Question about Black & Decker Leaf Hog Blower Bv4000
Replaced fuse and can't get the the toggle mech to op the pwr swi
BV 4000 type 2. I took apart the blower to replace the fuse. When I put the switch pieces back in, I can't get the piece that turns the power switch to low or high power to operate the switch.
  • philwarner Apr 14, 2012
    Had the same problem and, after spending most of the day trying to figure out if I had lost a part that was also not shown in the parts list, I discovered the missing part was the blower base which has two prongs that push the rocker toward the switch when you put it on. IE, you can't turn the motor on unless there is a blower base or a vacuum attachment installed.
2 Suggested Answers
2strokeJim
  • 577 Answers
SOURCE: i took my leaf blower apart and a white plastic
What kind of blower is it, I guess I'm not sure what you are talking about unless it was something covering the bottom connectors so they did'nt short to case ?
Posted on Oct 11, 2011
On 2004 pontiac montana what does fuse 7 control
7-BATT MAIN 1
60A
Fuses: •
CIGAR/DLC/APO FRT
• CLUSTER BATT
• CTSY LAMP
• ON STAR
• PWR LOCK
• PWR MIRROR
• RAP RELAY
• RR PWR SCKT
look below for above listed componet's , pull those fuse's one at a time till arc stop's ,then you found your problem circuit . Do you know where the I/P fuse box is ?
Fuse Block- I/P
Right side of the I/P, in the right front door opening
Fuse Block-I/P Label
Fuse Block-I/P Application Table Fuse/Circuit Breaker
Rating
Description
BCM PRGRM
10A
Body Control Module (BCM)
ENHANCED EVAP/AWD
15A
Evaporative Emission (EVAP) Canister Vent Solenoid, Clutch Pump Check Valve
CIGAR/DLC/APO FRT
20A
Auxiliary Power Outlet-Front, Cigar Lighter, Data Link Connector (DLC)
CLUSTER/BATT
10A
Instrument Panel Cluster (IPC)
CRUISE
10A
Cruise Control Module (CCM), Cruise Control Release Switch, Cruise Control ON/OFF Switch
CTSY LAMP
10A
DRL
10A
Daytime Running Lamps (DRL) Control Module
HVAC/DIC/DRL/HEATED SEAT
10A
Air Temperature Actuator-Left, Air Temperature Actuator-Right, Daytime Running Lamps (DRL) Control Module, Driver Information Center (DIC), Mode Actuator, Rear Window Wiper/Washer and Multifunction Switch (Heated Seat Switch), Recirculation Actuator, Relay Block (Rear Window Defogger Relay)
ELC/TRAILER
25A
Auto Level Control (ALC) Air Compressor, Auto Level Control (ALC) Air Inflator Relay, Auto Level Control (ALC) Sensor
FRT HVAC HI BLWR
30A
Blower Motor Resistor Assembly
FRT WPR/WSHR
25A
Windshield Wiper Motor, Windshield Wiper/Washer Switch
HAZARD
15A
Turn Signal/Multifunction Switch
HEADLAMP
20A
Daytime Running Lamps (DRL) Control Module, Headlamp Dimmer Switch, Headlamp Switch
HTD MIRROR
10A
Outside Rearview Mirrors-Left, Right
HVAC/BLOWER
25A
HVAC Control Module
IGN1
10A
Body Control Module (BCM), Instrument Panel Cluster (IPC), Left Rear Side Door Actuator Control Module, Rear Object Sensor Control Module, Right Rear Side Door Actuator Control Module, Stop Lamp Switch
LH HEADLP HIGH
10A
Headlamp High Beam-Left
LH HEADLP LOW
10A
Headlamp Low Beam-Left
LH T/LP
10A
Tail Lamp-Left, Trailer Rear Wiring Harness
MALL/CLUSTER
10A
ON STAR
5A
Vehicle Interface Unit (VIU)
PASS KEY
10A
Theft Deterrent Control Module
PCM/ABS
10A
Electronic Brake Control Module (EBCM), Fuse Block-Underhood, Powertrain Control Module (PCM), Park/Neutral Position (PNP) Switch
PCM/CRANK
10A
PCM/PASS KEY/CLUSTER
10A
Instrument Panel Cluster (IPC), Powertrain Control Module (PCM), Theft Deterrent Control Module, Instrument Panel Cluster (IPC), Powertrain Control Module (PCM)
PWR LOCK
20A
PWR MIRROR
10A
Outside Rearview Mirror Switch
PWR QTR VENT
10A
Auto Level Control (ALC) Air Compressor, Auto Level Control (ALC) Sensor, Rear Quarter Window Switch
PWR/HEATED SEAT PSD
30A
Driver Seat Assembly, Passenger Seat Assembly
PWR SLDG DR
30A
Left Rear Side Door Actuator Control Module, Right Rear Side Door Actuator Control Module
PWR WDO
30A
Window Switch-Driver, Window Switch-Front Passenger
RAP RELAY
10A
Relay Block (RAP Relay)
RH HEADLP HIGH
