Question about Roper RGX4634KQ Gas Dryer
Drier keeps running
Ran all nite was hot in am but still on
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 50 Answers
Sounds like you have a bad timer
Posted on Mar 24, 2014
1996 cavalier has no fire and on interior fuse panel somefuses have good voltage and some dont...car ran ok but when was turned off and let sit over nite now it wont start back
Some fuses are only hot when the ignition is turned to run and some are always hot and other are hot only when the fused part is turned on. so that is not your problem
Nov 23, 2016 | 1996 Chevrolet Cavalier
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
Drier is running hot, smells like my clothes are burning, and it keeps blowing the fuse in the main panel.
Most probably a venting problem and probably caused the heating element to ground out in its casing. Easiest way to verify is turn your timer to 30min and if dryer starts heating without pushing the start button you got a bad element caused by bad venting most of the time.
Apr 16, 2013 | Estate TEDX640JQ Electric Dryer
Ac blows hot air,compressor does run,put can full can r-134 in it! ran kinda cold couple hours. went to turn on again and nothin but hot air
Have you checked your condensor out ? could be clogged...or your accumulater/Reciever Drier being faulty..
May 25, 2011 | 1999 Chevrolet Cavalier
Pressure problems
those seem to be very acceptable numbers you are stating if this is R22 running in summer temps. Im curious what pressures you are striving for?
Jul 02, 2009 | Heating & Cooling
I ran the drier 3 times using medium press. The heat is on and it is hot, but the clothes is not dry.
Hi, Does this dryer heat at first and then stop heating late in cycle?
Remove the lower front panel and start the dryer. Look and see if the ignitor glows and if you get a flame or not. If the ignitor glows and then shuts off before you get a flame, the coils on top the gas valve need changed.
If the ignitor does not glow, UNPLUG the dryer and check the fuse located on the blower housing (whits with two wires going to it). Check and see if it has continuity to it.If there is no continuity, change it.
Please let me know if this helps you so far.
Vic
May 30, 2009 | Whirlpool GGQ9800PG Gas Dryer GOLD...
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
Drier keeps shutting down.
I had the same problem, they wear out in the rear bearing slot and drag on the front slides, So I bought Sears heavy duty model and it was was running better than ever until my wife took it away when she left me. Hope this helps
Feb 02, 2009 | Whirlpool LER4634J Electric Dryer
Wont blow hot air
heating element failure 30 bucks and an hour of labor
Jan 14, 2009 | Dryers
Fisher Paykel double dishdrawer
pour some vinger in and run it thru a few cycle this will flujsh it out also if you have a hot tub supply store near you can buy a bottle of Foam Down and that will cut the bubbles down so you can wash again
May 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Roper RGX4634KQ Gas Dryer Logo
59 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
