Question about Dryers
WIRING DIAGRAM FOR A DAYTON EXH. FAN FOR A GREENHOUSE. tHE FAN GOES TO A THERMOSTAT THEN TO ELECTEICAL BOX
My greenhouse roof collapsed and pulled the wires apart from the exh. fan, which goes to a thermostat. I need a diagram to rewire the fan.Ther is no diagram on the fan itself. It's a 12" Dayton Med. duty direct drive exh. fan .Model 4C361F.If I could get a diagram that would be great, thanks
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 69 Answers
So far, I cannot locate a wiring diagram for an installation. However, this is a single phase "shaded pole" motor.
For a single speed, shaded pole motor, there are only two power wires. For a dual speed motor, a third wire provides a second speed. One wire will be one side of the motor coil(s)...connected to the white power wire. The other wires are the opposite side of one or two motor coils, connected to the black power wire or through a thermostat. A thermostat is simply a temperature operated switch. An additional wire may (should) be a green "grounding" wire.
Specification Sheet from Grainger.
http://www.grainger.com/product/DAYTON-Exhaust-Fan-4C361
Installation manual.
ftp://207.99.53.68/array1/pacs/AS-BUILT/D1112-50-GLOBAL-Terminal&Container(15KV_ARC-RES-Swgr_Outdoor)/D1112-50-O&M/D1112-50%20Global/BM%20%23%20549%20Exhaust%20Fan.d20100210-u113426.pdf
Posted on Mar 23, 2014
5 Suggested Answers
SOURCE: I need a wiring diagram for a dayton 120/230 v
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Posted on Jan 26, 2011
  • 19 Answers
SOURCE: need a wiring diagram for thermostat/hunter model44260
Hello please try this link and see if this contains the information that you need
Reply to bsix@hotmail one way or the other Thanks
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/42711.pdf
Posted on Sep 14, 2009
SOURCE: wiring diagram for dayton ac electric motor
i need wiring diagram for a dayton electric motor 4mb22
Posted on Oct 21, 2010
  • 5245 Answers
SOURCE: wiring for a Dayton motor 6k857L
Wiring diagram appears on side of motor.
This motor is rated 115Volt.
Hot and Neutral wires connect to main terminals.
Connect other wires as shown on label.
For example there can be yellow, black, blue and white wires.
Dayton manufacturing is owned by WW Grainger.
Contact Grainger.
http://www.grainger.com/Grainger/static/help_contactus.html
Posted on Oct 12, 2012
WHERE CAN I BUY FLEXIBLE POLYCARBONATE SHEETING FOR MY 10FEET BY 16FEET GREENHOUSE?
this product is available on line --E-Bay-- from the manufacturers---and by order from you local hardware store. Comes in a variety of profiles and lengths and colours including a uv controlled style
Oct 10, 2014 | Cars & Trucks
Dayton 1HLA3A greenhouse fan blades do not turn unless I spin them to get started. Is this a capacitor issue?
fan starter in side there is a starter black box on wiring with c66 something on it change that. there are lots of these with the same number but you need the same uF number 1-4uf on most can go higher. get the same uf as the one in the unit.
Sep 21, 2013 | Dayton Dryers
Dayton 3 speed switch 34g191 has no wires or diagram. how do I hook it up.
2a5da9a5-aac3-42c6-abd8-aafc5120b40f.jpg205419c3-0ab0-44b2-af3d-75ca1d7c5061.jpg30a6a9a2-5d9a-485b-aa23-85f37da6902a.jpgDayton fan motor 6C539A Grainger switch number 34G191. Luckly I have two fans. So when the one I went to pull out fell apart before making anything I pulled the other one apart. Okay, on the white plastic there are numbers l(1), ll(2), lll(3). Orange wire l(1), nothing in ll(2), blue wire lll(3). Now on the black plastic, the outlet wires go here: black wire L, white outlet is 180degrees (by orange wire) NEUTRAL SPLICER. Now, white wire from motor goes into the other side of the NEUTRAL SPLICER next to the black wire on the black plastic. This is just above the ll(2) on the white plastic. REMEMBER - NOTHING GOES INTO THE ll(2) ON THE WHITE PLASTIC.
May 02, 2013 | Dryers
I need help on connecting my a/c thermostat
Determine if the two wire thermostat wire goes to a Condensor on the ground or roof. The red goes to (r)24v on stat. Green(g)fan, white(w)-heater, blue - (y1)-cooling .red 2wirre goes to blue also.white2wire goes to common ( C) terminal.
Apr 20, 2013 | Heating & Cooling
What is a miniature greenhouse called?
It's called a cold frame. It is a close to ground enclosure with a roof that is usually transparent.
Jan 29, 2013 | Garden
My Dayton 4lz94 greenhouse thermostat doesn't activate at the set temp. But will turn on when temp is about 5 degrees below. Set temp. Is there a sensitivity adjustment to calibrate for activatio
I am having the same problem with my Dayton greenhouse thermostat, this question was posted in the wrong section...but if you find a solution I'd like to know. I am having problems with the heating thermostat as well as the cooling one.
Jan 27, 2012 | Ovens
I am having trouble with rewiring the air handler transformer and thermostat wires
Here is standard wiring on a low voltage transformer:
"r" on transformer goes to "r" on thermostat (use red wire)
"w"on transformer goes to "w" on thermostat (use white wire) (this is heat)
"y" on transformer goes to "y" on thermostat (use yellow wire) (this is cooling)
"g" on transformer goes to "g" on thermostat (use green wire) (this is the fan)
"c" (if used) goes to "c" or thermostat
"o" (used only on a heat pump)(orange) (reversing valve)
note: on most thermostats if you have an rc and an rh, they both must be jumpered together and use them as "r" (red)
Jun 23, 2011 | Heating & Cooling
Have a dayton 3F405D propane greenhouse heater don't know where to light the pilot light.
Find where the gas line connects to the gas valve on the back of the heater, from the gas valve, follow a small aluminum tube going into the back of the heater. There may be a removable door to access the pilot assembly. If there is no aluminum tube, the unit has electronic ignition and no pilot lite. Turn the gas knob to off, then to pilot. Hold the gas valve in and with a long match or gas grill lighter, light the pilot. Continue to hold the knob in for about 30 seconds. After that, release the knob and check to make sure the pilot stays lit. If so, rotate the knob to ON. The thermostat will kick the burners on.
Mar 30, 2011 | Dayton (3E405) Gas Radiator Heater
I need the wiring diagram to wire a thermostat to the outside unit. Which wire goes where ? My Thermostat has four wires, green, red, white, and yellow. My Outside unit has three wires that are not...
The thermostat wires are this, Red is 24 volts hot, Yellow is cooling, Green is fan,indoor, and white is heat.The outdoor unit wires up to the indoor units terminal board, not the thermostat.The red will go to the R or red 24 volt wire at the furnace.The yellow goes to the yellow terminal at the furnace. You should only have 2 wires to connect at the outdoor unit. Try capping the blue off.It may not be used unless this is a dual transformer unit which you will need a tech to come out and rewire the furnace to make the outdoor unit a 2 wire set-up. This can be very complicated if this is the case. Connect these wires like I have said to the indoor unit, and it should work fine. Please keep me posted. This is only low voltage, so don't let it scare you. If nothing works, I would say that the blue wire outdoors is the 3rd wire for a 2 transformer unit, and will need to be rewired at the indoor unit for it to work, this I would have to be there to do.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Feb 26, 2011 | Heating & Cooling
Dryers Logo
422 people viewed this question
Top Dryers Experts
