Question about Nokia E7 (16 GB) Smartphone
Need more solutions on how to reset my security code of a Nokia E7
Need more solutions on how to reset a security of my Nokia E7
  • 44 Answers
How to Perform Soft Reset of Nokia E7 with Secret Security Code:
Soft Reset Nokia E7 is the recommended try for user who get problem with Nokia E7. Doing the soft reset will not delete any important data, it only will restore the setting files with ini extensions to default on. The default ini files is saved in Nokia E7 rom, so it will not deleted event you already doing the hard reset or format Nokia E7. Do the soft reset easily by Press *#7780# with dial pad to Soft Reset Nokia E7. Please enter 12345 for security code
Posted on Nov 26, 2014
SOURCE: Resetting Security Code
i have nokia 1112
my imei no is 354573018881860 i want to reset my code
Posted on Sep 24, 2008
SOURCE: forgot security code for my nokia 6103b
Need help unlock nokia 6103b imei 354814011369325
Posted on Sep 27, 2008
Model : Nokia 6300
IMEI : 359809013573044
Can you please tell unlock code?
Posted on Aug 12, 2009
SOURCE: Master reset code for Nokia 6280
how can i get my 6280 mastercode?? my IMEI is 358356004735753
Posted on Jul 01, 2010
SOURCE: Nokia 5300 Security Code problem
my scurity code eror, help me new scurity code
Posted on Nov 01, 2011
I have forgotten my password for nokia e7 how can i hard reset
Follow the steps to hard reset nokia e7:
Before doing the master reset and format Nokia E7, ensure that you have backed up important data
1. The Nokia E7 battery should be charged fully
2. Turn Off Nokia E7
3. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
4. The Nokia E7 will reset
OR
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
GuruAid.com
Jan 04, 2015 | Nokia E71 Smartphone
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
Mar 23, 2014 | Nokia E7 (16 GB) Smartphone
Reset password
  5. The process will do format to factory default Nokia E7.
Source: http://www.hard-reset.org/factory-default/how-to-easy-master-format-nokia-e7-with-safe-hard-reset/
Jan 15, 2014 | Nokia E7 (16 GB) Smartphone
How to unlock that nokia e7 of f-secure ?
Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Master reset code:1122
Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Nov 03, 2012 | Nokia E7 (16 GB) Smartphone
Dear sir i wana format my phone nokia e7 i ave tried all of the solution but i am stucki in lock code which is not accepting any of the codes i have even tried pressing all the keys togather as sugges
Hi you mean that after you type *#7370# you can't find the security code ?If yes here is the tricks .first you need to find your E7 compitable USB cable.Afterwhich, just follow this link How to Generate Your Phone Security code..Only for Nokia bb5.You can easily get the code within max.5mints.Good luck.Thanks for visiting fixya
Jun 28, 2012 | Nokia E7 (16 GB) Smartphone
Forget security code nokia e7 how to unlock
The default security code for Nokia is 12345 or 00000 you can use it.
If you want to unlock your Nokia E7 you can use the codes ie the
unlock codes. Get the unlock codes using the site Onlinegsmunlock.com
and unlock it easily.
Apr 21, 2012 | Nokia E7 (16 GB) Smartphone
I WANT TO RESET MY NOKIA E7-00 WITHOUT ENTERING SECURITY CODE
You Can Hard Flash Your Nokia E7-00 without Security Code. At First Switch off Your Mobile, Then Press And Hold Green Key+End Key+Camera Key And Press Power on Button or see Complete Format Nokia Mobile Without Security Code.
Feb 18, 2012 | Nokia 3110 Cell Phones
Master reset code for nokia E7
i want to reset factory setting but first want to security code but i forgot i have need master security code
Feb 05, 2012 | Nokia E7 (16 GB) Smartphone
Nokia E7 (16 GB) Smartphone Logo
113 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
