Question about Frigidaire Refrigerators
Fridge temperature too hot won't go down with temperature controls
We put warm food in fridge. Temperature went to 16. High temperature alert went off. Couldn't turn it off so unplugged fridge for a while. Plugged back in and temperature only went down to 14. Took a lot of food out, put some freezer packs in and next day it was down to 1. Later that day it went back up to 13. Temp went up and down all day. This morning - two days later - it is back to 15. So I have turned it off by the temp controls. Compressor went off and have turned it back on - set for 1. Put some freezer packs in for the food that I can't move to the freezer. Left a message for the service tech (but it is Sunday). Anything else I can do so all my food does not spoil.
    New Friend:
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Posted on Mar 23, 2014
myob247
  • 1342 Answers
SOURCE: GE Profile- Freezer/ Fridge at 56 wont go cooler!
More good into HERE
Posted on May 03, 2008
  • 1462 Answers
SOURCE: Fridge temp too high
probable cause is jammed fan. first take back panel off fridge, electrical connections are plug and socket. yoy may find a quite small build up of ice underneath the fan. melt it off and you should be ok. samsung are prone to this problem
Posted on May 08, 2007
tborn6
  • 700 Answers
SOURCE: Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Posted on Mar 28, 2009
Sea Breeze
  • 4655 Answers
SOURCE: fridge works but doesn't isn't cooling
I will help but you need to confirm your model number. Is your model the one listed above your post? Let me know, Sea Breeze
Posted on Jun 20, 2009
woodchuck789
  • 4070 Answers
SOURCE: Freezer temp. goes high
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and the back in others.
Posted on Mar 06, 2010
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
The fridge & freezer has started to get warm it was 8deg above the recomended temperature & then the light starts to flash,we have cleaned all around it,taken food away from the outlets in the...
it can be a defective thermistor,a defective cold control or compressors short cycling(not running long enough) or the evaporatorin the freezer is frozen up and cant keep temps constant
Aug 03, 2011 | Refrigerators
Xerox Phaser 4500 printer has a U4 fuser code.
From the Xerox Phaser 4500 Service Manual (here), the main problems could be one of:
  • Warm-up failure - Fuser warm-up not complete within 110 seconds after
  • starting.
  • Cool-down error - Cool-down process not complete within 200 seconds.
  • Low trouble temperature - The fuser temperature drops to the low trouble
  • temperature (approximately current control temperature, minus
  • approximately 25°C).
  • High trouble temperature - The fuser temperature rises to the high trouble
  • temperature (approximately current control temperature, plus
  • approximately 35°C).
  • STS circuit open
  • STS failure - The heat rod remains on for at least 10 seconds after warm-
  • up has completed
It could be that your fuser needs to be replaced, but as you can see that code relates to a couple of problems, so even replacing the Fuser might not fix the problem.
If it doesn't even do the warm up checks it is likely to be the fuser because the other components such as STS failure and cooldown won't have had a chance to run..
May 03, 2011 | Office Equipment & Supplies
I am having LG GR-B352 YC , what is the best temperature that i can keep initially and future??
Generic instructions to set temperatures in fridges:
Many manufacturers design these appliances to operate at 0 degrees F in the freezer and 34 to 36 degrees F in the fresh food compartment.
To set the temperature correctly, fill a glass with water (8 to 12 ounces) and place a thermometer capable of indicating 32 degrees and up into the glass with water (if the temperature goes below 32 degrees, the water will freeze - so no need to find a thermometer that indicates any lower). Place the glass with the thermometer in it on a shelf and wait. Putting the thermometer in a glass of water helps preserve the temperature reading while the door is open. You can skip the water and glass if you want - but you'll need to read the temperature as soon as you open the door.
The freezer will require a thermometer capable of displaying 0 degrees F. Place it on a shelf where it can be seen readily - but preferably in the rear - between items (to prevent the warm air from driving the indicator up when opening the door to read it).
It will probably be easier to set the freezer temperature first. Adjust both the freezer and fresh food thermostats to mid-points (if the fridge is empty - otherwise skip this step). Adjust the freezer thermostat up or down as needed to reach the desired 0 degree F temperature.
Once the freezer adjustments are complete, adjust the fresh food compartment thermostat as needed up or down to reach the desired temperature for it.
If you fridge is fully stocked, it may take some time for the temperature to stabilize and warm / cool the fridge's contents completely. This is further affected by how often the door(s) are opened and for how long. 24 hours is often claimed - but you might be able to sneak an 8 - 12 hour soak before reading the thermometers.
After the temperatures are set, you may find that the lower part of the fresh food area is partially freezing - simply adjust the thermometer up *slightly* as needed.
Please rate this reply if it was helpful - good luck!
Aug 11, 2010 | Refrigerators
VEGETABLES FREEZING IN LOWER LEFT DRAWER. I have an LG model LFX25960. If I raise the temp to 45 in the refrigerator it will be 34 in that drawer but that also makes the rest of the refrigerator too low a...
Hello, This problem is going to be the cold control, this can be located in the control panel inside the fridge. This part is also called the thermostat. What is happening here is it has opened and the freezer is getting to cold which is making the fridge too cold. This is why the food in your fridge is freezing. You should replace the cold control and you will be all set. Mike
Nov 07, 2009 | LG Refrigerators
Mr.
When the heater comes on for defrost behind the rear freezer panel , it gets red hot . The defrost thermostat ( bimetal ) , cuts the heater off , when it reaches 140 degrees for new (2000 - 2009 ) and 55 degrees for older refrigs . When this temp is reached at the top of the coils , the lower portion will be hotter due to being closer to the heater . The frozen food in the freezer , is what keeps the temp down in front of the rear freezer panel . No food in freezer , the hotter the freezer section will be .
Oct 03, 2009 | GE Hotpoint® HTR17BBSL Top Freezer...
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Pressed a button, now fridge won't work
you have pressed the defrost button that is why the compressor stops and would not come back on. there could be a temperature sensor on the thermostat or a timer where in it would only reset back after the temperature of the fridge warms up. try to remove all the food and let is sit for a while, plugged and watch if the compressor would kick in after about two hours or untill the fridge warms up. if the button is stuck, you may have to spray lubricant in the thermostat or replace the thermostat .
Feb 21, 2008 | Danby DCR34 Compact Refrigerator
May 08, 2007 | Samsung RS2630WW Side by Side Refrigerator
Refrigerators Logo
174 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
