Question about KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator
I have a Moffat side by side that the water diespenser keeps freezing up and stops working
Have the freezer set almost as low as it can go and still freezing dispenser in the door Had man board replaced about a year ago
Krazytech
  • 725 Answers
SOURCE: water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
Posted on Sep 01, 2008
MNTECH
  • 1543 Answers
SOURCE: Kitchenaid Superba Ice Maker quit
Water dispenser works fine eliminates some potential probems, so disconnect the water line at the outlet of the water valve leading to the icemaker. Blow into the tube (with the freezer door open so the air has an escape route.) If you can't blow through the tube, check where the tube passes into the freezer section for an ice blockage. This would result from a water valve not shutting off 100 %, allowing a little water to dribble in and freeze the inlet shut. If you can blow through the tube, most likely the electric solenoid coil on the water valve supplying the ice maker water is bad. In either case, replace the valve. (it is a dual solenoid valve, part # 2315533)
Posted on Sep 08, 2008
tborn6
  • 700 Answers
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
Posted on Apr 04, 2009
woodchuck789
  • 4070 Answers
SOURCE: Water Dispenser not working
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Posted on Aug 27, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: water dispenser will not dispense water ice
eqwe
qe
Hello and sorry to hear about your problem.
90% of the time you will have 2 issues, the water lever switch has failed or the main water inlet valve has failed. I suggest you call a service company.
I have tried to help you. So please help me and Vote/Rate this response. Thanks and good luck.
If you live in the Denver Area, I can help you.
Posted on Dec 23, 2010
Testimonial: "thanks for the suggestions"
Water dispencer works and stops, works and stops
I have a similar refrigerator and there is a problem with the the water line freezing in the area of the freezer door. You can solve it by removing everything perishable from fridge and shutting it down. I have had to do this twice and it works. We now keep the freezer set at 1 and it has been fine for a year. GE does make a small electric aftermarket heater that goes in the door area if needed.
Mar 27, 2011 | GE Profile Performance 25.2 cu. ft....
Fill tube to ice maker keeps freezing up. Replaced double water valve and worked good for a week. Stopped up again today and found a leak in elbow going up to water in door. Would this let water leak into...
1.Check water pressure is lower than actual. Turn it full flow.2.Check water filter, replace it if over dust particles. 3.Freezer setting may be very low. Increase it. Better to keep in 5 degree always.
4.Inspect the water hose from one end to the other. If there are parts that are bent or pinched, the water will not be able to pass through and chances for get freezes. Thanks.
Jan 24, 2011 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Water does not work. Possibly frozen line. i keep
I have a GE PSS25SGNA no ice no water freezer side is reading -2 refrigerator side 25 everything is freezing help
Jan 03, 2011 | GE PSS25SGNBS Side by Side Refrigerator
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Ice maker fill tube freezing water dumpng all over floor
either the water solinide valve is faulty and allowing water to escape/ water pressure is to low or air is getting into freezer from the back of fridge freezer were the fill tube inserts
Sep 22, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dipenser
The instruction book suggests this could be because the freezer temperature is set too low. Mine is set at -20C. It says the water line can freeze stopping water flow. Try reducing the temperature.
Sep 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Water dispenser system
the dispenser in the freezer door has a small low temp heater surrounding the dispenser compartment to keep this from happening, and also to keep condensation from building up around the dispenser. this heater may have stopped working.
May 22, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Won't make ice
some times low water pressure will freeze drain tube, a badwater valve wont give enough water quick enough and tricling water will freeze ion a a week or so its frozen!
Mar 17, 2008 | Refrigerators
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
KitchenAid Superba Architect KSCS25IN Side by Side Refrigerator Logo
14 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
