Question about Cosmi 1,000 Best Fonts Full Version for PC
Installing with cd
My cd is for 16 bits and it is not compatible with 64bits windows What can I do
I got a NexxTech force feedback sterring wheel, the model is 261-8107, is there a driver compatible for windows 8
Have you tried the 32 bit driver? Many things will not have a specific 64 bit driver. You may need to install in compatability mode.
Jul 25, 2014 | NexxTech Computers & Internet
Je ne peux pas installer mon scanner "Canoscan
As tu le pilote 64bits??? si non il le faut, il se peut aussi qu'il ne soit pas support? dutout par Windoze 64bits
Bonne chance!
Apr 26, 2011 | Canon CanoScan 5000F Flatbed Scanner
I cannot install arcview 3.2 gis on my laptop just because my laptop is 64bit and yet this arcview 3.2 requires only 34bit system!
Hello - You have the idea of the nature of 32/64 bit operating systems somewhat confused. 32-bit does not mean it is inherently downwardly compatible with 64-bit. To the contrary, much 32-bit software is not compatible.
64-bit versions of Windows try automatically to run in a 32 bit compatibility mode called WOW64. It couldn't work with Arcview. The actual problem with 3.x is that it has a 16-bit installer and no 16-bit software will run on a 64-bit OS. I checked at the ESRI website and the issue has not been fixed.
If Arcview is essential for you to run then it could be addressed by making your system dual boot between 32/64 bit Windows versions.
Thanks for using Fix Ya
Mikeywaf
Mar 20, 2011 | Computers & Internet
I have windows 7 and I have been trying to install hasbro sorry game cd rom but it wont install
You need to read the case that the CD came in. It will list 'system requirements". I bet that the game is written in 32 or 16 bit language and windows 7 is 64 bit and it is not "backwards" compatible, meaning that it won't run a 16 or 32 bit program.
Feb 25, 2011 | Hasbro Interactive Video Game Consoles &...
SPECIAL EDITION SCRATCHES won't play on my windows 7 laptop. Chris
i think the problem is with compatibility with your OS. first, u need to check that your windows 7 is installed with 32bits or 64bits system. second, check your game compatibility (is it compatible with 32bits, 64bits, or both. if your OS installed with 64bit then your game only compatible with 32bits so the game will not work, and the contrary.
my opinion (probably wrong):
maybe your win 7 is installed with 64bits and your game only support 32bits system, so you need get another 'scratches' game that support 64bits. another solution (worst scenario), try to installing your win 7 with new win 7 with 32bits system.:)
Feb 17, 2011 | Computers & Internet
Installing the jumpstart advanced 1stgrade cd rom that has 4 cds to it and I can't get it to install.
Jumpstart advanced 1stgrade cd rom installation.
System Requirements
Windows: 98/ME/2000/XP; Pentium II 266MHz (Pentium II 300MHz or faster for XP); 64 MB RAM (128 MB RAM for XP); 100 MB HD; 12x CD-ROM drive; 16-Bit color; Windows compatible sound card
If you are installing on a newer OS ie Vista, or Win 7, due to software incompatibility the software might not install, or even you can install the software might no work.
You can try using the "compatibility mode" in Vista or Win 7 to install the programs as "administrator" but no guarante this will work.
Alternatively, you can get a newer version which is compatible to your Operating System.
Hope it helps.
Jul 25, 2010 | Jump Start JUMPSTART ADVANCED 1ST GRADE...
I have Windows 7. Wanted to install Trophy Bass 2 and get this message. Any suggestions? --------------------------- Unsupported 16-Bit Application --------------------------- The program or feature...
unfortunately no, windows 64 bit doesn't support 32 bit or 16 bit applications so you should call the support number or go online to return the unsupported edition for a 64 bit edition (if they have one). Hope this helps.
Jan 30, 2010 | Computers & Internet
Picture won't show up for nancy drew message in a haunted mansion
these are the min. specs for the game>
System Requirements:
  • Windows 95, 98, ME, 2000, XP
  • 166 MHz Processor
  • 16 MB RAM
  • 200 MB available hard disk space
  • 16 Bit color graphics video card that's compatible with direct X 6 or higher.
  • 8x CD-ROM drive
  • 16 Bit compatible sound card
  • A pointing device and speakers
Platform: WINDOWS 95/98/ME/XP
Oct 06, 2009 | Computers & Internet
Cosmi 1,000 Best Fonts Full Version for PC Logo
27 people viewed this question
Top Cosmi Computers & Internet Experts
Tony
Alun Cox
raysaw
Are you a Cosmi Computer and Internet Expert? Answer questions, earn points and help others
