Question about Packard Bell Easynote Tk85 Laptop Motherboard Mb.br702.001 Mbbr702001
System shuts down and gets hot
My laptop shuts down by itself and it gets real hot at the site of the CPU.
I am not familiar with this particular model, but this is a problem found in all older PCs as well. The first thing to check is whether the cooling fan is turning, and whether it is blocked by dust and fluff.
If that is fixed, the next thing to check is whether the thermal heat transfer paste has dried out between the CPU and the heat sink. In a PC this is usually fairly simple, and if you have a large cover plate on the bottom of your laptop you can (if you are game) do it yourself. If not, get a reliable tech to help you. Heat transfer paste is cheaply sourced from the internet. Clean dried paste is best cleaned with mineral turpentine and a clean rag. Use no more than a grain of rice sized blob of paste, and spread it very evenly with the edge of a business card onto either the CPU of the heat sink. Be very careful to make sure everything goes back exactly the way you found it.
Good luck.
Posted on Mar 23, 2014
G7
Yes, the CPU will shut down. . If it is getting too hot, even though the vents are open, then the fan may need to be replaced.
Jul 02, 2014 | HP Pavilion Computers & Internet
I have a msi a6000 laptop and it keeps shutting off itself and wont boot windows when windows stars booting it shuts off and i clean the fan so thats not it can someone tell me what it's hapening
try replacing the thermal grease on your cpu.
the BIOS have a protection that restart or shut down the computer/laptop when the cpu get to hot.
You can also check if the power suply is working in parameters
Dec 06, 2012 | MSI A6000-226US Core 2 Duo T6600 2.2GHz...
Laptop randomly overheats/shuts down.
Just let it charge fully , take out charger and then use it as normal , when you leave a charger plugged in it drains the life from the battery ????Best of luck hope it works it did for a few ppl on here
Sharon murphy via fixya.com
May 08, 2017 | HEWLETT-PACKARD Pavilion DV74065dx...
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 04, 2010 | Toshiba Computers & Internet
My Averatec 3200 keeps shutting itself down. The
A common problem with all laptop is dust. Sounds like you have 5 years worth of dust stuck in there. You should get a can of compressed air and blow though every vent you can! You want to loosen the dust that's in there and possibly try to blow it out and/or get it closest to the vents.
After that you should take a vaacum cleaner and **** out all the dust you can!
Dust inhibits air flow, alot! Its the number 1 killer of old computers.
Apr 18, 2010 | Averatec Sotec 3200 Series Fan with...
My acer aspire 5738g keeps shutting down when i'm
Sorry you are having troule. It sounds as if it is getting hot and protecting itself. Games are very cpu intensive and this causes heat. The cheap fix is an under cooler. This is a cooler the laptop sits on. I have seen them at Best Buy for under $20
Apr 07, 2010 | Acer Computers & Internet
My laptop gets heat and shutdown
Solution:
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
Feb 27, 2010 | Compaq Evo N610C Notebook
I have a balance laptop cn 6301 modle 1 535 when you trun it on it just beeps and the screen is black and then it shut down and get very hot
Try unseating the memory and reseating it back into its slot.
If you don't get video after that and the motherboard still is getting real hot then either the cpu fan or motherboard is bad.
Dec 15, 2009 | Computers & Internet
Shut down itself
Hi i'm Rain.
If your Laptop is over heating you may need to look into a stronger type of cooling system { Fan }
But for now lets set up your power Options settings
to try to keep your CPU cool.
In power options select Power Saver.
If you see the selection to keep the fan running select it also. save and exit.
Hopefully this will help to keep your system cool until you can service it.
Nov 25, 2009 | Compaq Presario Notebook
Laptop keeps shutting off by itself
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Oct 08, 2009 | Gateway (60.44K08.001) Laptop Heatsink
Packard Bell Easynote Tk85 Laptop Motherboard Mb.br702.001 Mbbr702001 Logo
107 people viewed this question
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tony
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
