Question about Husqvarna Viking 1
What is the symptom of a broken hoop
Broken hoop
    Scholar:
  • Husqvarna Expert
  • 104 Answers
Sounds like you might be having problems with the machine not wanting to start sewing an embroidery pattern or not recognizing the hoop size. If the former, and the embroidery is full size (say 100x100mm), try reducing the embroidery slightly (say 98x98mm). If the latter, your embroidery unit may need slight adjustment to correctly identify the hoop. Its not an elaborate adjustment but you will probably need a profession to accomplish it.
Posted on Apr 14, 2014
Singer xl-100 Where can I get hoops embroidery cards for singer xl100
http://www.ebay.com/itm/like/380994188253?lpid=82 and try searching for other in there as well....:)
Sep 08, 2014 | Singer Sewing Machines
How do i get my topaz 30 to accept the hoop installed?
Go to My hoops and add that size hoop. Make sure it is checked. Then select the hoop in the area for the hoop you are going to use. Make sure your design will fit in that hoop or it will reject it. If that does not work you may need to update your machine online.
Sep 07, 2014 | Sewing Machines
Can i do a large applique with my pfaff 7570 using the large hoop
Both the 7560 and the 7570 will only stitch out to the largest hoop it came with which is a 120 x 115 CM hoop (approx 4 1/4 x 4 3/4 inches). If you are using the Creative Big Fantasy Hoop or a Hoop-it-All you will need to split out the design so that each piece will fit within the 120 x 115 hoop. Transfer both designs to the machine. If using the original hoop, hoop your fafabric and stitch out the 1st design. Unhoop and rehoop again aligning the fabric with the hash marks on the hoop. You will have to move the design around on the screen to make a perfect fit. Stitch out the 2nd design. If you are using the Creative Big Fantasy hoop, you just have to hoop the fabric once, stitch out the 1st design and loosen the side screw on the hoop and slide the hoop into place for the 2nd design. Stitch out the 2nd design. The same process applied to the Hoop-it-All.
livingintx@yahoo.com
Feb 28, 2013 | PfaFF Creative 7570
My Singer XL400 gives me error #10 saying the hoop size is wrong, no matter which hoop I use. How do I fix this?
Update: In my case, the machine was broken. The main symptoms were that when opening the machine with the embroidery arm on, the embroidery wouldn't move at all as it should at startup and the error 10 would flash immediately. However, during my debugging time and as mentionned in Singer's FAQ (http://www.futura-support.com/products/xl-400/faqs), I learnt that the order in which you put/turn on the machine, computer and accessories matters. For safety, you basically need to close everything including the software when switching hoop size. Good luck!
Aug 06, 2012 | Sewing Machines
Brother PE770 Hoop size programming stuck on small hoop option
Your machine would be able to perform 5 X 8 embroideries. The hoop size on this machine is recognized by the machine itself, depending of the embroidery file size. So it the embroidery is small, it will indicate that the small hoop is needed.
But U can use the large hoop, position the embroidery where U want then perform another embroidery on the sams hoop.
TRICK : the embroidery size exceeds the hoop? reduce it in X and or Y using this function on the machine
Jun 10, 2012 | Brother PE770 Computerized Sewing Machine
Update for 150x150 hoop
If you have a light gray button then you need to have the embroidery unit upgraded. The hoop will fit on the machine, but the machine can not recognize the hoop. The new hoop holder that needs to be installed will have a second sensor trigger allowing the machine to recognize more hoops. The original holder only has one trigger and can only recognize earlier hoops.
Contact an authorized Husqvarna repair center to have your embroidery unit upgraded.
Nov 26, 2008 | Husqvarna Designer I
How do you use the Plus Hoop on a Husqvarna Viking "Rose" Sewing Machine?
The plus hoop is a multi positional hoop that allows you you to embroider designs up to 4" x 6". It is essential for monogramming and lettering using your Rose. The Rose hooping system is the same as the 1+, the Scandinavia 300 and 400.
The designs you use must be formatted for the plus hoop. That is, the design has already been divided into two or three elements. Each element is an individual design. For instance, say the design is a long stemmed rose. It would probably be divided something like this: design 1: the flower and the top part of the stem, design 2: The middle part of the stem and the leaves, design 3: the bottom part of the stem.
You would hoop up your fabric to be embroidered, attach the hoop to the machine, set the hoop to position 1, select design 1, stitch out design 1, set the hoop to position 2, select design 2, stitch out design 2, set the hoop to position 3, select design 3, stitch out design 3. You should have a complete design when you're done and everything should match up perfectly!
The hoop is divided up into three squares, 4" x 4". Position 1 square overlaps position 2 square and position 2 square overlaps position 3 square. This overlapping allows the designs to stitch out more smoothly.
I hope this helps. Let me know if you have further questions. Carrie
Aug 27, 2008 | Husqvarna Rose
I have a futura 150 and I can't get it to change hoop settings. I will put the small hoop on it but it doesn't recognize it. What do I do to fix it. It will change it on the computer screen but doesn't on...
Do not switch on the machine with the small hoop attached. After changing the hoop reload (close and open again) the design or restart the software or select the small hoop manually from the menu.
Aug 26, 2008 | Singer CE-100 Futura Computerized Sewing...
180E Hoop problem
Joan, there are 3 micrositches on your embroidery unit arm. these switches are depressed when you attach the hoops, it appears from your comments that one switch is not functioning. This could be simple, it is out of alignment or more complex it is broken. Either way you need to take it to a professional for repair.
Dec 21, 2007 | Bernina Artista 180
Sewing Machines Logo
91 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
