Question about LG 47 47LV5500 47 LCD TV
LG shows it will lose display in 3 seconds
Dear Expert: I have a 47" LG 47LV5500 LCD TV. It once showed that it would lose display within 3 seconds and sure enough, the display was gone then in 3 seconds. After this time, every time when I turn it on, the display will stay about 3 seconds then disappear. But audio is still there. I looked closely that I can still see the picture, but very very dim. If I use the remote control to adjust anything, the display will change normally though it is difficult to see.
    President:
  • LG Master
  • 775 Answers
What Russ Hill has said is a fairly good explanation and I will pay my respects by not repeating it.
What I'd like to add is that sometimes the problem is not in the LED strip, but in the cable between the LED controller and the LED strip - the cables are undersized and literally just burn.
So sometimes you may get lucky and not have to replace LED strip.
if you need to replace the main board, though, here's where you can:
http://www.coppelltvrepair.com/search?q=47LV5500
Posted on Jun 09, 2018
  • LG Master
  • 4,006 Answers
Hi the tv has detected a fault with the back lighting, now it could be a problem with the voltage to the back light or some of the leds in the back light have failed, it will turn off the back light when it finds a fault. behind the screen there is rows of leds on strips and they all light up when the screen is in use. and the main board knows they are lighting up by the voltage its using. when to many leds go out the voltage is too high so it will turn the back lights off to save them. also the same if the power board is not supplying the right volts. say the volts need to light the back screen is 64 volts and its only giving 62 volts the power is not right so it shuts down. same for if the volts go up to 64.5 volts it will do the same. hope this helps you under stand.
Posted on Jun 11, 2017
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
SOURCE: LG 26 inch lcd. Recently it loses the signal from sky remote eye
hi! maybe there is a problem on power supply section or loose connection.
Posted on Sep 01, 2009
  • 8457 Answers
SOURCE: HI my 32lc2r Lg Lcd tv wont show picture.
Might be ur controller inverter board or main video backlight board.Ur video does show up a picture right?That the only two boards that related to video.My adviced to u is buy the controller inverter board first tried that,if not work return it for money back,but must pay restocking fee.That the board between the power supply and main backlight video board.Than u know for sure it the main video backlight board.
Posted on Oct 22, 2009
  • 8457 Answers
SOURCE: LG 42LG50 42 in. HDTV LCD TV
Reset ur tv by unplug,replug it an hour later.Do the same with the digital box.Go to ur tv menu.Go to AUDIO setting,go down to reset,ur audio should return to factory setting,should have sound return.
Posted on May 04, 2010
SOURCE: Picture-In-Picture does not work (32" LG LCD)
my friend told me that if Tv is purchased from Canada will not work in Saudi Arabia but why?
Posted on May 22, 2010
LG vertical line
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 15, 2016 | LG 47LV5500 47 Class LED TV with SmartTV,...
LG 47lv5500 shows wrong colors
Hi, Probably you are gonna have to change the main board! Best Regards! Bye!
Serge!
Jul 03, 2015 | LG 47 47LV5500 47 LCD TV
Picture is upside down
Although obvious, things happen: make sure the unit is not installed upside down.
Recommend going to the Picture section of you manual, and follow the instructions to reset you unit to factory specifications.
Mar 17, 2015 | LG 47 47LV5500 47 LCD TV
How to center screen on lg tv
The set may have in menu or a hidden tech menu some way to center the picture---quick way would be call the Maker in this case LG.
Aug 27, 2012 | LG 47 47LV5500 47 LCD TV
No picture, only sound on LG 47LV5500: how do I get picture back?
Definitely odd for sound to come through and not sound, especially via an HDMI connection.
I would contact LG for support, your TV could be defective.
Good luck
May 28, 2012 | LG 47 47LV5500 47 LCD TV
I have the same issue with my new LG 47lv5500. I too have time warner settings of 1080i but the sound on hd channels comes and goes. Picture is fine. When I switch back to non hd channels the sound is also...
That tv HDMI hub output for the HD tv signal are could be a bad HDMI cable should tries it with another new HDMI cable.If still have the same problems tries it with another HDMI tv hub hook up.That tv HDMI tv hub the one u using now might have a intermittent shorting like lose or dries solders joints that why sound come an goes.
Aug 25, 2011 | LG 47 47LV5500 47 LCD TV
LG 47 47LV5500 47 LCD TV Logo
43 people viewed this question
Computer Repairing
Computer Repairing