10A
Headlamp High Beam-Right
RH HEADLP LOW
10A
Headlamp Low Beam-Right
RR HVAC/TEMP CONT
25A
Air Temperature Actuator-Auxiliary, Blower Motor-Auxiliary, Blower Motor Relay-Auxiliary, HVAC Control Assembly-Auxiliary, Mode Actuator-Auxiliary
RR DEFOG/ HTD MIRROR
30A
Window Defogger Relay-Rear
RR FOG LP
10A
Fog Lamp Relay-Rear
RR PWR SCKT
20A
Auxiliary Power Outlet-Rear
RH T/LP
10A
Tail Lamp-Right, Trailer Rear Wiring Harness
RR WPR/WSHR
20A
Window Wiper Motor-Rear, Rear Window Wiper/Washer and Multifunction Switch
SIR
15A
Inflatable Restraint Sensing and Diagnostic Module (SDM)
STOP LAMP
15A
Stop Lamp Switch
SWC BACKLIGHT
2A
Steering Wheel Controls-Left, Right
T/SIG
10A
Turn Signal Switch and Backup Lamp Relay
Jan 09, 2018 | Pontiac Cars & Trucks
I took my leaf blower apart because it was making a loud noise. How do I put the switch, slider and lever back together?
Google search your make and model# , switch replacement, the same way it came apart, next time take picture when disassembling
Feb 22, 2016 | Garden
B&D BV2500, Type 6 Switch Problem. Blower will
try replaceing the switch not that expensive.
Oct 14, 2017 | Black & Decker Garden
ECM Giotto toggle (power) switch needs replacement ASAP in Seattle area.
i had this happen myself a few months ago, power switch blew, i took the machine apart took out the power switch, and visited a few local electrical component suppliers, its a standard switch but its 2 stage single throw switch, home depot/Lowe's don't carry this type. ended up going to 3 diff suppliers and finally found a commercial supplier that had it connected the new one and now its fine, works better than the old one ever did. just make sure you bring the broken switch with you when you go to show them, most good suppliers can match it and see if they have one like it in stock.
Apr 21, 2011 | ECM Giotto Espresso Machine
2003 Pontiac Grand Am gt. the blower motor
hi
the problem lies with the selector switch.there is some short circuiting taking place inside the switch.so please replace the selector switch.
if my information was usefull please rate me
Jul 01, 2010 | 2001 Pontiac Grand Am SE
I have an ao code and have replaced the vaccum switch and blower vaccum switch and still getting the ao code
Check the tubing going from the blower to the blower vacuum switch. If there are any cracks, missing, or cut, it will give the same code. Rodents like to chew on this tube. Also, if the blower is not coming on at all, then you will get the same code, and the problem is not with the switch, it is likely in the blower.
May 19, 2010 | Hayward H-series Electronic Gas Pool...
How do you convert the vacum to a blower?
Im guessing ... remove the device you are vaccuming with and put it on the other end of the air stream. Is yours both a vacuum and a blower???
Oct 18, 2009 | Garden
My ps3 doesnt read the disk
The laser or laser mech or both are worn out. This is a very common problem. I had to replace my laser mech in mine. My advice is to replace the laser and mech. Best website for great prices and cheap shipping is..
http://www.consoleshop.com/home.php?cat=308
You can find out how to take your ps3 apart and to show you how to replace the laser mech on youtube. You will need to take it apart before you order the new part. There are 2 different laser mechs... The model code in one the laser mech its self. It will be Kem-410ACA or Kem-400AAA.
One more thing, once you replace the laser mech somtimes the cd holder I guess is what you could call it, its the where the cd sits where the laser is reading the cd with not accept the cd and jam. This is common just make sure every spring is set in the right place. There are also videos on youtube showing what to look for. Everything has to be in sync. It took me like 2 hours the get everything in sync .. But some people have no troubles at all.
Good Luck Hope It Helps
Sep 10, 2009 | Sony Video Game Consoles & Games
Black & Decker Leaf Hog Blower Bv4000 Logo
256 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
