Question about Emerson Science & Laboratory
Blown fuse put new fuse in 4amp 125volt it kkeps blowing
2 Suggested Answers
firecontrol7
  • 6696 Answers
SOURCE: fuse keep blowing
Means that item the fuse is protecting is bad.Fusing unit is a good start replace it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Apr 03, 2010
My Klipsch cs 500 has no sound. Blue light is on and I have tried every combination on remote to no avail. Any ideas?
There is the panel mounted 4amp fuse, and then there is a circuit mounted 6amp inline fuse as well. Mine blew due to a power surge that blew up other things in my house as well. It’s a bear to get the circuit board screws off, and some green sealant off! Step 1) I’m ordering a panel mounted fuse holder that is the same style as the 4amp fuse holder. Step 2) drill hole in panel, and install fuse holder Step 3) no need to remove old fuse (since its blown) so I’m soldering wires from new fuse holder to the fuse ends on the circuit board
Oct 29, 2017 | Klipsch Audio Players & Recorders
Yellow light on charger goes on then out checked fuse replased with 10amp 125volt slow-blow.
Check the battery voltages, if the total is less then 24v, then your problem is the batteries not the charger.
Sep 10, 2014 | Health & Beauty
Ceramic fuse blows on power board
the power board is shorted and will need replacement. Yo can get the power supply board from www.tvrepairworld.com
Mar 16, 2013 | Sony BRAVIA KDL-40EX400 40" LCD TV
How do i tell the amps for a t4ah 250v ceramic fuse? and is there a substitute for it? it came out of a microwave oven behind the panel.
That is a Time delay 4Amp High break rated 250Volt Sand filled Ceramic Fuse link
Hope that explains it for you. If you aquire a new fuse it must be Time delay 4Amp Ceramic type otherwise it could be a hazard.
Jan 03, 2011 | Televison & Video
The mains input fuse (4amp) and a (1amp) fuse on the main power out board were blown. Replaced fuses and switched on, blown again, disconnected output from transformer to main board (4amp) fuse did not...
The cheapest option is to replace the transistors (a quick check on google will tell you how much they are). If they are common transistors you will be able to find them and get them quicker then searching for a board that could be no longer being made.
Sep 02, 2010 | Mackie SWA1501 Subwoofer
Fuse keep blowing
Apr 01, 2010 | Office Equipment & Supplies
I have a KP-46WT510 and have replaced both STK chips and 1 fuse on the power supply board. Under the heat sink there is another fuse burnt. The value of the fuse needed is 3.15 A. I put in a 3 A fuse and...
I have worked on about 5500 projectors in the past 10 years.
There is a dead short already somewhere so you cant blow anything else up if its a fast blow fuse.
Disconnect the Convergence Amp from the pwr sply then power it up for a few seconds with your 4amp fuse. Does the fuse still blow? If so, check the HOT transistor. (3 pin chip againts the largest heat sink)
Good luck
Dec 30, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Hobart Handler 175 Wire doesn't feed when trigger operated.
First, UNPLUG the Welder! There is a small control board (2"x2") that the feed motor plugs into, it has a fuse on it. Here is what you do: Follow the circuit board trace that goes from one side of the fuse though a resistor then to the connector full of wires on the edge of the board, check that resistor for continuity it should read some value besides open. If it is open, this is your problem (as the drive motor ages it draws slightly more current than new, which should blow fuse, but instead blows the resistor). The resistor should be replaced with same resistance value, if problem persists replace again but instead of 1/4amp bump up to a 3/4amp for $1 or replace that drive motor for $150, you choose. Good Luck!
NOTE: As with any circuit board, take precautions to prevent ESD damage to board.
Apr 20, 2009 | Hobart Welding Tools
My kenwood compact disk payer rxd-a53 shut off now it keeps click
Your problem is caused by a blown fuse on the main board 6.3amp 125volt time delay fuse replace with the exact same type. The reason the fuse blew is most likely because they is a problem with the amp.
I suspect one of the finals is blown 2SD2560 or 2SB1647. Open the case and with the power unplugged replace the fuse, next unplug the 4pin connector from the amplifier board 3 black wires and one red.
now plug in the RXD-A53 and turn it on. you should now have the display working and no clicking.
unplug it from the wall and reconnect the 4 pin connector and now plug it back in and turn it on if the fuse blows again take it to a qualified service technician, the above noted output transistors will run you about 6 bucks a piece they are 4 of them 2 of each for each channel plus labor.
Mar 02, 2009 | JBL On Stage Micro Speaker Dock for Apple...
Science & Laboratory Logo
480 people viewed this question
Top Emerson Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Emerson Science and Laboratory Expert? Answer questions, earn points and help others
