Question about Haier Refrigerators
Compressor keep tripping out - Haier Refrigerators
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Could be the relay overload on the compressor if not it is a bad compressor
Posted on Mar 24, 2014
Htachi ec89 Thermal Protection trips
Its your reset button on the compressor that's bad! I have the exact same compressor (EC89) and it did the same thing! Compressor would run great for 15-20 seconds, then trip the reset button. I ordered a new reset button off e-bay, replaced it, and it works fine now. Good overall compressor! but has cheep china electronics installed. just replace the reset button and you will be good to go....cheep fix!!!
Sep 01, 2012 | Hitachi EC89 4 Gallon Twin Stack Air...
Why does my 40 amp breaker for my 5 ton Rheem AC keep tripping? Not my air handler
Hello, usually if the compressor is shorted to ground it will keep tripping t he breaker. One way you can check yhis is disconnect power to the outdoor unit and use a ohmeter to check each winding of the compressor to ground. You can use the discharge line from the compressor as a ground, you should not read any resistance, if ou do the compressor is shorted to ground and will need to be replaced.
May 10, 2012 | Heating & Cooling
Have an carrier 48tfe005-a-311 keeps tripping when i try to reset the breaker.Is the motor shorted.any thoughts
You need to use a CLAMP tester to check the CURRENT factor on the compressor. If this is HIGH then the compressor motor, the compressor or the capacitor is faulty.
Please couple a caapacitor to confirm , if not the compressor needs an overhauling.
check if there is leak on the motor body that makes the circuit breaker to trip.
Jul 28, 2011 | Heating & Cooling
Outdoor unit on a sanyo split unit not going on
Hi, check the box at the outdoor unit. Some have 2 fuses inside behind the plastic cover. One may have blown. Also, check the breaker at the main power box for a tripped breaker. If it is tripped, and keeps tripping when you reset it, your compressor is grounded. You can remove the 3 wires from the compressor, tape them and turn the breaker back on. If it holds, this confirms the compressor is shorted to ground. Is this helpful?
Shastalaker7
A/C, Heating Contractor
Jan 21, 2011 | Heating & Cooling
Need a point setting for ao smith air compressor ac motor model number opa-0297 s# c56b72b2316508j2 work on air machine with motor installed motor will hum and trip breaker can we set points to stop trip...
try running up this motor when its not installed on the compressor,, if it still blows the trips the motor is faulty,, if it runs ok, but hums when reconted to the compressor the compressor if far to tight for the motor to turn the compressor,,,you can not reset the points in a breaker trip they trip at a set curent if the motor is pulling more amps than the trip is set for it will trip the trip to turn off the curent, the motor will pull far more amps than it should if its over loaded thats why its humming its trying to spin up it but cant so it just keeps pulling more and more amps till the trip cuts out
Mar 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Kenmore upright freezer model 29238 keeps tripping switch
If the compressor actually runs for more than a second or two its likely the compressor is bad. Some models had a 5 year warranty and some ten years on the compressor only. The replacement of the compressor is likely beyond your abilities unless you are a service technician.
A typical cost for such a repair can be more than the freezer may have cost you if nothing is under warranty. Good Luck.
Aug 31, 2009 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Continues to make ice when grill cover is off, then trips on safety limit #2 when replaced. condensor has been fully cleaned
If this is a combination gas grill with the accessory fridge mounted in the cabinet, then the issue is that once you put the grill cover on, you are preventing proper airflow/circulation needed to keep the fridge's compressor ventilated enough to keep operating.
Try leaving the grill cover off and move the grill/fridge out of direct sunlight, as the thermal heating of the cabinet isn't helping the fridge get enough air circulation to help it (the compressor) run cool enough to keep from tripping the thermal overload sensor (thermistor or Klicxon themal protection device) mounted on the compressor.
This device prevents the compressor from extreme heating that can cause the compressor have a catastrophic failure.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Manitowoc Refrigerators
My compressor won't come on and the trip breaker on the compressor keeps going off and stopping the machine from running?
Sometimes when you have too long of an extention cord hooked to a compressor, it can cause the breaker to trip due to too much resistance in the power line. If you are using an extension, try to plug directly to oultlet or get a thicker gauge cord.
Jul 18, 2009 | Air Tools & Compressors
A/c is drawing 20 amps and keeps tripping breaker after running
If the fan is running and the compressor is getting hot and tripping off you may have a failed capacitor.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
Samsung Ac compressor stops after 20 minutes and fan keep running. Again after 10-15 minutes if ac is restarted the cooling happens for 20 minutes and compressor stops.
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Mar 15, 2009 | Samsung AW0693L Air Conditioner
Refrigerators Logo
48 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
