Question about Watches
I can't get the back of my fossil es2409 watch back on.
I changed the battery in my fossil es2409, but now I can't get the back of the watch back on.
SOURCE: Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
Posted on Aug 24, 2007
SOURCE: how to open the back of a Fossil pocket watch?
battery change
Posted on May 18, 2008
escapement
  • 2334 Answers
SOURCE: Cannot get the cover back on Fossil watch after changing battery
First open your bracelet. Then align groove in caseback with crown and press that side lightly into the case. Then using both hands(one from dial side, another from back) press as strong as you can.
If this do not work:
Get mens leather belt and place it on flat surface(table top). Lay the watch face down on that belt. Again adjust caseback as before and using your weight push caseback down with both hands.
NEVER use hammer or similar.
If none of these works- go and see your nearest watchmaker.
Posted on Dec 21, 2008
SOURCE: Time change Fossil JR 9120
i already found one link with all Fossil manuals.
Thank´s for your support.
Posted on Feb 09, 2010
SOURCE: how to change the battery
when changing a battery in a swiss legend how do i get chronograph hands to reset to correct position
Posted on Mar 25, 2010
I want to change out batteries
1. Lay the watch upside down on top of a towel or cloth on a flat workspace. Use a small flat head screwdriver or blade to pry under the watch backing, then lift the backing from the watch. Slide the battery cover to the side to access and remove the battery.
2.Take the battery to any electronics store to purchase a replacement. Bringing the old battery will ensure you install the correct type of battery in your Fossil watch.
3. Replace the battery and the battery cover. Apply pressure to the backing until it "pops" back into the watch.
THANK YOU FOR VISITING FIXYA
Aug 05, 2010 | Fossil Dress - Analog Glitz Red Dial Watch
Fossil ch2360 can not figuare out how to get to the battery
mcdevito75 here, Most Fossil Watches have a press fit back cover. First locate ant tab, or indentation that is on the back cover linning up with the case itself, Carefully use a steak knife under that tab or in the indentation, slot in the cover abd pry up. From there you may need a jewlers screwdriver to loosen the battery hold down plate to remove the battery. BEST BET, look for a small watch repair shop in your area to change the battery.
Jul 31, 2010 | Fossil Watches
What battery do i need for my fossil watch its one with changing display thank you
its the norm for fossils to have 2 batterys one for the hand function and one for the back display. it depends on year or what movement is fitted.you will have a 3v battery for back display and under it there maybe a smaller cell 1.5 .it could be a 2016 or even2025 3voltand a 364 or 377 small cell but you wont know untill the backs off the watch and remember you need it resealing to make sure its water resistant after its been repaired this needs to be done by fossil or a good watch repair service like Intime watch services uk..you have to AC the movement as well to make sure all functions work it needs to be done by a trained tech..
Mar 26, 2010 | Fossil Bigtic Animation Display Silver...
What size battery and how do you change it?
most fossiles are 371, 377 or 364. fossil backs can be hard to get back on so u might want to take it to a jewelry store its only like tem dollars
Oct 10, 2009 | Fossil ES9382 Wrist Watch
Changing the battery for my Fossil Watch
You have to have a tool to unscrew the back of the watch. I figured this out the hard way. I suggest taking it to a jewler for after I replaced my battery, the stinking thing still did not work. This sounds like a commom problem as I read more about them. Hope this helped.
Nov 22, 2008 | Fossil AU4003 Wristwatch
How do you remove the back of a Fossil watch to change the battery?
good morning ! to remove the case back of your fossil watch,just snap the case back use the knife to do that ! but if your fossil watch is waterfroof design you need to use the wrench opener for treaded watch case back ! good luck ! god bless !...
Sep 02, 2008 | Fossil Watches
Need to change the battery on my fossil watch but can't seem to remove the back of the watch to do so
good morning ! if your watch is waterfroop design that`s have a tread so if you want to open the case back you need a wrench or opener, but if your watch is snop in design you need a knife to open the case back,and change the battery,thank you,
Aug 27, 2008 | Fossil Watches
I have a fossil blue watch. How do i change the battery? thanks
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Aug 23, 2008 | Fossil Watches
Fossil watch battery
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi SDMIKED
I suggest you consult your authorized Fossil Dealers for the correct battery replacement of your watch.
Thank you.
Nov 11, 2007 | Fossil AU4003 Wristwatch
Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
Mar 15, 2007 | Fossil University of Oklahoma LI2282 Sport...
Watches Logo
62 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
