Question about Dishwashers
Pdw9280n20ss We woke this morning to the smell of burnt plastic. The smell was coming from our GE Profile dishwasher. I opened the door and it was burning hot to the touch and the heating element appeared to have never shut off from to prior evening dish cycle. Any plastic material such as dishes and spoons had melted. Nothing was directly touching the element. I don't believe the element is bad because of all the heat coming out of the unit. I immediately shut the circuit breaker off. I would like to repair myself. Is there a thermostat or another part that could be replaced to fix this problem? Is there a way to trouble shoot the problem? I don't believe it is the element. Thank you in advance for your help.
5 Suggested Answers
  • 1462 Answers
SOURCE: GE PDW9700 - Heating Element turns on by itself and Burns my dishes
have experienced this problem on some zanussi machines. what is happening is that the machine continues thro cycle thinking there is water in machine when there is not. can be caused by:
slow pump rate caused by blockage especially near the drain pump inlet
faulty pressure stat
Posted on Aug 21, 2008
meBNme
  • 334 Answers
SOURCE: Heating element comes on and stays on when not even called for.
There is a stuck relay or switch somewhere.
The important thing at this point is that you get it turned off!!!
Flip the breaker if you have to, but get it off, as it is a fire hazzard like that.
You can attempt to diagnose the problem yourself if you like and we can help. You will need a multimieter hat can read Volts, amps, and ohms.
If not, disconnect power and call a pro. But whatever you do, get it off ASAP.
Posted on Jan 07, 2009
  • 10865 Answers
SOURCE: Frigidaire dishwasher heated dry way too hot
Wow. So glad to hear that you had no permanent damage.
Posted on Jun 19, 2009
heatman101
  • 43501 Answers
SOURCE: Hi! I have noticed that
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Posted on Feb 27, 2011
I have a GE Profile Dishwasher... it's about 5 years old (Model # PDW7880J03SS). It has a front control panel. This morning, only half of the lighted buttons work. The left side does not. I have hit the...
I have a GE profile model number pdw8200jbb . Only two lights appear on the touch panel. The stay on for a little while after opening and closing the door and then go off. Any suggestions
Jun 27, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
Our GE Profile dishwasher will not open. I have
door latch must have broke take a knife and jimmy the latch
Dec 10, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher began smoking while cycling. Noticed some water in the bottom before starting the dishwasher. The little door for the soap pouch opened but the pouch stayed inside the door area. It smelled like...
hi..the reason to this problem is probably due to the
bad belt.you need to replace it with a new one.
check this out..
thank you..
kindly rate my response..
Jul 21, 2009 | GE Dishwashers
Burning plastic smell, big flash & now its dead - Bosch SHU8805UC
remove the water and, the burnt plastic that probanly melted on the dish drying heater coil
close and, lock the door turn the dishwasher back on and, reset the circuit breaker to see if the motor will run or, is damaged
Jul 01, 2009 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Burning Frigidaire dishwasher
After you turn off the power to your dishwasher, you can inspect the dishwasher with a flashlight to find where the melting happened. If it is near the circle that is the heating element, you can suspect the timer froze during the drying cycle.
But also open things up and look for shorted/melted wires (in the door panel and under the dishwasher.)
No matter what you find, if you have proof of purchase for your dishwasher, I would press for repair/replacement from the manufacturer.
Good Luck!
May 02, 2009 | Frigidaire FDB1502RG Built-in Dishwasher
Dishwasher door will not open.tried running it another cycle and still nothing.It is a GE profile with the latch that you just push in. The latch/handle seems stiff.
The plastic latch release inside the door handle is broken. Most likely one of the pins holding it in place has broken.
First go to your local dishwasher supplier and look at a similar brand (GE Profile in my case) and see how the mechanism works. Next, get a thin pair of siccors, pull the dishwasher handle down and slid the siccors into the opening above the handel and push the tab holding the door closed up so it will release.
Once the door is open, remove the inside of the door to get to the latch. Remove the plastic latch release and order a new one.
Sep 28, 2008 | Dishwashers
GE PRofile Diswasher PDW9880
you probably need a new control panel. The panel isn't sealed to the face everywhere, and food or water runs down the internal cable.
my panel burnt up. replacing it fixed the problem.
I caulked it in with clear caulk to prevent a recurrence.
Apr 15, 2007 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
Owen Barnes
