Question about GE Power PRO Series X2600 16.1-Megapixel Digital Camera
Broke battery cover
Battery cover locks are broke an will not stay lock down
    Top Expert:
  • GE Master
  • 6,702 Answers
And now you can't use the camera? the cover must be closed complete. There is a switch, to check if the cover is closed. this is checked, to prevent damage to the memory card. When the camera is powered down while accessing the memory, the already saved pictures can become damaged.
You better contact an authorised service centre, for a repair of the camera.
Posted on Mar 23, 2014
How to install sim card
1. Slide battery door switch from locked to unlocked.
2. Remove battery door by prying up in the notch are that is provided in the bottom corner.
3. Slide battery lock switch to unlocked position ( this is located at the bottom of the battery and slides from left to right or right to left depending on if the device is locked or unlocked.
4. Remove battery from the device.
5. In the bottom left hand corner you will find a small metal tray that has a rubber flap covering the front of it. Pull up on the rubber flap ( it stays connected to the phone ).
6. Look for the SIM card picture to show the correct orientation of the card.
7. Slide the card into the metal tray and the replace the rubber flap by pressing down on it firmly.
8. Replace battery and slide battery lock switch to the locked position.
9. Replace battery door and slide the battery door switch to the locked position.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/thomas_e8f475a8655f7b4a
Jul 11, 2014 | Casio G-zone Commando
I can't keep the battery door cover closed on my Nikon coolpix digital camera L.22
I see this message at least 3 times, so it must be important.
Looks like a mechanical problem. But not having the camera in my own hands I have to do some educated guesses.
Could be something broke off. Could be a small chip of plastic or a very small piece of metal. Difficult to repair it yourself. But you also could look if there is something in the battery compartment that should not be there. Could be just a little bit of debris, that is lifting the battery, (not if the battery is behind the lock) or debris in the door, so you can't close the battery compartment complete, and it can't be locked.
If you can't find anything and it looks as if the battery compartment closes correct, and still you only can't lock the door, please visit your dealer or the Nikon service centre closest to you.
Nov 19, 2013 | Nikon COOLPIX Cameras
Midland walkietalkies -how do you put in new
You have to remove the belt clip, then the battery cover. There is a locking tab at the top of the belt clip.
To remove the belt clip, press the LOCK TAB down , then gently pull the belt clip up toward the top of the radio.
Then remove the battery cover, press near the seam and slide the cover down:
Replace the batteries, observing polarity.
Slide the cover back on until it locks in place.
To install the belt clip, slide the clip down into the slot on the back
of the radio until the belt clip lock clicks.
Hope this helps! If you need more help, please ask!
Oct 17, 2013 | Midland LXT310 2-Way Radio
How to remove sim card from nokia x3-02
1.Insert a SIM card. Make sure the contact area of the card is facing down
2.Press the release buttons, and remove the cover. If the battery is inserted, lift the battery out.
3.Line up the contacts of the battery and the battery compartment, and insert the battery. To replace the back cover, direct the top locking catches toward their slots, and press down until the cover locks into place.
Nov 29, 2012 | Cell Phones
How do i remove the battery out of my garmin 1300
Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
  • 2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
  • 3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
  • 4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
  • 5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
  • Mar 01, 2011 | Garmin nuvi 1300 Car GPS Receiver
    I cannot get the cover off to change batteries
    Removing the cover is described and illustrated here:
    http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
    "Press down on the inner battery cover (as indicated by red arrow in image below) to relieve tension on the bottom portion of the cover. While pushing down on the top of the battery cover, pull the bottom of the cover towards you to remove."
    Feb 14, 2011 | Weiser Lock Powerbolt 1000 Lock
    Jvc camcorder gz-mg37u battery lock broke
    Fixya does not sell replacement battery locks and is unable to recommend sources.
    Aug 03, 2017 | Video Cameras
    Key ignition switch needs replaced lock cylinder how do i change key broke off inside damaged needs replaced wires broke off behind key switch
    disconnect the battery and pull the air bag fuse out to diable the air bag. Remove the steering coulmb trim covers and expose the lock cylinder. If the lock cylinder can be turned and is functional then push in the bottom tab and turn the lock cylinder then pull the whole cylinder out. If the keys broke inside and the lock cylinder is not functional the bottom tab will need to be drilled out.
    graphic.aspx?mod=reptiff&module_id=1&session_id=%7b812b1a44-e9f7-498d-9233-3843c35aa6d4%7d&image_guid=00010135&print_bw=0&
    Feb 27, 2010 | 2000 Pontiac Sunfire
    Battery cover for cds6300
    the molded plastic clips ,when cover is closed and pushed in to lock are broken from camera body both pieces. How and where can it be repair.
    Oct 21, 2007 | RCA CDS6300 Digital Camera
    GE Power PRO Series X2600 16.1-Megapixel Digital Camera Logo
    59 people viewed this question
    Top GE Cameras Experts
    Steven Wander
    Steven Wander
    jjanesic
    jjanesic
    Level 1 Expert
    Are you a GE Camera Expert? Answer questions, earn points and help others
