Question about Xerox Phaser 7760/YDX Laser Printer
Fault 004-350 occurs right after booting up - Xerox Phaser 7760/YDX Laser Printer
  • 53 Answers
Faulty ROS or ribbon cable, (ros window may be dirty)
Posted on Mar 23, 2014
Xerox Printer not starting, A fault has occurred. Fault Error 116-201
The problem description is: Fault Code 116-201: HDD Was Not Booted Due to an HDD Error Detected on Booting. Try this link first: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=387,E=0000000005750000208,K=9799,Sxi=3,Solution=obj(542)
If this does not work. Unplug the machine from the wall while still on
do not power down first. treat it like the power just went off in your building. While the machine is still off not plugged to the wall. Press the power button several times. This will erase any saved info on memory.
Plug machine back on an try again. If it does it again you will need to replace your hard drive and that will take a service call.
Dec 10, 2015 | Xerox DocuColor 3535 Copier
Indicators not working,was pulling tandem trailer when fault occurred,can't find fuse
must b electrical, check all fuses in fuse box, below steering wheel to the right, or under bonnet on left hand side
Jul 07, 2014 | 1994 Mitsubishi Pajero
Sony vaio pcg-21314w boot problem before that while working the sceen color was suddenly changing and was flickering and then stop. after that laptop could not start just green light occur. so what is the...
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Feb 15, 2013 | Computers & Internet
Toyota fourrunner automatic boot problems
Hello
The engine and transmission in this cars drive train are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPEDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
Jul 16, 2012 | 2008 Toyota 4Runner SR5
How to farmat BIOS System, i set to boot from CD but i still yet an receiving some mess of numbers trap 0000000====== GENERAL PROTECTION FAULT=========== TR=0028 Cr0=0000000 does are the...
A general protect fault is when processor architecture is violated by any of the programs that are running. If it is only occurring when booting from CD, then the drive is probably not supported.
Mar 14, 2011 | Computers & Internet
Can you please giv a soluton for this issue: error code CE 40 toshiba e studio 3520
CE40: Image quality control test pattern abnormality: The test pattern
is not formed normally. If you switch off at the right hand side of the machine, wait
10 secs then back on again, It should clear. I think it is caused by condensation.
It can also be transfer belt failure, or paper rubbing against the transfer belt. It could be
because the Developer Unit failed to Pass the Close Looping Check by the machine
every time it boots.... check for fault from 08-824 if the value of any color is " 1 "
means abnormal occur.... check for foreign matters on the dev tank...the
simplest way is clean all 3 tanks...then reset it back to "0" then do a 05-200 and
05-396-4-Fax-1624-Set
95% solved the case
Jan 15, 2011 | Toshiba E-Studio 3511 Color Copier
My hp laptop wont change desktop background.
The Indexing related issue occurs if one of the device driver is corrupt or not updated. Did the issue occur right after you installed the system, or it started to occur recently? If it occurred originally, the hard disk may not support Win SAT. You may need to contact the manufacturer of the hard disk to confirm this situation.
If it started to occur recently, Kingv84, please let us know if you have installed any disc maintenance related programs. If so, please remove it and check the result. If the issue still occurs, I suggest that you boot in Clean Boot Mode.
Clean boot
Let’s disable all startup items and third party services when booting. This method will help us determine if this issue is caused by a loading program or service. Please perform the following steps:
1. Click the Start Button type "msconfig" (without quotation marks) in the Start Search box, and then press Enter.
Note: If prompted, please click Continue on the User Account Control (UAC) window.
2. Click the "Services" tab, check the "Hide All Microsoft Services" box and click "Disable All" (if it is not gray).
3. Click the "Startup" tab, click "Disable All" and click "OK".
Then, restart the computer. When the "System Configuration Utility" window appears, please check the "Don't show this message or launch the System Configuration Utility when Windows starts" box and click OK.
Please test this issue in the Clean Boot environment, if the issue disappears in the Clean Boot environment, we can use a 50/50 approach to quickly narrow down which entry is causing the issue.
For more information about this step, please refer to the following KB article:
How to troubleshoot a problem by performing a clean boot in Windows Vista
http://support.microsoft.com//kb/929135
If the issue still occurs in Clean Boot Mode, please let us know if the computer is from computer manufacturer.
For the desktop changing issue, please visit the link
http://support.microsoft.com/kb/327998
Jul 10, 2010 | HP 530 Notebook
Service right control
this light is on because a fault has occured in the automatic ride control system, there are many faults poss, so the only smart thing to do is have the dealer run a scanner on the control module and see what fault code is present.
Oct 18, 2009 | 1996 Cadillac Eldorado
Problem display with laptop
I am giving you some steps, which will help you to determine where the fault lies. In this situation like yours, this is the best I can do. Please come back to me the result and I'll help you to resolve it.
- Whenever the distortion is occurring, fix it to an external monitor/TV (if you have such facility). If the distortion does not occur there, your display is gone.
- Check if the distortion occurs during booting. That is, before any drivers are loaded. You need to look carefully. If not, it may be a faulty driver. Sometimes, drivers malfunction due to conflicts with different applications. This can be an application you have recently installed.
- If distortion occurs during booting, it may be faulty graphics card. To check it further, you can take a bootable CD/DVD and boot from that, and see if the display is correct; if not, the graphics card is gone.
If your graphics card is an integrated one, you can't replace it, but you can send it for repairing.
Hope it helps. Do let me know.
Good Luck & Thanks,
Shiv.
Aug 22, 2009 | Computers & Internet
Western Digital WD 1200VE; 120 GB external hard drive unable to boot
good eve prapad dont worry for your data ,first if you have a boot cd ,owerrite the OS ,then select repair option,it is occures due to 90% OS currupt ,
regards prasanna
Mar 05, 2008 | Computers & Internet
Xerox Phaser 7760/YDX Laser Printer Logo
110 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
