Question about Electrolux EW23BC71I (226 cu ft) Refrigerator
Our icemaker drawer was stuck and when we finally got it out a piece had fallen out from above and we can't figure out where it goes. It's about 3" long by 1.25 " wide and made of packing material wit
Trying to find a place to fit or snap it in above the ice drawer. There are 2 small tabs on the plastic backing that would snap in somewhere and hold it in place.
    Problem Solver:
  • 11 Answers
It should "snap" into the twist tray mold. The white thermistor should be placed below it. A plastic cable tie can be used to hold it in location better. Please unplug the refrigerator while you place it back in position
Posted on May 17, 2014
Lg icemaker stuck
You have an overflow of ice building up in the reservoir. Turn off the maker and use the contents until 3/4 are used up. Turn on again and stop when near full. Check to see if the LEVEL of the refrigerator is correct. The BOX may be tilted forward and an adjustment made.
Feb 26, 2014 | Refrigerators
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Ice cubes are turning into a clump of ice
I found a high density foam and a plastic retainer under the freezer drawer, inspected ice maker and found a wire with a rectangular senser hanging down. Removed freezer drawer and door to gain access to icemaker. Reinstalled foam piece and plastic retainer to lower front of icemaker (there are recess and a small retainiing tab) Reassembled freezer door and drawer, system working normally
Feb 23, 2010 | Whirlpool Refrigerators
We have a dell 1710 printer and it is continously jamming , it seems to be sticking when it is feeding from the bottom drawer, and when you pull out the drawer the paper is getting stuck in the drawer...
Solution migh be is to check whether there are paper pieces stuck in between rolls. Also you migh try to apply some grease in to rolling conjuction. Prior doing above just try to roll it by hand whether it rolls freely
Sep 23, 2009 | Office Equipment & Supplies
Kenmore Elite bottom freezer drawer won't shut
Has something fallen behind the drawer, and is preventing it from sliding back all the way? Remove the drawer by pulling it all the way out and lift it up and out. Look for anything that has fallen back there.
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker makes tons of ice and it spills all over the floor
The icemaker should have a thin metal arm that turns it off when the arm is raised, and on when the arm is lowered. This is so when the tub of ice gets full, the cubes push the arm up, and the icemaker is turned off to keep from making excess ice.
When I had the overflowing ice, I checked my icemaker and found that the arm had fallen off (and thus the icemaker won't know when to stop making ice). I found the arm and stuck it back on, and all was well. It may be a bit tricky, and it might take some ingenuity to keep the arm from falling back off.
I hope this helps!
Sep 29, 2008 | Kenmore 73503 Stainless Steel Bottom...
Sliding drawer in the top refrigerator section
hi i have the 700tc as well,,ok the best way to place the drawer,,,extend the 2 sliders all the way out,,there is one pin at the end of each slider and 1 hole on each side of the drawer lip which lays on the track ,,,the holes on the drawer must fall into the pins otherwise it will not close,,,so place the drawer on top of the slider ,,,what usually happens is the sliders tend to roll back into the housing of the fridge,,,so while the drawer is resting on the sliders reach under the lip of the drawer and pull each slider until the the holes of the drawer falls into the pins,,,when the drawer is seated in the pins it will close smooth,,,hope this helps
Feb 10, 2008 | Sub-Zero 700TC Bottom Freezer Refrigerator
White Plastic From Washer
Sounds like pieces of the detergent drawer might have cracked and fallen off. Check the drawer and see if you need to replace it.
Nov 01, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Warming Drawer stuck
Pull the oven out and see if you can get to the pans from behind.  May have to lift up on the back of the oven to get out fallen pans.
Oct 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Electrolux EW23BC71I (226 cu ft) Refrigerator Logo
49 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
