Question about Bushnell InstaVision Binocular Binocular
BLURRY WHEN YOU LOOK THROUGH THEM
THERE ARE TWO DIFFERENT ANGLES WHEN YOU LOOK THROUGH THEM. ONE SIDE IS HIGHER THAN THE OTHER. WHEN YOU LOOK THROUGH THE LENSES DO NOT MIX TO MAKE ONE CLEAR PICTURE.
    Sniper:
  • 73 Answers
The binoculars are out of collimation (alignment). It is a problem that requires a repair center. In order to properly adjust them they need to be taken apart and aligned using a collimator. Not something one does at home. If they are under warranty send them back. If not a proper repair will cost more than a replacement.
Posted on Jul 31, 2009
What is the least number of acute angles that a triangle can have?
2 is the least number.
Triangle has 3 angles, so if only 1 is acute and 2 obtuse, then the sum of the two obtuse angles would be > 180 degrees, which can't be correct. Hence you can have max 1 obtuse angle only with 2 acute, or all 3 acute.
Feb 04, 2015 | Computers & Internet
What types of triangles
A triangle with two sides of equal length is an isosceles triangle. The side that is different from the other two is usually called the base, and the two angles at the base are equal.
Aug 01, 2014 | The Learning Company Achieve! Math &...
Replaced wheel cylinder ( driver side rear) brake line not going in? are they different sizes? or is it just a pain to re attach..
If its the right wheel cylinder it should fit, sometimes you have too look at different angles to get it started. Just be careful not to cross thread it or you will have to replace fitting and cylinder
Jul 30, 2012 | 2003 Ford E150
Sony KDL-52WL130 Dark and blurry on left side of screen . Also vertical lines on left side of screen
The TV requires thorough servicing and this might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
Lower cable channels are blurry and higher cable channels are really blurry. Olevia 232S12. Switched tvs and found cable supplied good picture on different tv. Cable tech checked their system and found no...
It is an indication of faulty Tuner, IF transformer.
Send it to repair shop because it is quite technical.
Resoldering on the tuner section will be done first because any cold solder on that section the same problem will be the result.
Tuner is quite expensive so you better ask the shop to estimate the service fee plus the cost of parts. Now you have an idea how much money you are going to spend.
Thanks for using fixya.
Jan 17, 2011 | Televison & Video
Video becomes blurry when object is moved using
Most web cameras are that way. cams are rated on there refresh rate. Higher the rate the better the picture and higher the price.
Aug 30, 2009 | Microsoft LifeCam VX-3000 Web Camera
Photos of souvenir spoons are blurry
Here is the Advanced Manual.
http://gdlp01.c-wss.com/gds/0900001188/PSA540_530CUGad-EN.pdf
See pages 50-52 for what to do. Use a close-up setting and no flash. Also take photo at an angle to reduce reflected glare.
Jul 07, 2009 | Canon PowerShot A540 Digital Camera
My computer monitor loses resolution
try running your graphics card in separate screen mode im thinking you may have it in clone mode and is running both displays at the same res, or if the projector can handle it try running the projector at higher res
Dec 15, 2008 | InFocus LP70+ Multimedia Projector
Bushnell InstaVision Binocular Binocular Logo
702 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
