Gateway SX2801-01e I own a Gateway SX2801-01e computer. Currently the tower is placed on its side (power button faces up, the air flow from the fan faces vertically. Does it matter if I change the tower placement and lay it flat? The monitor would be on top of the tower...and will not block the airflow? Thank you in advance. Paul
  • Paul L
    Paul L Mar 23, 2014
    I want to lay the tower flat. Will it maintain more dust rather that having it on it's side?
  • Brad Brown Mar 23, 2014
    There wont be any more dust that way than if you set it any other way.
  • Computers & ... Master
  • 16,404 Answers
There is no problem with laying a tower on its side.
Posted on Mar 23, 2014
Fan is too loud
Every computer comes built with a processor cooling fan system.
The fan's main function is to keep the processor from overheating.
After long periods of use, processor fans can start to malfunction.
If your eMachines computer's fan is excessively noisy, it will need some maintenance.
If you don't deal with a noisy fan promptly, your computer's processor could overheat and cause significant damage to your motherboard as a result.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Power down the computer.
Disconnect all cables and peripheral devices from the computer's back panel.
Rotate the computer so the back panel is facing you. Lay the computer on its left side.
Remove the Phillips thumb screws that fasten the right side access panel to the computer's frame.
Remove the side access panel from the computer to reveal the motherboard and all internal components.
Locate the cooling fan assembly near the center of the motherboard.
Remove all Phillips screws fastening the fan to the motherboard.
Disconnect the fan's power cable from the motherboard.
Then lift the fan out of the computer.
This will reveal the processor chip.
Place the fan on a flat work surface with the label sticker facing upward.
Use a thin, flat-head screwdriver to peel away the label sticker from the fan.
This will reveal the access hole to the fan motor's bearings.
Apply one to two drops of lightweight mechanical oil into the fan motor's bearings.
Replace the fan's label sticker.
Use a can of compressed air to spray the dust and debris from inside the fan blades.
Place the fan back into the motherboard on top of the processor chip.
Replace the retention screws and reconnect the fan's power cable to the motherboard.
Replace the side access panel and its two retention thumb screws.
Place the computer tower vertically, and then reconnect all cables and devices to the computer.
Nov 18, 2013 | eMachines EL Computers & Internet
Dell precision T3500 unable to initialize fan controller error
Step 1:
b> WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Every computer comes with its own internal cooling system. Dell workstation desktops are no different. Your computer's cooling system consists of a heat sink and cooling fan. The function of the cooling fan is to regulate the temperature of your computer's processor. If the fan stops working your processor will overheat and cause damage to your motherboard. Fortunately, Dell desktops have a built-in alert system that tells you when your fan stops working.
Shut down your desktop computer. Disconnect the power cable from the computer's back panel. Then disconnect any external devices. Rotate the computer so the back panel is facing you. Attach an electrostatic discharge (ESD) strap to your wrist and its wire clip to the outer casing of the computer. Lay the computer tower on its left side. Press on the side panel release buttons situated on the top and bottom panels. Grasp the side panel and rotate it away from the computer until the internal contents of the computer are accessible. Locate the cooling fan duct near the center of the motherboard. Lift the duct off of the cooling fan so it is in the upright position. Disconnect the fan's power cable from the motherboard. Disengage and remove the retaining clips from each side of the cooling fan assembly. Lift the cooling fan out of the motherboard. Set it aside. Check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Use a clean paper towel to wipe the excess thermal grease from the processor's surface. Apply a thin coat of thermal grease to the processor's surface using a cotton swab. This is important; if you skip this step, your processor will fry as soon as you power on your computer. Place the new cooling fan over the processor. Press down on each retaining clip until the cooling fan snaps into place. Connect the fan's cable to the motherboard. Place the air duct back over the cooling fan assembly. Rotate the side access panel downward over the computer's opening. Press down on the side access panel until it snaps into place. Place the computer vertically, and then reconnect all cables and devices to the computer.
Feb 18, 2013 | Dell Precision T3500 Computer Workstation...
