Question about Ruud Matching Split Air Conditioner
Help My transformer got hit by lightning whenpower came on the air conditioner didn't all I need to know is where the reset button is
  • 614 Answers
Old rheems ahd a reeset for head pressure on outside unit. May have took out the transformer. Check inside Air handler to see if there is five amp auto fuse in the fan board it may have blown. Rus
Posted on Jun 14, 2009
I,m having trouble setting the remote for this machine. i have hit the reset and that didn,t do anything. can you help me please
Make sure you have good batteries in the remote. Then if nada works the problem lies with either the hand remote or the receiver part in the AC.
Jul 18, 2015 | Danby DPAC90061 Portable Air Conditioner
Reset the contactor relay
the contactor does not have a reset button 24 volts will energize a magnet and pull the contactor in you can also manually push in the contactor for testing purposes the airhandler has the transformer which produces 24 volts this power then goes to the tstat then you select a mode which then goes to the contactor you most likely have a blown fuse on the circuit board or simular problem the contactor could have shorted causing this
Jun 27, 2012 | Goodman Heating & Cooling
My house was struck by lightning most of all my computers and tv's and phones are no working and my ac is not coming on at all. What happen to my AC unit
Hi and welcome to FixYa, I am Kelly.
The main Preinted circuit board (PCB) most likely has had a failure of the small PCB transformer. This is the most susceptable component (PCB transformer) in the Air Conditioner. Within the last 60 days I have personally experienced the exact same symtom. I replaced the PCB transformer and 1 diode on the main PCB of the air-conditioner and my AC unit is working fine. Unless you can find a source for the transformer your only option is to replace the PCB (Board).
Finding the exact transrformer for the PCB can take a very long time. It iwll look similar to this one: http://www.machsources.com/productimages/9913/pcb-mounting-transformer.jpg
If you have home owners insurance ALL STATE and State Farm often cover this type of damage. It is worth the time to find out if you are a home owner.
Thanks for choosing FixYa,
Kelly
Sep 13, 2011 | Frigidaire FAC085M7A Air Conditioner
Model UAKA 030JAZ was working fine. Now, the compressor fan does not come on and neither does the compressor. I don't know how the contactor works but it is not engaging (the spring loaded contacts are...
Hello
You need to complete the 24 volt circut from the themostat to the transformer to get the contactor to pull in.
Check for voltage at the transformer,should be 120 v in 24 volts out.Also there may be a small reset button on the transformer.
Apr 18, 2011 | Ruud UAKA030 Air Conditioner
Have a problem with my Intertherm air conditioner not coming on so I put a new thermostat on it. Nothing comes on fan nor heat nor air. I reset the breaker but still nothing and the unit model is a...
Turn the thermostat off and check for 24vac between R and C on the thermostat. If there is no C then to G or W. If you don't have 24vac go the transformer and check for 24vac on the secondary. If it isn't there then check for 120vac on the transformer primary. If it isn't there check the circuit breaker/fuse. If it is there then ohm the transformer windings and replace if bad. Let me know what you find so I can offer more advice.
Aug 10, 2010 | Intertherm P3RA-048K Air Conditioner
Is there a breaker on unit 9000 itself. i changed the thermastat there was a spark and now it dont work. is there some kind of reset button??model num;ca9036vk92
It sounds like you shorted the transformer. You can check at the transformer for a control fuse - alot of time there is not one and the transformer must be replaced.
htttp://www.my-air-conditioner.com
Oct 19, 2009 | GE AJCH10ACB Built-In Room Air Cool Unit
It is blowing out room temperture air all the fans are working correctly, no power supply problem just no cold air at all I changed the filter and looked for a reset button but no, we had a thunderstorm...
Sounds like your compressor might have been hit by lightning. If you have 220 volts going to the outdoor unit use a stick to push the contactor in. The fan and compressor should start, if not check the capacitor. If the capacitor is good, the compressor is probably bad.
Sep 27, 2009 | Heating & Cooling
Heat Pump Reset Button
If running in heat check indoor air filter if in cool wash out outside coil with garden hose make sure fan is not overheating and shutting down.
Jan 06, 2008 | LG LSC121PMA Split System Air Conditioner
Air conditioner
The lightening may of caused a surge and your unit may have it's own protector that resets and comes back on after a time frame programed into it.
Jul 30, 2007 | Maytag M6Q10F2A Air Conditioner
Ruud Matching Split Air Conditioner Logo
125 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
