Arrange channels in bpl tv using manual tuning
SOURCE: Sharp LC-52D62U HDTV won't tune-in channel 21.
I finally got Sharp to repair the TV. It was under warenty but they said if the problem wasn't with the TV they were going to charge me for the service call. I told them I wanted a new TV. They sent the tech instead of a new TV. He replaced the turner card and it worked!! Now I get all the channels as well as channel 21.
SOURCE: how to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
SOURCE: I am in Afghanistan, Kabul
try going into the autotune then select us then cable select the auto acan then change from auto to irc or std then scan should do the trick.
SOURCE: my samsung LE40R8 no longer
It could be an Ariel problem. Suggest you try checkin all ariel connections .
Hope this helps.
Looks like there are multiple problems with the unit. The inability to find freeview channels is due to a malfunctioning tuner which is responsible for scanning for analog channels. As for the self-test tone, I believe its just not letting out an audio signal thats all. The self-test will still work incase of serious component level failure.