Which way does the rear fan go in a compaq computer tower
The proper installation of a CPU fan is often the subject of debate. Though there are conflicting theories as to which direction the CPU fan should face, there are methods to ascertain which CPU fan installation best suits your needs. The determining factors of your CPU fan installation direction include the manufacturer specifications, your case design and the specific design of your heat sink
Horizontal Installation
  • The installation of a CPU fan horizontally to the plane of the motherboard is the most common installation orientation there is. Your options when installing your CPU fan are to blow cool air onto the heat sink or to pull cool air through the heat sink from the motherboard. Horizontal installations show negligible advantages in either installation direction. The differences in temperature usually vary by only 1 or 2 degrees Celsius. The main point to consider when installing a horizontal CPU fan is the location of the rear exhaust fan on the case. If the rear exhaust fan on the case is parallel to the processor, it is advantageous to have the fan pull cool air from the motherboard and push it out above the heat sink. This is because the case fan will quickly draw that hot air away from the CPU and out of the case, allowing for quick cooling.
Vertical Installation
  • Vertical, or tower, heat sinks rise high enough off the motherboard to allow for a fan to be installed perpendicular to the plane of the motherboard. This allows for cooling to go from the front to the back of the case, as opposed to going from the bottom to the top. Optimal installations for vertical heat sinks are blowing toward either the back or the top of the case. If there is no exhaust fan in the top face of your computer's case, it is more effective to orient your fan on your vertical heat sink so that it blows toward the rear exhaust fan of the case. If there is an exhaust fan on the top face of your computer case, it is almost always more effective to mount your CPU fan so that it blows air up toward the top of your case. The reasoning behind this is that hot air rises and will more naturally flow off the top of your case. Also, top-mounted fans are usually larger and allow for faster airflow out of the case.
Manufacturer Recommendations
  • It is often the case with nonstock heat sinks that the manufacturer has designed the heat sink's fan to be mounted in a limited number of orientations. This is usually evidenced by limited mounting notches on the heat sink itself. Most aftermarket heat sinks use technologies such as heat pipes that have specific cooling needs to operate appropriately. Because of this, it is important that in any CPU fan installation you follow the manufacturer's installation instructions.
Performance chips of BMW
May 31, 2012 | Compaq Hp - 375376-001 - Dc7600 Tower...
How do you take apart the tower
Turn the computer off.
Disconnect the AC power.
Look at the "back" panel.
You might see thumb-screws that hold the side-panels in place,
or you might see Philips-head ("cross") screws.
Or, you might see plastic "locks" -- slide them 1/4 inch to "unlock" the side-panel, and lift it off.
Or, look at the side-panel -- there may be a "lever" (like a "tab" on the top of a pop-can) that can be lifted to release the side-panel.
Or, older towers had a "one-piece" cover (like an upside-down "U") that needed to be unscrewed, pushed slightly towards the back ot the case, and then vertically lifted off.
Aug 29, 2010 | Gateway GT5220 PC Desktop
The cooling fan on my Gateway 506GR has been noisy for several months. Now it "groans" every few minutes, but continues to run.
Have you cleaned all dust from the fan and inside the computer? If not disconnect all cables from the computer and take the tower outside. Remove the side panel and with a can of compressed air or an air compressor blow all dust from all fans, heat sinks, and all other components. Do not touch anything inside the computer without first grounding yourself to the chassis. If this does not solve your problem the fan needs replacing.
Dec 28, 2009 | Gateway (8008625) Cooling Fan, Heatsink...
Gateway Model 0019401806 Tower - Power button fell into case
there are tabs inside the case that you depress to pull the front cover off. once pulled off you should be able to replace the switch.
hope this helped
please rate well.
Mar 06, 2009 | Sony PCV-RS620G PC Desktop
Noisy
there are two screws on the back of ur tower for each side supporting plate .remove the side plate which is on the other side of ur motherboard.then just blow out all the dust with a air blower.
Dec 22, 2008 | Gateway 504GR PC Desktop
Disassembly
If your Gateway 300s tower is sitting vertical the button is in the front side under the CD-Rom push it really hard.
May 01, 2008 | Gateway 300 X PC Desktop
Computers & Internet Logo
David Payne
David Payne
