Question about Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100
BEEP on start. BOOT OS but no VIDEO
The board boot and get a BEEP and boot Op. System. but no video. I try with other monitor and it work. The problem is with some monotors. I try with 3 monitors and 2 works and 2 not works. Why? can you help me please? Thanks in advance
    Problem Solver:
  • 10 Answers
How many beeps. Look up beep codes. is it a award bios there are stickers or names on the chips look them up that should help maybe even drivers from biostar might help you determine the beep codes .
Could be something as simple as a memory module just not sitting proper . take out memory and reset the memory. just to be sure. or try a similar memory module. back then they never sat proper you have to wiggle them a little
i have known computers not to boot with a bad memory module.
the 6150 had alot of bad capacitors check to see if the little bottle caps are bulging out or leaking that might just be your issue. nvidia stoped making motherboards. its a shame cause I think beyond the issues with capacitors (that effected everyone in the market asus gyabyte you name it manufacture of motherboards or electronics of any kind from early 2000 on till after 2004 some time)
Posted on Mar 23, 2014
Testimonial: "The PC star normally but, no image. After boot, i plug other monitor and it work. The other monitor, i plug into other PC and it Work!!! :O both monitors work fine!"
Lollyloopp
  • 31 Answers
SOURCE: Boots, no video signal.
First try removing the memory you installed and see if it boots normally. If that does not work then try replacing the original memory with the new memory.
If the motherboard beeps at you then look up the beep code pattern in the owner's manual. If you do not get any beeps and no video output at all then it is possible the motherboard or processor was shocked. You can try testing the motherboard with another compatible processor. If that does not work then it is likely the motherboard is bad.
Hope this helps!
Posted on Nov 28, 2007
mewms_14904
  • 1027 Answers
SOURCE: motherboard problems??
If all the peripherals are working in other machines then it sounds like the chipset or the bios itself would be suspect.
Did anyone Flash the bios with an upgrade?
I have a motherboard that the northbridge is affected. All components seem to work fine except no USB ports or CardBus work.
Posted on Jun 01, 2008
  • 64 Answers
SOURCE: No Monitor display with P4VMA-M Motherboard cpu...
good day,
have you tried unplugging and replugging the cable connecting from the monitor to the video card? if after trying that it your video card is still not functioning, try installing a separate video card in its appropriate slot and try if this will work. better yet, have it checked by a competent technician in your area to verify other possible causes of this problem.
i hope this will help
Posted on Oct 13, 2008
hmerchant110
  • 7191 Answers
SOURCE: pc used to work fine but now won't boot, post or
Check the mains power supply cable. Try to Connect with another cable. Or, the SMPS power supply unit may be at fault.
Posted on Jun 24, 2009
  • 3 Answers
SOURCE: my biostar g31 -m7 te motherboard does not boot
bigger problem with that!!
I Need a Answer For The Biostar -
MCP6P M2+
AMD2 board
I am useing a 430 Watt power supply
now that the onboard video from the back of the computer has broken/revoved
was removed for fire hazard risks/ was not repairable soldered broke loose from the board it was attached to made by biostar INC
I went out and bought a brand new ATi Diamond Multimedia Radeon HD 6450 pci express 512MB GDDR2
pci express card
my problem is my video is not coming up/ no post
now I did read there pdf material for my board on bio setting enabing features etc but thats only if you had the onboard video to get there first hahah
right come on lol
can you help me out here if theres a solutio
my only sollution thought of mind o knowledge where to go is
I can go buy a new board same 100 % at electronic pc store they have it take this video card back come back bio-settings with new board then return it buy the video card again then procide?? would you suggest that?????
Posted on May 28, 2010
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
AMD sempron power supply
I would venture that "shows winfast on monitor" indicates the type of Video Card that your PC is using. Thereafter it should go to POST showing the motherboard, BIOS, memory count and others.
Since as you posted, after Winfast nothing follows, I can only suspect that you have a motherboard problem or at least a BIOS corruption.
Please post back the brand and model of your computer or at least what motherboard.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Computers & Internet
Screen breaks up into 4 horizontal screens when booting. Occasionally can get proper boot screen. Have reinstalled OS (Vista) still cannot boot to OS even when I have the full screen. My feeling is that...
Do a simple test - Try connecting it to an external monitor or LCD monitor (at work, a friend or neighbor's) - if you get the same thing on the LCD and external monitor, then you've got bad on-board video (MB); if you only get abnormal output on the laptop's screen and the external video is fine, then it's likely a bad screen...
Sep 14, 2011 | Packard Bell Computers & Internet
Long continuous beep on boot (no boot) ,monitor keeps off, Boistar BIOS, i checked the fan, the keyboard and also the memory... what it should be then??? should i throw the PC from the window??
A long continuous beep could be a video card problem or video RAM problem.
Try reseating the video card or try a different video card.
