U-Line 2075WC Wine Cooler
Furniture Logo
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
