Question about ASUS K501 Pc Laptop/notebook As Is Needs Lcd Replacement & Hdd
Keyboard num lock
Cant switch to side numbers
  • 128 Answers
While pressing Fn button press Num Lock (should be on Ins button)
Posted on Mar 23, 2014
Num lock not working. number keypad not working. keyboard numbers are working.
Press the num lock button - usually the top left hand button on the keyboard numbers on right hand side of keyboard.
Mar 02, 2016 | Logitech Computers & Internet
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
WHAT IS THE ICON ON TOP TO THE LEFT OF THE CAPS LOCK ICON? HOW DO YOU TURN IT OFF?
This is either the Num Lock or the Scroll Lock. To turn off the Num Lock, look at the top left of your number pad on the right side of the keyboard, and press the Num Lock key. To turn off the Scroll Lock, press that key in the middle of the top row of 3 keys above your arrow keys.
Feb 27, 2011 | Dell 0Y3740 Keyboard
When I press certain keys like P I get 6
This is yoru number lock function
look along the "F" key row for the NumLk or picture of the number 1 in a square. then hold down the Fn key on the lower left of the board. press the "F" key that corresponds to it and this will disable it.
Feb 18, 2010 | Acer NSK8458AN Keyboard
Have to press fn to type the correct letters otherwise some keys type numbers the numbers lock is on and cant get it to turn off. i tried restarting pc didnt work. btw this is a laptop
1.  FN + F11
2. Fn+F12+Num Lk
3. F12 & the Num lock
hope one of these work.
if you have the keyboard driver you could try uninstalling it then reinstalling it.
please rate :)
Feb 14, 2010 | Acer NSK8458AN Keyboard
My asus keyboard is writing some keys as letters and others as numbers - tried restarting and no change (I am using a USB one now)
It sounds like you have your Num lock on. To disable the Num Lock either just hit the Num Lock key (its usually on the top right hand side of the keyboard) or hold down Fn and then hit the Num Lock key.
If you need more assistance please post back.
Regards.
Jan 06, 2010 | ASUS 90-A4C1K1000 Keyboard
Acer aspire 3003wcli keyboard stopped responding
You probably activated the "Num Lock" accidently. Just hold down the FN and look for the key that says "num lock" Now you should have your keyboard back and the numbers will just type when you hit the numbers key. I did this to myself yesterday!
Dec 06, 2008 | Computers & Internet
Number pad
There is a Fn key on the bottom left of the keyboard and a num lock key at the top right of the keyboard (depending on the model) Hold the Fn key and then press the num lock key, that should fix your problem.
Dec 10, 2007 | Zippy EL-610 Electron Luminescent Keyboard
My numbers aren't working and my num loc is on
i got it!! hold down the 2 shift keys for a few seconds then bamm!!
Sep 08, 2007 | Targus USB Ultra Mini Keypad Keyboard...
ASUS K501 Pc Laptop/notebook As Is Needs Lcd Replacement & Hdd Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