If the video card is builtin on the motherboard then it uses shared RAM and the RAM module may be faulty or needs reseating. Try testing the RAM at your friendly computer repair shop.
Jul 23, 2011 | Computers & Internet
I put the card on my PC and connect de monitor to the card (VGA). when system boot, the speaker of the board sounds beep, like everything is good, but no video. And yet the card plugging in the board, but...
Hello friend,
Please i think you card is not acceptable by the system, or have you checked another card on the system to see if it displays the same thing. And when you remove the card the system boots normal without any error. So check on the card make a change on it.
Jul 04, 2011 | Creative Labs 3D Blaster 4 Titanium 4200...
I have a samsung 973v..the problem is that "there is no display"..what part of the monitor should i check..?
Cause:
  • Monitor failure
  • Video card or onboard video device failure
  • Driver conflict or improper driver installation
  • Power issue
  • Loose device connection
Resolution:
  1. Verify the computer and monitor has power and is actually turned on.
    • Not turned on? Well… turn it on. J
    • No power? – Make sure power connections are in and secure. Reseat them to verify.
    • Make sure their power bar is on. (If they have one.)
    • If the monitor still has no power, try it directly to the wall and another outlet.
    • Still no power on the monitor, RPL if in warranty and is the original monitor or Op sale a new one.
    • If the tower has no power, try step 5. If still no power see No power troubleshooting.
  2. Verify the connections are secure. Reseat them to verify this.
  3. Remove the monitor connection from the tower, check if the monitor self test appears. (If may take a few seconds) If it appears, the monitor is fine. If it doesn’t, bad monitor!
  4. Replace it if in warranty (and is the original monitor) or Op sale a new one!
  5. Does the owner have picture in POST (Power on Self Test) or in the Bios? Do they lose it as soon as Windows loads? (If the computer has no POST or Bios go directly to step 7)
  6. If they lose picture as soon as windows loads, boot to safe mode
    • Check for multiple video adapters, if there are two, try disabling the one the user is not using. (Usually a problem with onboard video overriding a video card).
    • If they are exactly the same try uninstalling one and rebooting. It might be a ghost driver.
    • If the ghost driver reappears after rebooting, try disabling it like it is a device. (Because it might be.)
    • If only one device is listed, uninstall the video driver. Reboot the PC and install the driver off of the driver disk.
  7. If the issue repeats, uninstall the video driver again, get the user into windows normally and Doc-express them the updated driver. Give the SR# and your audix. If this issue happens even with an updated driver, you are looking at service for a potential hardware issue.
  8. Do a hardware reset: Unplug the power from the wall and hold the power button in for 20 seconds. Try and boot. Check for onboard video as well as a video card. If the owner has both, try the onboard video. If it works. Check the device manager and try installing the video card properly. If it is installed properly, try disabling the onboard. Then switch it back to the video card. If the PC does not have both onboard and a video card. Proceed to the next step.
  9. Open the tower and reseat the video card. (Make sure the owner has the power off and unplugged. Also make sure they touch a metal part of the computer to discharge static (IE the metal frame or power supply)
  10. Still no video after reseating the card? It may be the video card or something on the motherboard.
  11. Remove the video card completely and try booting. Does the motherboard beep? If it does, the motherboard is fine and you should replace the video card if in warranty. If out of warranty, op sale a new one. If the motherboard does not beep, it may be a bad motherboard or something attached to it. (Note: Not all motherboards have beep codes, check the source!)
  12. If you are unsure if the video card is actually causing the problem, service may be the best option
Aug 06, 2010 | Computers & Internet
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
When I have two monitors plugged in, machine starts three times: first just a fan noise for a 5 seconds or so and power down, second (starts by itself) also fan noise and shut down, third (starts by...
  1. If the system has integrated video with a DVI expansion card, you can use two monitors.
  2. If the system has a PCI-E dual head video card (2 video connections on the video expansion card) then you can use 2 monitors.
  3. If the system has a single head PCI-E video card (ATI HD2400) with a single DVI port, then that card disables the on-board VGA port.
So first you have to find out what the hardware configuration actually is for the Video Card. Then we can look at the monitors and how they are connected.
Post back with details on the video card and the monitors you are trying to connect if you need further information.
Jan 14, 2010 | Dell Inspiron 530 PC Desktop
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
thnk you.
Nov 29, 2008 | Computers & Internet
ASUS P4S533-MX Motherboard
Does it have a built-in system beep buzzer? or else you need to connect one. The system beep has a code and will tell you if your video is not connected or your memory is not detected.
Try to make it boot even until the bios screen. Check your video card or your monitor connector. A single beep is a good sign that your motherboard has no problems. hope this helps
Sep 25, 2008 | ASUS P4S533 Motherboard
Biostar MCP6P-M2 Motherboard - v6.0, NVIDIA GeForce 6150, Socket AM2, MicroATX, Audio, Video, 10/100 Logo
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
